Hola – Putting this one out to the hive mind as I’m not having much luck so far…
I’m looking for some replacement gravel forks – as the aluminium crown and carbon legs on my 7 y/old pair are doing their best to part ways. (Nice crack around the top of both fork legs where they join the crown! Sadly, it’s very much out of warranty).
Finding replacements of a similar spec is proving to be a bit tricky, so if anyone has any pointers…
400mm a/c
Quick release
Post mount brake
Mudguard mounts
Clearance for 40mm off road tyre, or slightly smaller road tyre with mudguards
Can be carbon or aluminium, around £100 from a brand/source that can be trusted ;-)
Thanks in advance!
