Home Forums Chat Forum Does this battery need changing?
Viewing 6 posts - 1 through 6 (of 6 total)
  • Does this battery need changing?
  • cb
    2015 macbook pro, battery lasts a couple of hours max now – used to be 8/9 hours. That suggests it needs a new one but is that backed up by the numbers below?
    Anyone know how much a new battery would be via offical channels?
    Charge Information:
    Charge Remaining (mAh): 4125
    Fully Charged: No
    Charging: No
    Full Charge Capacity (mAh): 4806
    Health Information:
    Cycle Count: 827
    Condition: Normal
    Battery Installed: Yes
    Amperage (mA): -1908
    Voltage (mV): 12021
    doris5000
    No idea. But my 2015 MBP (13inch) has a ‘Full Charge Capacity’ of 5775 mAh, which suggests yours is fairly well down on capacity.
    Mine has only done 407 cycles though.
    nickdavies
    My ‘11 air started to last a couple of hours between charges.. the health count etc didn’t look too bad so I ended up using it on power a lot more not bothering to change it. Iirc I was on 800 or so cycles. Eventually the battery swelled overnight and the next morning the MacBook was like a beach ball!
    Got an ‘apparently’ oem battery for it and fitted it, amazingly easy and the case just went back to shape and it holds about 4-5 hour charges now, not as good as original but it’s a decade old. So I’d say just change yours.
    TroutWrestler
    And be VERY CAREFUL with swollen batteries. Like, outside, NOW!
    seosamh77
    cb
    yes
    geuben
    My 2015 MBP battery 100% needs replacing:
    Model Information:
    Manufacturer: SMP
    Device Name: bq20z451
    Pack Lot Code: 0
    PCB Lot Code: 0
    Firmware Version: 702
    Hardware Revision: 1
    Cell Revision: 3244
    Charge Information:
    Charge Remaining (mAh): 3522
    Fully Charged: No
    Charging: No
    Full Charge Capacity (mAh): 5675
    Health Information:
    Cycle Count: 1157
    Condition: Service Recommended
    Amperage (mA): -1626
    Voltage (mV): 11156
    It often turns off at anything up to 90% if you ask it to do anything taxing on battery power.
The topic ‘Does this battery need changing?’ is closed to new replies.
