Home Forums Bike Forum Dinged rim repair
Viewing 9 posts - 1 through 9 (of 9 total)
  • Dinged rim repair
  • IamSam
    Put a ding in my xt rear rim last night which means it now struggles to hold air. Has any one any advice on how I can fix this, will pliers and a cloth be ok? is there anything that I should definitely not do?
    thanks in advance.
    cynic-al
    Have had success with adj spanner.
    foxyrider
    also a mole wrench – but did that with mine and it split when I tried to bend it back – perhaps a hammer on a block of wood better? Otherwise put a nerw rim on – can you get replacement XT rims?
    D0NK
    Second the adjustable spanner. mole grips or pliers may crush or scuff up the rim wall, lever it back into shape with spanner. If your still having trouble holding air after its straight try some sealant (or have you already tried that?)
    IamSam
    seems like its the spanner then……………………………..god hope this works newish bike and can’t afford to replace anything yet. Damned lake district rocks 😀
    bent_udder
    Adjustable spanner for sure. And lots of patience – don’t go crazy.
    foxyrider
    thats the nature of the beast – especially if you were “NAILING” them 🙂
    coatesy
    With the adjustable spanner that i use, i’ve ground back the jaw that fits inside the rim so that the outer jaw sits lower than the rim edge and doesn’t dig in and cause cracks to start.Your local garage will probably do it for you if you haven’t got access to a grinder.
    IamSam
    Don’t know what you mean, confidence is a bit of a double edged sword i am finding
    Now thats good advice think that instead of a grinder I’ll use a piece of ali though
    Thanks muchness
The topic ‘Dinged rim repair’ is closed to new replies.
