Home › Forums › Bike Forum › Fatbike with modern trail geometry
- This topic has 131 replies, 44 voices, and was last updated 8 years ago by roverpig.
roverpigFull Member
Just a bit of idle Friday daydreaming really, but what’s out there with:
Tyres at least 4″
Head angle no more than 68 degrees
Chainstays no longer than 440mm
Decent reach (i.e. longer than 445mm in large)
Nice bright colour(s)ClobberFree Memberpuffin is closest one I can think of
Edit: Might need some bright stickers…
monkeyboyjcFull MemberNicolai argon Fat….
Or a Mi-Tech if your prepared to order from them.NorthwindFull MemberI don’t know of any, but also, I’m not sure it’s really that comparable- they’re pretty different bikes so it doesn’t necessarily follow that the same geometry works. My 2 day to day bikes are a long slack 150mm 29er #endurosled, and a much smaller and shorter fatbike but the fatbike doesn’t feel like it needs to be longer and slacker. Everything on paper tells me the fatbike’s short and steep and probably too small for me, but it doesn’t ride like it.
If I was riding the same stuff (tweed valley enduro offpiste etc) on a normal bike with an 1140mm wheelbase and 68 degree head angle I’d not be happy but it works really well as a package on the Dune. I suppose at least partly becasue it doesn’t sag but I’ve a feeling there’s more going on than that. Lots of rotating mass? Low roll centre? But I am not a geometrologist, maybe we could get Chris Porter to make something up to explain it.
nedrapierFull MemberNibbling after the fat/thin thread, roverpig?
Latest puffin’s been tweaked to fit 29+ as well as 4.7/4.8s. You’d have to rebuild on different hubs, but you could reuse some of what you’ve got on the Solaris.
roverpigFull MemberNibbling after the fat/thin thread, roverpig?
No, no, not interested at all, honest guv 🙂
The Puffin has the shortest chainstays of any fatbike I’ve seen, but still a 70 degree head angle. Maybe that doesn’t matter, but it looks steep on paper. Plus it’s white, which is just really light grey !
Well it only took three posts to attack my premise 🙂 but I’ll let you off as you make some interesting points and I’d be the first to admit that I don’t know what I’m talking about when it comes to fatbikes.
If I were interested, which I’m not, oh no siree, it would be based on the following logic:
My chubby Solaris (currently running 2.8 Nobby Nics) is fun and (based on no experience at all) I’d wager that it’s probably a better all-round trail bike than any fatbike (with Trailblazers for the summer). But that’s it’s problem really. It is basically a decent trailbike, which is fine but I’ve already got a good trailbike (Smuggler). The Solaris is a bit different, but I’m not convinced it’s really different enough to justify its place. It’s a slightly better option than the Smuggler when the trails are a mess (like now, with a good mix of snow, ice, mud and bog) but mainly because it means the Smuggler can stay tucked up nice and dry. It doesn’t really cope that much better with crap (or non-existent) trails. A bit, but not a lot. But a fatbike might !
Except that fatbikes are ponderous, heavy, have chainstays so long that they are stuck to the ground and head angles so steep that you wouldn’t want to point them down anything remotely steep. We all know that, right 😀
scaredypantsFull MemberWell it only took three posts to attack my premise
haven’t done much fattyriding yet but I nwonder if things like the (real IMO) tendency of big tyres to self-steer might get interesting if you made a very slack-fronted version
thisisnotaspoonFree MemberIt was mentioned on the other thread, but Fatty Trail?
I suspect it’s probably the longest/slackest you’re going to find without going down the semi-custom route, or at least spending 5x to 10x as much. Based on my Original Fatty the large isn’t cramped even with a short stem, it almost always feels ‘about right’ for #enduro type stuff.
People said the same about wheels bigger than 26″ and a split between XC and everything other than XC. Then stuff like the Enduro 29er and then 650b/650b+ happened.
I doubt a fat bike is going to win the EWS, but that doesn’t mean they’re limited to the current crop of ‘XC’ fat bikes, is there anything in production apart from the O-O designed around 120mm forks?
