Home Forums Chat Forum Digital SLR question
Viewing 40 posts - 201 through 240 (of 289 total)
  • Digital SLR question
  • simonfbarnes
    copyright thief 🙁
    donsimon
    But you just said you “don’t want to be pi55ing around with two buttons for every shot” – which means you have to fix one?
    Exactly, but I have the choice about which way I want to move, depending on exteranl factors like the light levels, or internal factors like my whims, and I get to choose which one I fix.
    GrahamS
    at the same level as choosing the contrast on your TV allows you to join hands with the director…
    **** me you really just don’t get it do you simon? 😆
    The contrast on my TV doesn’t alter the depth of field. It doesn’t introduce motion blur or freeze the action. It doesn’t make the scene lighter or darker. It doesn’t introduce noise.
    That’s the directors job!
    GrahamS
    So do I. I can switch it to shutter priority if I want. 😀
    Personally I just can’t be arsed doing the mental maths to work out exposures.
    Presumably you have to go “Right I’m at f/11 for 1/30s. That exposure is spot on, but I want a shallower depth of field. So stop down the aperture to f/4, that’s three stops, so then I need to decrease the shutter speed to… 30 x 2 x 2 x 2… rounded.. 1/250s”
    Whereas in Aperture priority I would just stop down the aperture and the camera does the maths to give me the 1/250s shutter for the same exposure. That feels simpler to me.
    molgrips
    maybe from the above scenario I decide the pictures have too much blur and I want a faster shutter speed, I only need one control.
    Yes but in that situation your picture will get darker if you only operate one control, so you’d need to operate two to keep the same exposure. In S mode you’d only have to operate one.
    Next purchase, hopefully will be an EOS5d MkII with non of this auto rubbish.
    Not quite sure I follow what you are talking about. Your current camera and that one have full auto, full manual and all points in between. You are free to choose which one you want.
    I am suggesting that in the scenario described, S mode would be a simpler option since you could adjust the shutter speed as you wish without having to adjust the aperture as well to maintain exposure.
    donsimon
    More a case of “f/11 for 1/30sec is spot on….
    … and now the suns gone in, let’s go f/8 or,
    … this guys coming slower, let’s go 1/50sec, or,
    … this guys wearing a really light shirt, let’s go f/13, or,
    With the photography I do, I’m unlikely to get a perfect exposure. I’m looking for something else. Why are you trying to convice me that the way I find comfortale is somehow not good?
    simonfbarnes – Member
    copyright thief
    Who?
    TijuanaTaxi
    Set the aperture you want, quick butchers at the RGB histogram, get the furthest peak on the right nearly clipping by adjusting the shutter speed and hey presto spot on exposure
    molgrips
    More to the point, why do you THINK I’m trying to convince you of anything?!
    If you’re an experienced camera user, then fine. You sounded somewhat unsure of things however, so I was trying to illustrate what S and A modes could do for you if you weren’t aware, which you may have found useful.
    Bloody internet… everyone thinks everyone else is trying to force them to do something or other 🙂
    donsimon
    Not necessarily you, and I was playing earlier. 😉
    Why do people have to take thinks so personally on the internet. 🙄 oh yes, and… 😉
    molgrips
    I thought the idea was to get most of it in the middle?
    GrahamS
    I’m not I’m just countering your argument that using a priority mode would restrict creativity. Its just a different way of controlling the same thing.
    Unless, y’know, you don’t just want an exposure that fills the histogram. Maybe you want to clips some highlights or drop some blacks.
    molgrips
    Yeah but he said that clipping the right most peak meant ‘spot on’ exposure.. I’m still not understanding the implications of historgrams very well.
    donsimon
    My reaction is that there are too many variables, both internal and external, and that fixing one point must restrict movement and creativity, or they wouldn’t put so many options on the camera in the first place. All IMHO.
    molgrips
    Yes.. you only select the option to fix that if that’s what you want. After all, you want a photo that is exposed enough to see. So that’s a constraint right there.
    It’s just a convenience that’s all. So if the sun comes out and you decide you want to do a high speed shot of a fast rider with bits of gravel flying up in the air, you can just whack the exposure from 1/30 to 1/800 and snap – the camera will make sure the pic is still visible.
    Just saying that S mode can be useful that’s all.
    PeterPoddy
    Me neither. But handily, on the screen it tells me if I’m over or under exposing and I can adjust until the exposure is how I like it, or select Tv or Av modes, then tell it to over or under expose by a certain amount leaving me free to concentrate on shutter speed or DoF as I choose.
    I know very little about the technical side of photography, but I know what I like and I like learning how to achieve it 🙂
    GrahamS
    Left is dark/black, right is bright/white (or vice versa on some systems)
    The height is the amount of the image which is that brightness.
