Home Forums Bike Forum Eagle axs replacement cage?
Viewing 7 posts - 1 through 7 (of 7 total)
  • Eagle axs replacement cage?
  • appltn
    I’ve mangled mine (non t-type). I see that I can buy the inner but not the outer plate as a spare. I’ve found this https://ratiotechnology.com/product/sr52x-derailleur-cage/ but are there other alternatives? Maybe something a bit more oem looking?
    1
    doomanic
    I’ve got a Ratio cage because I couldn’t find any other alternative. Looks nice, didn’t fix my issue. Probably not the cage’s fault though.
    appltn
    What issue were you trying to fix out of interest?
    I’ve just spotted that Garbaruk have one too.
    https://www.garbaruk.com/rear-derailleur-cage-for-sram-11-12-speed.html?category=15
    Tracey
    I got a stick stuck in the cage of my XX1 AXS and it snapped the front part which SRAM didn’t have a replacement part. Fitted the Ratio cage and it’s still going strong. No problems with it.
    honourablegeorge
    +1 for Ratio.
    doomanic
    Even using microtone I can’t get the shifting as good as it was when new. I’ve fitted a new chain, chainring, cassette, UDH and the Ratio cage which hasn’t made any difference so I suspect it’s the mech itself at fault. It has taken a few knocks over the past 4K miles…
    IMG_0066
    teethgrinder
    Leap are doing 3D printed cages now, with ot without jockey wheels. The Ratio cage looks better.
    Sram AXS Derailleur Stealth Cage
