Home Forums Bike Forum DMR Bolt – what does the shock linkage actually do?
Viewing 28 posts - 1 through 28 (of 28 total)
  • DMR Bolt – what does the shock linkage actually do?
  • remoterob
    Fixed pivot, fixed connection of swingarm to shock. What does the rest do? Am I being really dense?
    shaggy
    Reduces side load on the shock.
    gravity-slave
    Keeps everything stiff and in line and prevents side loads on the shock.
    thepodge
    Yep, it’s just for stiffness
    stoffel
    Does it stiffen thongs up and prevent side loads on the shock?
    thejesmonddingo
    It hasn’t stiffened my thong 😆
    kayak23
    shaggy – Member
    I disagree. I’d say it reduces lateral load on the shock.
    gofasterstripes
    Actually, I have a related question – why is it in 2 pieces? Surely a single piece would do that al-la 575 etc
    There must be something going-on we can’t see in that pic.
    Or I am dense.
    batfink
    If it was a single piece the end of the shock would be trying to rotate in two opposing arcs at once….
    The seatstays would be pushing it in an arc flowing the BB pivot point, and a single piece linkage would be trying to get it to follow an arc around the top-tube mounted link pivot-point.
    The result – death, most likely.
    AlexSimon
    If it was one piece, you’d have a rigid triangle and it wouldn’t move.
    The gap between the top-tube pivot and the rear shock pivot needs to grow during compression
    Edit: Beaten to it.
    And a very heavy hardtail.
    gofasterstripes
    Makes sense, but how is this different to the 575 and why does that work?
    Sorry, no brekkie yet 😉
    iamroughrider
    why does the rear triangle pivot around the bb? Is it so you can run it single speed?
    AlexSimon
    That has a pivot near the rear dropout (or a flexi bit of frame on some models).
    Yes – it’s a bike-park/jump bike.
    thepodge
    It’s also a very fun short trail bike.
    There is one in the for sale forum right now which I’d love but don’t have the cash
    gofasterstripes
    Ah, I kennit.
    ajantom
    There us also the ‘long’ version – extended seat-tube and longer top-tube. Makes for a decent trail bike in that guise….
    cloudnine
    How does the bolt pedal?? Been looking at them for a while
    passtherizla
    With the right tune in the shock they pedal ok. One I rode had a x fusion piggy back type shock in it and the owner had it nicely set up. Worked really nicely.
    thepodge
    I’ve not had a bolt but I have owned another bb pivot frame. If you don’t mash the pedals then they work just fine, those wobble chainrings also help reduce bob too
    gofasterstripes
    Dear god you don’t mean Biopace do you?!
    thisisnotaspoon
    Naa, the new wobbly rings are 90deg further round compared to biopace, in theory new wobly rings are closer to a constant chain tension all the way round rather than all the power coming in 2 big lumps at 90 and 270deg past TDC, or thinking about it the otherway, the crank slows down at 90 and 270 so you’re pushing on it longer and it can skip past TDC and 180deg.
    The advantage on an FS bike is that the peaks in power output are what caused bob, flatten them out and bob is reduced.
    thepodge
    Yeah roughly speaking:
    biopace enhances your max output
    wobble rings enhance your min output
    thisisnotaspoon
    On the subject of Bolt’s, does anyone know the reach/stack measurments for the long one? The website just quotes 595mm actual top tube, which seems more like a horisontal top tube measurement.
    gofasterstripes
    Can I just say, we all answered the question wrong:
    Q:
    What does the shock linkage actually do?
    A: It moves about a bit.
    fervouredimage
    I’ve just ordered a long version which I will be building into a mini-downhill bike. I much prefer short travel bikes so it seemed the perfect frame for the job.
    thepodge
    I’ve not seen any r/s dims but I’d bet they’d tell you if you asked dmr direct, they seem like nice guys
    VanHalen
    i`d love one but they are HEAVY!
    ajantom
    Heavyish 😉
    I’ve now got gears on mine and it’s 32 lbs on my fishing scales. That’s with coil Pikes, a dropper post and heavy pair of wheels. So not too bad considering…..and it feels indestructible!
The topic ‘DMR Bolt – what does the shock linkage actually do?’ is closed to new replies.