I think it’s overplayed, it’s not noticeable off road, and it seems to depend on everything from the tyre and pressure, to how well it seated on the rim. It’s not like you ride along and suddenly get the bars ripped out of your hands by a slight camber.
nedrapierFull MemberPlus it’s white, which is just really light grey
Funny you should say that, the new one is actually light grey!
http://webshop.singularcycles.com/en/Products/Singular-Puffin.html
I wasn’t convinced by the idea of fat, which is why I waited til I found one 2nd hand, so I could ship it on for not much loss if I didn’t get on with it.
But it’s quick, grippy and fun, climbs really well, and I’ve pointed it down some chest-on-the-saddle steppy downhills and come out smiling. Sam’s pretty happy to talk geometry if you’ve got questions about why the angles are how they are.
monkeyboyjcFull MemberLike I said…..
Nicolai Argon Fat67.5° headangle
610 mm top tube (med frame)
440 mm chainstaysComes in any colour you want.
Just be sat down when you look at the cost.
richiethesilverfishFree MemberMondraker Panzer.
Not 100% in line with your list of must have’s but its pretty close and is Forward Geometry so definitely fulfills the ‘modern trail geometry’ criteria.http://www.silverfish-uk.com/ProductDetail/0/18112/Panzer-RR-Bike-2016
roverpigFull MemberThanks for all the suggestions folks.
Calibre Dune available mail order
Not the large ones yet though, thank heavens. Also, chainstays are long (if that matters).
Nicolai Argon Fat
I bet it’s brilliant, but I’d need to be a lot more convinced a fatbike was going to work before splashing that sort of cash.
Mondraker Panzer.
Again, a bit spendy for an n+1 and could I really live with a bike called a Panzer?
Fatty Trail
There is a lot about that I like, but I haven’t managed to dig up much in the way of a review yet and am I right in thinking that 4″ would be the limit for that?
hopkinsgmFull MemberBeargrease ticks most of those boxes though the head angle is a touch steeper at 68.5. And some of the 2016 variants really tick the “bright colours” box.
Bright enough for you?[edit]Just seen your last comment bemoaning the spendiness of some of the other options suggested. Probably best you don’t go looking at the price of Beargrease Carbon X01’s [/edit]
tillydogFree MemberTyres at least 4″
Nice bright colour(s)If you can live with very dark white, and another degree on the head angle, then the Farley 5 ticks the other boxes:
Tyres 4.8″ stock – upto 5″ will fit (also 27.5 x 4 for when they become fashionable)
Head angle 69 degrees (angleset if you want slacker?)
Chainstays 440mm (adjustable)
Reach 441/454mm in 19.5/21.5″ frames
Nice bright colour(s). Ahh, got me there…pipiomFree Memberhttps://www.pivotcycles.com/bike/les-fat/
Does it for me. 69 degrees, I know, but feels as slack as a thing.
thisisnotaspoonFree MemberThere is a lot about that I like, but I haven’t managed to dig up much in the way of a review yet and am I right in thinking that 4″ would be the limit for that?
I’ll stick a wheel in the back tonight and take a photo.
It’s listed as 4″, but it does take a 2x chainset so chainline shouldn’t be a problem, chainstays might be though. But whilst I’d hate to disagree with the irrefutable logic of fat = good, moar fat = betterer, I suspect that 4″ tyres are wide enough, and don’t need such a wide chainline.
People rode the idtarod on 3.7’s endomorphs before the BFL came along (and before that 3″ grazoldi and spesh big hit tyres, and before that in the 90’s on2x normal tyres).
STATOFree MemberTyres at least 4″
Decent reach (i.e. longer than 445mm in large)I did a comparison of a few bikes and really you need to be very careful just comparing numbers without looking at what fork they have.
The fatty trail is measured with a 120mm fork. Large=440mm reach
A surly Wednesday with a short rigid fork. Large=453mm reach.But run with the same fork they are near identical geo wise.
The XL Singular is very similar reach to the Large Wednesday and measured with a rigid fork, but has much more stack.
If you look at trek, same frame but different fork = different reach.
Rigid Farley 5 reach XLarge=454
100mm Bluto Farley 9 reach XLarge=444peccuFree MemberI bought a Fatty Trail last year and absolutely loved it, then Cannondale announced the Fatcaad1 and as a Canno’ fan i ended up ordering one.
