My concern is why the second fast idle results were marginally worse than the first, as by the time you get to a second fast idle test, the engine should of been running at fast idle for a good few minutes. So even if it wasn’t that warm to begin with, things should be improving for the second test.
However, first thing would a good run to get things well warmed up, then straight in for a gas test.
As others have said, give it a decent run, with higher than normal revs, and the occasional push to near the red line in lower gears, to blow out any cobwebs and get the cat nicely warmed up.
A service with new plugs wouldn’t go a miss, but a decent run first is cheaper, provided there are no obvious faults like a misfire, or using more fuel than normal.
