Home › Forums › Bike Forum › First proper eMTB ride revelations
- This topic has 30 replies, 22 voices, and was last updated 55 minutes ago by Aidy.
8bikesandbootsFull Member
Had some interesting noticings. For context this was on a “lite” bike.
Any such things yourself?
Not running so hot. Sweaty but not dripping, so need to squeeze out my helmet pad so often, and don’t chill so quick when stopped in a windy spot. I put it in turbo on the way back on some doubletrack, I actually got cold presumably due to the wind chill of speed and not generating as much heat myself.
Forgetting to drink enough. Arriving at the top of a climb half wasted, out of breath, and all hot and sweaty must be a natural trigger to take a good gulp.
Leg cramps due to never having to get off and push. I get these sometimes towards the end of a long ride on my normal bike, usually on a long climb or descent. The solution is always to walk for a bit (stretches don’t help). Didn’t have to push any climbs so no walking, so I got the onset of cramps despite the ride being less of an effort overall. I guess my legs don’t like full time cycling and need walking now and again.
Shifted gears almost 1000 times over 45km. Count is from AXS. I didn’t have a guess beforehand but that’s a big number. Battery still showing full. Makes you appreciate how much cables and mechanical shifters last.
Using gears 2-9 about the same amount of time, 1st (52T) twice as much, and 10-12 almost never. That’s with a 32T chainring (smallest available), using eco most of the time. Glad I replaced the factory 34T. I’ll have to see if that aluminium big cog is what renders the cassette worn first.
Having energy for the descents makes a huge difference, I’m sure I was doing wheel lifts, hops, pumping a lot better despite the bike being 4kg heavier and 20mm longer chainstays.
Overtaking other eMTB riders on climbs, who were using absolutely glacial cadence on full power bikes.
Being overtaken by someone on a normal bike while climbing in eco mode (100W assist).
No idea if that day was better for my fitness vs. a normal bike day, definitely wasn’t as knackered by the end and I mostly used eco. Going to try and avoid the temptation to pair my Garmin watch heart rate sensor and be nerdy about it. 50km, 1300m ascent, no pushing. Normal bike sameish route with fewer trail repeats would be 35km, 900m ascent, of which 250m pushed due to being steepish and near the end of the ride.
johnheFull MemberI’m still new at eMTBs. I have several weeks on my lite e-bike. I did measure my heart rate on two short trails, just to try to see the contrast. My max and average heart rate drop by about 20 on the e-bike. But to balance that, certainly in deçent weather, I was going 50-100% further.
like yourself, I’ve noticed that I sweat less. I used to be a total sweaty mess at the end of any decent ride. Also, I can now make techy climbs that beat me on my normal bikes. In fact, I’ve found myself riding back down just to ride some of my favourite technical climbs more than once. That’s not something I’d have the legs to do on my normal bike.
i had my first hike a bike on my e-bike yesterday. Even though my bike is only 18kg, I thought it was going to kill me! Still, I was able to ride a lot that I would have been pushing before. And I’m fairly confident I enjoyed it more.
like yourself, I’ve found myself enjoying the good bits more than ever – presumably due to being less knackered.
but the consensus seems to be that our fitness will definitely suffer. I’m prepared to work with that, because the benefits are so noticeable for me.
1BruceFull MemberI have a question.
When we were cycling round Ballater we cycled up to Loch Muich and we are used to being passed by people on eBikes. On the way back is a long and gradual descent and we seemed to catch up with and pass people on eBikes who were pedaling down the slope.
What happens when you go downhill? What does it feel like?
juliansFree MemberWhat happens when you go downhill? What does it feel like?
Assuming we’re talking about a typical ‘proper’ mid motor mtb from one of the main brands (I can’t speak for home made specials, or Halford specials) It feels like a normal mountain bike, but a few kilos heavier, which gives slightly different characteristics when descending, but not hugely different. Emtb can plough through rocks/rough stuff better than a regaulr mtb, but are a bit less responsive to braking and changing direction (because of the extra weight). It freewheels/coasts like a normal mountain bike.
I’m going to guess that you caught these people up because they weren’t as proficient at descending as you are.