I have done a few laps of Dalby red on both now and a couple of rides in the dales to compare both. I think the On One has a bit more aggressive feel about it, more bullet proof? but the Fatcaad feels livelier somehow.
I tried one of the wheels with a 4.8 JJ off the Canno’ into the rear of the Fatty Trail but not enough clearance, the Bluto will easily take it though.
Fatcaad has a steeper head angle but the lefty has a big rake. Both bikes at Dalby, mate wanted to try the On One and was really impressed.
NorthwindFull Memberthisisnotaspoon – Member
Yeah, but that’s my point- I’m out riding my “xc” fat bike on ews trails, and not that much slower than on the proper bike, and it doesn’t feel at all like an XC bike- it’s a far more stable and confident descender than the numbers all. I’m not going to pretend I know why but it’s really surprised me, enough that I’ve put aside ideas that what I know works for one works for another.
I just put an angle headset in the enduro bike, but I’ve no urge to do the same for the dune and it gets ridden on much the same stuff. I think I fatbike wrongly tbh 😆
roverpig – Member
I think long stays are in just now, but it can only be a matter of time til they’re out again, or shaking it all about.
juliofloFree MemberSurly Wednesday.
But it’s the only Fatbike I’ve ridden on a half decent trail, other than others i’ve only swung a leg over.
Rode one at Ashton Court in the Oktoberfest for a lap. It was much more fun, happy to be thrown around and launched off stuff than the Scandal 29 I was racing on which is my daily bike and the only mtb I’ve rdden for the last three years. I felt like I was able to stay off the brakes for almost the whole lap…
Also Ashton court isn’t remotely technical at all. So not an extreme test. But I thought the Wednesday was great.
thisisnotaspoonFree MemberYeah, but that’s my point- I’m out riding my “xc” fat bike on ews trails, and not that much slower than on the proper bike, and it doesn’t feel at all like an XC bike- it’s a far more stable and confident descender than the numbers all. I’m not going to pretend I know why but it’s really surprised me, enough that I’ve put aside ideas that what I know works for one works for another.
Fair point, and the dune is moderately slack already.
It’ll be interesting to see whether fat bikes are here to stay and move into other niches (like trail/enduro) or if they’ll just slowly disappear off the radar and return to being an oddity. There’s certainly not been the massive influx of models we saw 18 months ago, I kinda expected some 29er front triangles with modified rear ends from the big brands (take a stumpjumper aloy, swap the BB to 100mm, and fit some new chain/seat stays) but it seems we might have hit ‘peak fat bike’.
roverpigFull MemberI think long stays are in just now
Darn it, so they are, I must pay more attention.
So, chainstay length doesn’t matter, head angle doesn’t matter, you can ride a fatbike that is two sizes too small for you and that doesn’t matter either. We’re still agreed on the importance of getting the right colour, right?
Surly Wednesday
Thanks both, I’d not seen that before. Presumably not the lightest option, but does seem to fit the bill.
And the Farley 8 even comes in green. It does look a bit like a more expensive version of the On-one, but worth further investigation.
That’s good to hear. There does seem to be a dearth of reviews for the fatty trail, which is a bit surprising for an on one. There was a lot of activity in forums last September when it was launched, but very few ride reports since. Maybe everyone is just having too much fun riding them to post.
Too late. It’s lovely, but ouch ! To be fair I like a spendy bike as much as the next man. Just maybe not on a bike that you think may well be a mistake before you even pull the trigger.
Thanks. Good point, well made.
scotroutesFull MemberFWIW, my 5 year old 9ZERO7 has a 68 degree HA. Newer versions are up to 69 or 69.5.
tillydogFree MemberAnd the Farley 8 even comes in green….
Be careful – the older Farley 6 and 8 have different frames to the newer 5 and 9, etc. (AFAIK)
NorthwindFull Memberscotroutes – Member
Interesting that. Any idea why?
scotroutesFull MemberNope. I’d have thought that with fatbikes being adopted for more “general” duties HA would have decreased over the years. Maybe?
