Home Forums Chat Forum Digital Aerial Installation – Cost
Viewing 12 posts - 1 through 12 (of 12 total)
  • Digital Aerial Installation – Cost
  • younggeoff
    Just moved home and getting broadband and TV installed but only have an old analogue aerial.
    So do we need a digital aerial installed and if so what’s the going price for a single and multiroom setup
    properbikeco
    no such thing as a digital aerial – just an aerial which is the correct band for your chosen nearby transmitter.
    a decent local installer should cost ~£100 but they really need to see the job to give you a more accurate quote
    ton
    £95+ vat for a aerial to 1 point.
    £65 per point thereafter. in Leeds
    nickjb
    Plug the TV in and see if it works, check signal strength. An old “analogue” aerial will most likely be fine.
    About £40 from Argos and dead easy to fit yourself.
    younggeoff
    thanks for the quick responses guys
    I’ve already tried the existing aerial and it pick sup nowt 🙁
    nickjb
    Weird to get nothing at all. Probably a dodgy connection but it could just be a really weak signal on an old aerial.
    ton
    younggeoff…..if you decide to do it yourself, give me a shout.
    I sell all you need.
    rossburton
    We got charged 165 inc VAT to wire up an aerial to our old house but in fairness they did need a rather long ladder…
    Cougar
    When you “tried the existing aerial”, did you retune the set?
    senorj
    £125 in north London two years ago & £95 in Cumbria 5 years ago.
    Could have done it myself but Rod Hull and all that….
    younggeoff
    thanks for all the info guys, all sorted now and cost nothing 🙂
The topic ‘Digital Aerial Installation – Cost’ is closed to new replies.