I think quite a proportion of emtbers have never actually ridden a regular mtb any significant amount, so may not have the experience and skills an average regular mtber who’s been riding for 20 years might have at descending.
BruceFull MemberI think they were people on hire bikes, so probably not very experienced cyclists. The track is as non technical as you can get and I was not pushing on as I am fatter than my partner and she has less natural momentum.
I guess I am going to have to hire an eBike and find out.
I have a fear that if I try one I will want one.1potheadFree MemberI have a fear that if I try one I will want one.
You will want one, but treat it as a different sport to non assisted mountain biking. I’ve had a Whyte E-160 (which is heavy by ebike standards) for about 15 months now and it there are places I’ve ridden that would definitely be more fun on a normal bike but on the whole I’ve got no regrets about buying it. The weight makes it a handful on slower steep techy switchbacks and also on fast stuff with quick changes of direction, but being able to do 8000ft of climbing in a day where I’d usually manage about 4500ft, as well as an hour on turbo after a 10hr shift at work makes it more than worth buying to me. It also means climbs that wouldn’t be possible on a normal bike aren’t just possible but are actually fun to attempt. I’ve no plans to get rid of my trail bike but the ebike has been a game changer for me personally
3FunkyDuncFree MemberGoing to try and avoid the temptation to pair my Garmin watch heart rate sensor and be nerdy about it
I am still waiting for my first emtb (orbea Rise) to arrive, but when I tested a few back in May my heart rate was just as high as it was on an analogue bike. That could have been because I was trying to get as many runs in as possible on the day.
I guess it depends why your bought an ebike, and what you like riding. I like riding uphill so maybe my hr will remain high, but my ultimate aim is to still do the climbs and keep going for longer.
oikeithFull MemberWhat happens when you go downhill? What does it feel like?
They all feel different depending on the motors, I am in the e-curious camp and have demo’d some ebikes. I found some motors that you pedal to the limit and then its like hitting a wall almost when the assist goes and then the motor is draggy and slows you back down, whilst others have been less draggy and felt like you could sprint past the assist limit with no issues other then a slightly heacvier bike, but its more planted.
potheadFree MemberI am still waiting for my first emtb (orbea Rise) to arrive,
A mate of mine has been waiting over 6 months for a new battery for his Rise (warranty claim, due to water ingress according to the shop he’s dealing with) , last he heard was basically ‘we don’t know when we’ll be able to get one’. He’s not a happy man
1didnthurtFull MemberE-bikes are fun and definitely make climbing easier, leaving you less tired for descending. I’ll be on one eventually, just not quite yet, even then I think it will be a ‘light’ version.
Also I reckon one benefit of e-bikes that is underplayed, is keeping your heartrate down, I don’t think maxing my heartrate on the bike (or anytime) is healthy for a mid forties dad with a bit of a belly.
A bit like a brisk walk being better for your overall health compared to running. Just a thought.
2DickBartonFull MemberDrink more as that can help reduce cramps as well…maybe have an electrolyte mix to keep drinking from.
reeksyFull MemberAlso I reckon one benefit of e-bikes that is underplayed, is keeping your heartrate down, I don’t think maxing my heartrate on the bike (or anytime) is healthy for a mid forties dad with a bit of a belly.
Mid-forties? Mid-forties?
1EwanFree Member“I don’t think maxing my heartrate on the bike (or anytime) is healthy for a mid forties dad with a bit of a belly.”
That seems unlikely to be true. In any event you’re probably not going to max your HR cycling, running max HR is normally a bit higher as more muscle groups involved.
2BadlyWiredDogFull MemberAlso I reckon one benefit of e-bikes that is underplayed, is keeping your heartrate down, I don’t think maxing my heartrate on the bike (or anytime) is healthy for a mid forties dad with a bit of a belly.
Maybe look at golf as well? Combines walking with mild resistance training and low HRs – win!!
2BadlyWiredDogFull MemberHad some interesting noticings. For context this was on a “lite” bike.
Did you enjoy yourself at all?