SannyFree MemberJust test ride a few and don’t get hung up on geometry. My Beargrease is rapid and fun to ride but for sheer, hooligan, big mountain stuff, the Ice Cream Truck wins every time despite being several pounds heavier!
however, I now have a Fat Caad Lefty to test. Really excited to see what it brings to the party. It looks lush! 😀
I still want to play on a Wednesday and a Singular though!
roverpigFull MemberOK, I’ve done some more thinking and reading (thanks for all the pointers) and am happy with the geometry. A couple of other questions have arisen though:
Suspension or not? My original thought was that big squishy tyres make suspension less necessary, but a few of the reviews of the Bluto have made me think. A rigid bike with big tyres is still a rigid bike, you just have to be really careful with pressures to stop it turning into a bouncy mess. So, stick some damped suspension on and run the tyres a bit firmer. Job done. No more getting bounced all over the shop, more traction, fewer punctures etc. What’s not to love?
Four inch or five inch? Four for general trail duties, five for snow right?
NormalManFull MemberSurly Wednesday (or Calibre Dune depending on budget).
Try it rigid and add a bluto if you feel the need.
roverpigFull MemberSurly Wednesday (or Calibre Dune depending on budget).
Is that based on the tyre clearance? It does seem that bikes that come with Bluto forks tend to be restricted to 4″ tyres (being designed for trail use).
On paper the Dune is the obvious choice out of those two. Half the price, lighter and much more fun colour, but there is a lot to like about the Wednesday. Surly kind of kicked off the whole fatbike thing and I quite like that. Chainstays can be dropped right down to 435 with the smaller tyres. Nice. Even the seat tube is nice and steep, which I like. But it is twice the price, heavier and comes with Nate tyres that nobody seems to like (so more cost there to change).
It’s only a thought-experiment at the moment and may never progress any further, but it’s fun to dream about new bikes.
NormalManFull MemberBased on my reading of what you are looking for I’d say.
But then I like nates!
roverpigFull MemberBased on my reading of what you are looking for I’d say.
What, you mean you actually read all this rubbish ?!!
Seriously, thanks. I know you’ve been down a similar route and have given it some thought.
That;s good to hear. All I read so far is about how draggy they are. But then I’m coming to the conclusion that drag and grip are very much related.
NormalManFull MemberDraggy yes. In fact the ride home (often 4-6 miles of road depending on the route) with a headwind the other day was border line horrible.
BUT, the off road buts had been truly brilliant and more than made up for it. The grip up one particular short, steep and very rocky climb was great. No wandering or being bucked off line. Just traction.But everyone is different. I would suggest to hire one for a weekend if you can.
It won me over. But then mine is an old fashioned heavy one 😆
johnnystormFull MemberNobody likes Nates?! Apart from being a bit dragging I’ve heard nowt but praise for their winter gloop awesomeness.
Don’t get hung up thinking low pressures are a bad thing and suspension let’s you avoid it. I run mine at 5/6psi and they feel no worse than my oof did nearer 8/9 (as the rims lost the bead if I went lower). 10psi in a 4″+ tyre feels like 40psi in a 2″ tyre to me.
If I was after a trail fatty I’d be tempted by buying a Wednesday frameset for £450 and a Fatty trail in the sale as a donor. Apart from the rims/tyres I’m not sure much of the full build Wednesday spec is much to get excited about.
rOcKeTdOgFull MemberDraggy yes. In fact the ride home (often 4-6 miles of road depending on the route) with a headwind the other day was border line horrible.
S’wat pumps are for
NormalManFull Member@ RD
Who stops? 😉My dad would call it character building. He is 77 and still MTBing so who am I to argue 😆
coastkidFree MemberYou want trail geo and ride fast? why bother with 4 or 5″ fabikes?
Go get a 29+ bike like a Krampus or Trek Stache, Travers, Jones…
I own 4 regular fatbikes, been riding them 8 years now and seeing the 29+ come online and now riding 3 options (KramPug, Krampus, ECR) it offers the best option for speed and grip, can do 75% of riding where a Fatbike can away from the coast (if set up tubeless to allow low pressures without pinchflats) not as much public attention for some folks maybe but deft a beter option for most folks 😉
The topic ‘Fatbike with modern trail geometry’ is closed to new replies.
