Home › Forums › Bike Forum › DIy 700 lumen batteries inside light
- This topic has 1,254 replies, 94 voices, and was last updated 12 years ago by stevemorg2.
Jammy111Free Member
ultrafire 3000mAh protected cells on ebay. I’ve no idea about the brand, but i’d presume they aren’t really 3000mAh as i think they are cheap foreign stuff. Still I got 4 for 12 quid posted so cant complain 🙂
smudgeFree MemberPersonally I only use high quality 2.6Ah Samsung Li-Ion cells, not cheap but you pay for what you get.
As for the 3Ah cells, chances are unless youre buying top quality cells they wont be 3Ah and if they are they will be pretty expensive, besides the cycle life will be pretty reduced as something has to give having that extra Ah inside for the same size can.BlackCatTechFree MemberIn essence, there are two types of driver / power supply. The old-fashioned linear supplies burn any excess voltage as heat. Switch-mode supplies like my driver are able to convert a higher voltage at low current to a low voltage at high current with minimal losses but at the expense of a more complex circuit.
With a linear driver the current out is the same as the current in. With a switch mode driver the power out is pretty much the same as the power in, taking some small losses in to account. To explain, two XPGs at 1A would represent about 6.6W of power (3.3V x 1A x 2) Using a 11.1V battery and a linear driver this would mean 11.1-6.6 = 4.5W of power would be dissipated as heat in the driver and in effect wasted. A switch-mode driver assuming 90% efficiency would use about 7.3W of power so at 11.1V this is about 660mA.
Increasing the battery voltage to 14.8V and the linear driver still draws 1A but now you are wasting 8.2W as heat. The switch-mode driver still draws 7.3W which is just under 500mA. (Current = Power / Voltage)
When you are talking single LEDs from single lithium cells then the issue of drivers gets a bit more complicated. The battery voltage is only just above the LED Vf so the wasted power in a linear driver is small, often making them as or even more efficient than a switch-mode driver, plus they are usually cheaper as they are simpler.
spacehopperFull Membermanaged to get my new driver fitted last night (cheers blackcattech :D)
and took the triple for a spin.. only down an unlit country road but pretty impressed with the output..!! seems slightly more light than my old 20Watt philips Masterline halogen light.. but with a much colder bluer colour..
slightly ‘spotty’ beam though and am thinking of using a different optic on the middle LED to give a bit more flood close to the bike.. (and keeping a regina either side to keep the spot)
what optic would anyone reccomend for this purpose?
its addictive this light building business! 😉
VanHalenFull Memberhttp://uk.farnell.com/ledil/ca10931-boom-w/ssc-p7-acriche-ref-tape-base-wide/dp/1817773?in_merch=New Products&MER=i-9b10-00001144
farnells do these – i guess might work to give more flood?
for a quid a pop its got to be worth a go?
spacehopperFull Membermight work… but they are designed around the P7 LED’s which i think are bigger in size than an XPG so it might not work…?
they have Reginas in stock at farnells in the UK ive just seen if anyone needs any..! Farnell link to Regina optics
gunna sort an order from cutter soon i think and get a few things to tinker with from there but the optic choice is a bit bewildering!
thesurfbusFree MemberI have used the Ultrafire 18650 3000mAH cells for a while now (in DX torches), and I don’t believe they are 3000mAH as my run times are no where near what I would expect. I haven’t timed the run time, but I got less than 2 hours last week with a combination of 2 and 4 XPG’s on full power. I am out tonight and have just charged the cells, so will see how long they last for.
When I finish building my 2x XPG and 2x 18650 batteries inside light, I will do a proper timed run.
BlackCatTechFree MemberDon’t know if they’ll fit inside the Hammond case but if you check out the Ledil range at Farnell they have some oval optics – I think the heidi one is 21.6mm diameter for example. I’m intending to test a combination of spot and oval to see if that gives a better beam.
If anyone wants any, let me know ASAP as I need to order from Farnell today but I’m off to Portsmouth at about 3 this afternoon so I need to get the order in before then!
BTW, I’m sure I pointed out that Farnell had Reginas about 20 pages back….
DoctorRadFree MemberTroutie: you have mail re ordering £28 batteries inside parts kit if you have any left.
thesurfbusFree MemberLast night I only got 1.5 hours on a combination of 2 and 4 XPGs, using 4x 18650 3000mAh. I will have to try and do a controlled test, I have a P7 torch that takes a single 18650, I normally get an hour out of it. Will run it with each cell to try and determine which ones are bad. Or does anyone know of a better test?
bigjimFull MemberYeah something wrong there surfbus, guess the best way to tell is to try each cell in your torch whilst you sit at work or something.
DoctorRadFree MemberYou have some payment Troutie 🙂
For anyone looking for external battery options, bags like this one: http://bit.ly/frJPGl fit batteries like these pretty well: http://bit.ly/ibeRpW
14.4v LiPo batteries will also overvolt your retro halogens very nicely 🙂
thesurfbusFree MemberDoctor Rad – Any idea what charger for those LIPO batteries?