    The dark and bright are absolute limits.
    A big peak squashed up against the dark edge means lots of your image is completely black with no detail in it.
    A big peak squashed up against the bright edge means lots of your image is completely white, “blown highlights” with no detail in it.
    Tijuana Taxi’s approach means your exposure is as bright as it can be without any (significant) blown highlights.
    Read: http://www.luminous-landscape.com/tutorials/understanding-series/understanding-histograms.shtml
    GrahamS
    ..or select Tv or Av modes, then tell it to over or under expose by a certain amount leaving me free to concentrate on shutter speed or DoF as I choose.
    Which is exactly what I was proposing. 🙂
    molgrips
    That’s what I thought.. but that’s going to lead to bright pictures. Which you may not want! Getting most of it in the middle means a neutral exposure doesn’t it?
    donsimon
    So you make that change from rider 1 to rider 2, rider 2 is wearing a white shirt, rider 3 comes along wearing a black shirt or the sun disappears again. You still want 1/800sec, what do you do? I’m more concerned about the rider than the background. For me I find it a lot simpler to use manual 100% for action shots and auto for the podiums because I can’t be ar5ed… 😆
    molgrips
    Are you trying to say that one mode is better than another?
    If you are in S mode, you don’t have to do anything. The camera will still expose correctly.
    That’s what spot metering is for.
    PeterPoddy
    Carry on at f5.6, & 1/125 becasue I’m using a remote strobe, actually…..
    8)
    (Or if I do need a bit more exposure, I’ll knock it back to 1/100th maybe)
    GrahamS
    Or conversely it means most of your image is average grey and uninteresting 😀
    Basically there is no ultimately “correct exposure” there is only the exposure that matches what you want.
    GrahamS
    I wouldn’t do anything for the sun disappearing, because presumably I am in S mode so the camera will open up the aperture itself to compensate (and some can even be set to increase the ISO if you don’t have enough aperture available).
    For the black shirt, well if I wanted him to be brighter than the last guy then I’d just add a stop to the exposure compensation.
    MrSmith
    no it isn’t. it’s the job of the DOP to do this and whoever does the grading in post production.
    TijuanaTaxi
    I use the RGB histogram which I find far better for accurate exposure than the light/dark one.
    Just get the one of the three peaks that is closest to the right nearly touching seems to work for me
    Also a good idea to set the shutter speeds in smaller increments than whole stops for finer adjustment
    Bearing in mind most of my shots are landscapes hence setting the aperture to one of my choice
    simonfbarnes
    I think we may be homing in on a harmonious conclusion as I realise a lot of the argument is over teminology. I don’t think of the camera controls as creative but functional – the creativity (if any) is in the mind of the snapper as they decide the framing, focus and areas of interest.
    Of course I’m always fritzing with the ASA and relative EV to get the best compromise between subject movement, rendering quality, camera shake, backlighting, shadow detail etc etc, but as I do it I’m not thinking “Oooh, look at me being creative!”, but “Grrrr! Now the stupid camera needs me to do this :(“.
    It so happens the Program mode seems to make a reasonable job of the kind of shutter and aperture compromises I like, biased towards overall sharpness, so I’m happy to leave it in that, but there’s one other vital factor left out of the mix, which is my inability to remember what I’ve set, so I end up shooting landscapes at 1000 ASA after action, or action at 200 ASA, or getting lots of overexposed shots after I wind up the EV for riders against the sky. It doesn’t matter that it’s all displayed round the edge of the viewfinder, as I’ve never consciously seen any of that stuff while shooting, as my concentration is on the subject out there in the world – perhaps due to using SLRs for 25 years before there was any of that clutter.
    And that’s why I want a real viewfinder that lets me feel like I’m looking directly at the subject, not a little screen in my hand!
    GrahamS
    😆 yeah okay, but it is part of the creative process and the overall creative direction and “look” of the programme, no? (don’t encourage sfb ffs!)
    PeterPoddy
    Nahh, that’s what a remote stobe is for. 😉 Expose for the background, then use just enough extra light, placed exacly where you need it, to light the rider up and freeze (most but not all of, in my case) the action
    I’ve got one more addition to make to my kit before I’m happy with shots like this:
    [/url]
    IMG_8520[/url] by PeterPoddy[/url], on Flickr
    Have a guess what it is… 🙂
    (Oddly, my local photography shop doesn’t stock them either!)