3qwertyFree MemberAs a non ebiker my observation is that eMTBers wear more clothing.
welshfarmerFull MemberNot sure how to link an Instagram Reel but reading the OP it seems he needs to learn the Emtb riders mantra :-)
matt_outandaboutFull MemberBeing overtaken by someone on a normal bike while climbing in eco mode (100W assist).
That’s one of my lads party tricks…It is a matter of stubbornness that he keeps up or overtakes eBikes.
Bloody twenty something year olds.1bikesandbootsFull MemberDid you enjoy yourself at all?
Yes!
When I’m not riding bikes I like thinking and talking about riding bikes. As we do on this very bike forum.
rudedogFree MemberIve demo’d a good few e-bikes, one thing I really dislike is the on/off feeling when the speed limiter kicks in and disengages the motor. Feels like an actual brake on some of them.
3grahamt1980Full MemberUsing an ebike to keep your heart rate down as a positive?
Yeah sure if you have a medical condition that means you shouldn’t go hard (have a mate who suffered from that), otherwise that is a poor excuse to be a lazy arse
1didnthurtFull MemberThat seems unlikely to be true. In any event you’re probably not going to max your HR cycling, running max HR is normally a bit higher as more muscle groups involved.
Nice to know that you know more about me than I do.
As for golf, I think an e-bike would be cheaper than the cost of replacing all the golf balls I’d lose.
I still think that as a ‘health’ point of view, riding in zone 2-3 for longer periods would be better for most people than the zone 4 (and briefly zone 5) that can be reached when riding off-road on proper steep off climbs and muddy conditions.
https://health.clevelandclinic.org/exercise-heart-rate-zones-explained
2FunkyDuncFree MemberUsing an ebike to keep your heart rate down as a positive?
I think like anything there is balance. I am no expert, but I think there is now research that shows as you get older max efforts etc can do more harm than good for your heart.
I am 50, and cant be arsed ‘training’ to get fit, as its always going to be a loosing battle now. I just want to keep fit and do the stuff I did as a fit young kid, and an ebike definitely enables me to do that !
1inthebordersFree MemberIve demo’d a good few e-bikes, one thing I really dislike is the on/off feeling when the speed limiter kicks in and disengages the motor. Feels like an actual brake on some of them.
Far worse on full-fat bikes than SL’s, I don’t even notice it on my Kenevo SL.
Also, this only really occurs when you’re riding on tarmac or up a fire road – so probably going far faster than you would on a normal bike, either pedal harder or go and buy a motorbike.
1BadlyWiredDogFull MemberI still think that as a ‘health’ point of view, riding in zone 2-3 for longer periods would be better for most people than the zone 4 (and briefly zone 5) that can be reached when riding off-road on proper steep off climbs and muddy conditions.
Isn’t the point – as per Joe Friel etc – that you mix zone 1.2 riding with occasional shorter, harder efforts, which is pretty much what happens if you ride a conventional mountain bike aggressively on undulating/technical terrain. It’s not ‘either / or’ you can do both?
bikesandbootsFull MemberWhich eeeeeb did you buy in the end b&b?
Mondraker Neat.
A compromise between everything I liked and disliked about Bosch SX, Specialized SL 1.2, TQ HPR50, and the bikes they come in.
Was offered a good price on an in stock 2024 model, and didn’t see rumours of anything appealing coming next year so went for it.
I was hoping to like the Bosch SX, and wait for Bird/Ethic’s SL sometime next year. But that clutch rattle killed it for me, and to a lesser extent the fixed batteries.
jediFull MemberI absolutely love ebikes. Full power so my spectrum of assistance is greater. Game changer .
TheArtistFormerlyKnownAsSTRFull MemberIve demo’d a good few e-bikes, one thing I really dislike is the on/off feeling when the speed limiter kicks in and disengages the motor. Feels like an actual brake on some of them.
You can make that not happen you know ;-)
But don’t tell STW, they’ll probably get a bit preachy…
AidyFree MemberI don’t think maxing my heartrate on the bike (or anytime) is healthy for a mid forties dad with a bit of a belly.
Where on earth does this idea come from? Probably more at risk for not hitting your max heart rate.
AidyFree Memberbut I think there is now research that shows as you get older max efforts etc can do more harm than good for your heart.
Links please.