DoctorRadFree Member@thesurfbus – I got one of these: http://bit.ly/eb35Xe which claims to charge pretty much anything: LiPo, LiIon, LiFe, NiMH, NiCd and good old Lead Acid. Will do balanced charging for LiPo stacks, and claims to do balanced discharging too, but I don’t think it does this correctly. Needs an external power supply, a laptop supply with the right plug works fine for me.
LiPo charging is a tricky business; get it wrong and you can cause a fire: http://bit.ly/epCGQL
Apparently it’s best to use a charger which will balance the cells, i.e. make sure each cell of the battery is charged to the same voltage. If you don’t do this, you can easily overcharge a cell, or over-discharge it when the battery is in use.
You also need to be careful not to over-discharge the whole battery pack. A 4-cell 14.8v pack should not be discharged lower than 12v, or 3v per cell. At this point, your LEDs or halogens would still be burning brightly! You can get battery monitors / alarms on eBay, or build your own if you can solder: http://bit.ly/hVuMYm (circuit diagram in 4th post).
One of the two 4-cell batteries I got (http://bit.ly/ibeRpW) apparently has two bad cells which won’t charge properly. May be able to revive them by discharging the other cells to the same level and then charging, but I’m not sure yet. Have asked if I can return the pack to Hong Kong for a replacement, will keep you posted on customer service quality.
Have a look round their eBay shop, they’ve some useful stuff and LOADS of different LiPo battery packs: http://stores.ebay.co.uk/GoMarketStore
greasyriderFree MemberHi Troutie, I’ve sorted payment and emailed you my address.
Did you recieve it?
pikerFree MemberHi troutie i sent you payment last friday,just wondering if the kits on its way,got BCT kit on tuesday and hammond box,cant wait to get started.
troutFree MemberGreasyrider
not sure depennds on what your real name is .Piker your stuffs in the postal system somewhere .
DoctorRadFree MemberRight then: drilling stuff.
I’m much better at the electrical side of things than the mechanical. Looking at the standard of CK’s drilling and tapping, I’m guessing he must be using a pillar drill?
I already have a tap and die set, but my concern is about drilling holes ‘straight’ into the metal, as presumably if the pilot hole is ‘off’ then the tapped hole will result in a wonky bolt? So, how to drill straight without a pillar drill?
Response from go_market about the wonky battery: they’re sending me a new one! Have asked if I need to send the duff one back (will actually work as a spare if not) but can’t say fairer than that… assuming it turns up!
VanHalenFull Memberi used mini nuts and bolts and gave myself enough ‘float’ with each hole to line things up.
otherwise you just have to centrepunch the bolt hole and be really careful. the ali is so soft do you really need to tap the holes? a self tapping screw will offer more leniency than a wonky tapped bolthole.
all my equipment is a bit shonky (bought for fixing classic VW`s not weeny accurate electrical work) and i dont have a vice either so i have to accept it wont be perfect (although my light doesnt look bodged!)
DoctorRadFree MemberJust a quickie for BCT: how well would your drivers cope with a sudden change in load? I’m thinking about having a second switch on the output to swap from two LEDs to one, either for power saving or so you could switch in and out a more floody optic on the switchable LED.
I guess a break-before-make switch would work best so there’s a break in connection when switching?
troutFree MemberDr Rad
No the leds or driver will not like the sudden switching of loads and while it may work once or twice
Bad things will happen.IE. Both leds are on so driver sending 6.6 volts to the leds. You suddenly switch one off
The other suddenly get all the six vots and becomes unhappyjoec1Free MemberNewb here, just read this thread front to back, after a post i read on MTBR guided me here…
Really interested in building this but have a few Q’s
Can you both (trout and BCT) confirm you have kits available? (not neccessarily in stock) but dont wanna buy one half if the other half isnt available. haha.
secondly, where do i send payment?
Thirdly… Thankyou. 🙂
BlackCatTechFree MemberTroutie, is this something you’ve actually tried? I’m not sure myself but I’d have thought it should be OK. The voltage is pretty much irrelevant, the driver stores charge in an inductor and discharges it through the LEDs. If you reduce the load suddenly then briefly the inductor will hold too much charge which would result in a slight current spike through the LED but as there is also a capacitor across the output this will absorb some of that spike until the driver has the chance to adjust itself. As XPGs can take 1.5A you may be fine.
Really, I’d want to set up a system to measure current in the loop and see what happens but you’d need a ‘scope to do this properly.
A few points I’d make though, you would be better reducing current rather than the number of LEDs to save power – LEDs are more efficient at lower currents so two LEDs at 350mA would give more light than one at 700mA.
If you did want to disable one LED or switch one LED for another what I’d do is to use a suitably rated switch to short across the LED in question. That would mean there is always a complete path rather than possibly having momentary open circuits which could cause problems. I’d still want to check this with a ‘scope though.
