evening all..
doing the usual service on the wifes car, havent changed the fuel filter on hers before and notice it’s stlightly differnet to her older 1.4TDCI.
Basically the new one (1.6TDCI) doesnt have a fuel bulb primer thingy.
once the new filter is in place haynes manual (which is cr*p for this job) says “now you need to PRIME the fuel system using the ford pipe kit”
quick gander on a ford forum, got sent a link to a hand primer bulb and two bits of plastic pipe, saying stick one end of the pipe onto filter and the other into a plastic bottle to catch the fuel.
it’s the exact same engine in some peugeots the HDI but again that has a built in primer.
so question is
if i do the above (without sounding stupid)i’d conenct the other end of the pipe onto the outlet fuel filter pipe so it draws the fuel from the tank into the filter (filling it up) im guessing this will take hours of pumping!
a mate said just use a syringe and fill the filter to the brim, then it will start first time.
i was also told it should be a self priming engine, whereby a few turns of the ignition to turn the fuel pump should be enough, but no mention of this in the haynes.
cheers