    I think Elfin will guess, becasue he thinks like I do…..
    donsimon
    So you do actually agree that priority setting are restricting and for full creativity you need to step outside an automatic setting. 😉
    McHamish
    If you can use manual on the fly then do so, you’ll have greater control over the image rather than relying on the camera to figure it out for you,
    If you can’t (or don’t want to) use manual, then use aperture or shutter priority, there’s no shame in it, and you’ll be doing what many pros do.
    If you’re interested in taking photography seriously avoid using the auto settings…start off with the aperture and shutter settings, and then play around with manual when you’re comfortable.
    GrahamS
    Have a guess what it is..
    Better looking subjects?
    A right fork leg?
    donsimon
    Women? Naked women? Women with their norks out? Is it women????
    PeterPoddy
    They sound like SFB answers! 😉
    GrahamS
    Nope, I just use priority + exposure compensation, where you use aperture + speed.
    I don’t think by using the compensation I am stepping “outside the automatic setting”. I’m just using the controls available. (and I don’t really consider priority modes to be automatic either.)
    Remember though, I am a rank amateur. I don’t do nearly enough photography to be able to guesstimate exposures on the fly in the way you describe. I simply don’t have that experience. So I let the camera handle that part whilst I still maintain the control I need over the exposure.
    PeterPoddy
    Tell you what, some of that set are better then I remember. It’s nice to look back at them again…
    [/url]
    IMG_8412[/url] by PeterPoddy[/url], on Flickr
    simonfbarnes
    FYI I am not the only man to appreciate totty 🙂
    I’m not sure why one would want to unless frequently operating under heavily controlled lighting conditions, particularly when sophisticated light metering is on hand 🙂
    Elfinsafety
    From the two pictures from Elfin, the TT picture has too much movement for my tastes, I’d like to see at least a small area being clearly defined, the eyes or face for example.
    It’s interesting, reading different people’s opinions about that pic. I was going for a pretty abstract sort of feel, evocative of the blur of movement as a rider speeds past. Not really trying to include any significant detail, but just enough to show what’s actually happening. Like I said, I’m not particularly satisfied with it. Happy that someone likes it though.
    The track photo is quite beautiful, not just as an image, but also it is a quite difficult image to take from a technical point of view. How many pictures were rejected from that shoot????
    Why, thank you! 🙂 I was pleased with it. Was fairly difficult, as the riders were doing 30mph+; and the 24mm exaggerates perspective. The riders were going past me in a split second, so only had a tiny window of opportunity to get the right shot. Only took about half a dozen shots from that angle; most came out ok but that was the best.
    there’s something awry there either in exposure developing or printing.
    it looks muddy so maybe under exposed and there is an area of overexposure running along the top of the frame so either lack of agitation when in the tank or a reflection off the baseboard mask when printing. it certainly doesn’t look like everything was 100% spot on in the process from exposure to print.
    Ooh, picky! 😉
    it’s an outdoor track, so the lighting isn’t the same as indoor ones. I think the exposure’s bang on for the rider, tbh. So, I’d disagree with you on that one. Processing is fine too. The scan is just how it was off the film, so maybe a little tweaking in Photoshop with Curves, but I’m happy with how it is.
    It’s meant to serve as an illustration of how to capture fast action with fully manual control and no motordrive. I think it does that job quite well.
    You’re more than welcome to print me a ‘perfect’ copy, though. 🙂
    joemarshall
    I think it’s stupid to argue that manual is more or less creative. Quite a lot of pictures, they’d be impossible or hard to create using full auto. But also, there are tons of pictures out there that rely on quick picture taking, no thinking about settings, and just pressing the button at the right moment. In the past I bet people taking those pictures just set some rough settings and crossed their fingers that any problems could be fixed in the darkroom, whereas nowadays the camera at least adjusts for conditions.
    When it comes down to it auto modes are just another useful tool for getting pictures, no reason not to use them for ninety percent of pictures (where you’re not doing special effects with blurring or depth of field, or shooting fast action in poor light). It doesn’t make you less creative if you get a picture using them.
    Elfinsafety
    Sure, but relying on auto alone is bit limiting.
    I dunno. I learned using manual-only cams, and never had a problem with only using manual, even in tricky conditions.
    In fact what I’d really love, is a digital FM2. Full frame 35mm sensor, proper tough-as-bastards metal body, no fripperies such as built-in flash, ‘sports’ and ‘portrait’ modes etc, silly built-in shitty digital effects and all that bollocks.
    And not costing £1700….
    GrahamS
    I never use the scene modes myself but they do mean I can hand the camera to someone else to get a picture of me without needing to give them a 20 minute lesson.
    They are not hard to ignore though, so I’m not sure what the benefit would be in mssing them out?
The topic ‘Digital SLR question’ is closed to new replies.