(BTW, Troutie, did you get my email from a few days back about drivers / XPGs? Or are VM playing their usual tricks again….)
BlackCatTechFree MemberYup, kits available still. Payment details are in the thread several times but it’s go a bit messy now! Paypal address is in my profile, kits are £8 each plus £1 P&P for as many as you like. (Although I’m down to my last few switches now)
joec1Free MemberBCT – Can you stick me down for two Kits, Payment Sent
Troutie – If you could get in touch and let me know i would appreciate it 😉
cheers
DoctorRadFree Member@trout – I thought this might be the case, but then if two LEDs were disconnected and one LED connected afterwards, presumably the driver would have time to sort itself out while there was no output load connected. What I need to know is how long the driver takes to sort itself out and if a break-before-make switch would give enough time.
@BCT – good point about efficiency, but at low speeds I might want e.g. to be able to switch out my more floody beam to save power.
I’ll get the double regina version rocking first and then look at refinements. I like the idea of a dynamo version too mind you, I think there’s scope for a single unit with two power sockets for either battery or dynamo drive.
BlackCatTechFree MemberDrRad – not that easy I’m afraid. Once the inductor has stored some charge the only way to discharge it is through the LEDs so you will always get that initial spike. What I don’t know without doing some measurements is how high that spike could be – as I say, hopefully the capacitor on the output will even it out. If you did do this then maybe connecting another capacitor on the output would help as well – the one fitted is only 1uF so maybe something in the range of 22-47uF may help but again I’d prefer to do the measurements first rather than guessing.
DoctorRadFree MemberFor those wanting spare end pieces for their Hammond boxes, Digikey can order them in for you: http://bit.ly/geKxOz (photos here: http://bit.ly/fKmxvJ )
troutFree MemberHi Joec1
Yes I have plenty of the kits available
mail is in my profile
Steven
not tried myself but going of what George from Taskled said when asked the same question as Dr Rad asked .
will have a trawl through the spam and see if your mail is there .
It seems like a few of you have not yet received your kits from the last batch I posted the PO sounds like they are struggling with a huge backlog of deliveries so I cant raise any missing mail queries just yet they say I need to wait till things settle down after the xmas rush.
bobblehatFree MemberHey Doc …. as BCT says far better to switch the power down on both LEDs using the driver control switch.
If you drill the holes in the case first and dry fit the L bracket, Leds, reginas and lexan to the case, you can then mark through the holes onto the L plate with a scribe or fine sharpie/pencil making sure everything is pushed up to the lexan. Disassemble everything, centre punch the 3 scribe/sharpie/pencil circles and drill the L plate. This ensures that even if you are slightly out of line with your case holes, the L plate holes should match!
As for alternative optics …. I’m contemplating experimenting with an optic swap for my dip beam.
Doc … you know you want to do it don’t you …… 😈
….. my test rig ………
….. twin lights ….. dip and main … or … wide and narrow ….. 😀
joec1Free MemberBrill troutie.
Can you confirm the cost per set? I will get payment across to you tonight (when I know what it is haha)
Cheers.
BlackCatTechFree MemberWill see if I get the chance to do some tinkering next week – bosses are using up their holiday allowance before the year end so I should be able to play a bit… Any peak will be for well under a millisecond so shouldn’t overly tax the LED and I’m fairly sure the capacitor will filter things out anyway, still best check before I start advising!
Not sure if any of the driver kits are held up but I’d be surprised if they aren’t. I have just received a weekly paper that comes on a Wednesday – dated 8th December. I’m waiting for some LEDs that I ordered from Germany over two weeks ago and in general I seem to be getting much less post than usual so I have a feeling things are going to be FUBARed until well in to the New Year…
troutFree MemberI have just posted out a batch of the latest folks stuff ordered
but dont hold your breath for christmas the post lady said .Steven you need now to be thinking about a max 3 amp driver .
with dimming and thermal protection .and you could be on to a winner in the new year .for the XM-L they are shipping soon
BlackCatTechFree MemberStill thinking about drivers to be honest. I’ve had feedback from elsewhere that sticking with the 25mm circular format would be preferable. I think I may end up with three drivers, 25mm circular ones rated at 1.5A in buck and boost formats and the 3A buck driver in a larger, rectangular format.
bobblehatFree MemberSnowed in ….. Very unusual for Merseyside ….. no Christmas shopping, no grocery shopping …. no bikey riding ….Bah! 😥
Hmmmm! Found a spare piece of hammond extrusion …. how about making a hood for the dip beam …. could give it a try ……
…. how about 2 from one piece!
One of them will match the dynamo light nicely ….. I could anodise the one for the twin lights …. all they need are longer screws and they fit the front perfectly.
But will they work ………. too much snow to find out! ……….. Patience! 👿
The topic ‘DIy 700 lumen batteries inside light’ is closed to new replies.
