Home Forums Chat Forum Christmas Airfix!
Viewing 40 posts - 841 through 880 (of 2,392 total)
  • Christmas Airfix!
  • spursn17
    To flat spot my tyres I stand the finished model on sand paper and gently “brum” it like a kid with a toy car. I don’t make any noises though
    Try the iron method, it bulges the sidewalls out a bit to give the impression of weight. Practice on an old wheel first as it’s easy to overdo it.
    Rockhopper
    Airfix 1/72 Royal Navy Phantom FG1. A bit disappointing for a new tool kit – I didn’t attempt to correct the various errors they made either.
    Harry_the_Spider
    Nice. It “has” to be 007 and Omega.
    Did you put all of the stencils on? The decal sheet has really put me off buying one.
    Rockhopper
    I didn’t do all of them! Just some on the underside but most of the ones on the top and sides Black writing on a dark grey aircraft doesn’t show up too well so i left most of that type off. They are good decals to be fair and the bigger ones went down beautifully after liberal coatings of Tamiya MarkFit Strong.
    Harry_the_Spider
    I’m going to put the FGR2 on my Christmas List.
    https://www.airfix.com/uk-en/mcdonnell-douglas-fgr2-phantom-1-72.html
    nickc
    The fit of the intakes and the front canopy on that Phantom look shocking!
    Rockhopper
    Yep. There was no way the front canopy was going on any better, the fuselage is considerably wider than the glass. I could have filled the intakes but they are in such a prominent position i thought I’d leave well alone and just live with it.
    Harry_the_Spider
    Now you see ’em…
    Now you don’t.
    Harry_the_Spider
    One week and a lot of filler later…
    It is starting to look like a Victor, but there is a way to go yet and I’ve run out of primer.
    To give an idea of the size of this thing the tail is bigger than my Hawk “Test Pig”.
    nostrils
    Any update on the Victor? Where are you going to display it once done, its huge!
    Harry_the_Spider
    I’ve done a bit more filling and sanding bit I’ve run out of primer.
    I have no idea where I will put it or it’s twin. They are chuffing massive.
    PJM1974
    Am rather pleased – for my birthday I received a 1/48 Revell FGR 2 which will sit nicely with my two Airfix EE Lightnings and Hasegawa F104. I just need to find the time to build them.
    Harry_the_Spider
    Progress.
    Victor
    In other news, Cold War, Hot Jets is back on the iPlayer.
    Riksbar
    I’ve just got this RAF 1980s films DVD from amazon for a Cold War jets fix.
    nostrils
    How much better is a dedicated re-scribing tool compared to a scalpel blade? Struggling with some panel lines at the moment with the scalpel blade wandering. Can figure out how a scribing tool would prevent this?
    PJM1974
    My FGR2 is coming along slowly due to work/cycling/drinking/wife commitments, but the kit’s engineering is generally very good – aside from the fit around the intakes and the lower fuselage/wing assembly interface that naturally follows a number of compound curves and will be an absolute pain to fill.
    The plan is to paint it in XV408 circa 1991 colours – a fetching shade of blue which will be carefully post shaded.
    The Phantom’s intakes are very complex in shape, which means that masking them is proving to be frustrating – the blue overlaps the inside of the intakes slightly but it’s difficult to get a consistent masked edge, plus one needs to be careful with two contrasting colours (dark blue and white on the intakes inside) which could bleed.
    The auxiliary air vents on the underside have required some careful sanding to reduce their thickness – because the inside of the vents are a contrasting red against the blue, this will be tricky to get right.
    @HTS – am genuinely very impressed by your bravery tackling that Victor (I had that Matchbox kit when I was a child), not to mention the work you’ve done on the intakes. You absolutely cannot have a Victor tanker without a Lightning nearby, I’m delighted that you’ve got that covered.
    @Nostrils
    – I bloody hate scribing. It’s a PITA and never looks right when I do it! FWIW, I do have a scribing tool which helps, but the best approach is to polish the plastic to a sheen before you rescribe. A rough finish will deflect whatever scribing tool you use resulting in uneven engraved lines.
    spursn17
    If you’re using a Swan Morton scalpel you can make a scribing tool. Snap the tip off the blade with a pair of pliers, you only need to take off 1-2mm and it’ll leave a tiny sharp square edge. Turn the scalpel upside down and drag the tip backwards along the plastic. I’ve never tried it but I imagine a photoetch folding tool would be good for snapping the tip?
    Just wear some goggles when you’re snapping it though, sometimes bits of scalpel blade go flying about!
    Harry_the_Spider
    I’ve read that you can stick Dymo Tape down and scribe against it to make a straight edge.
    Progress on the Victor is slow, but I’m getting there.
    spursn17
    I use this, I don’t stick it, I just hold it on. You can also use a bit of the frame (sprue?) That photoetch parts come on.
    nostrils
    Thanks guys, hadn’t considered “masking” either side of the panel line to be scribed. Re the snapped off blade, is a square profile better than a bevelled profile for scribing? I suppose you aren’t really cutting the plastic when scribing…
    spursn17
    Square is better as it cuts a ‘trench’ in the plastic, a bevelled blade will score a line but it’ll create two minute ridges on either side where the plastic gets pushed over and up.
    Harry_the_Spider
    Finally got permission to put some on display. Not ideal, but better than in boxes under the bed.
    Meanwhile, the work in progress Victor looks on menacingly from its lofty perch.
    nostrils
    Nice! Whose kit is that Corsair? Today I managed to snag the Revell 1/72 Corsair from the local stationers for £7. Looks a nice kit.
    Any more progress on the Victor?
    Harry_the_Spider
    It is an Italeri. Cost about the same as yours. Got it on line from Jadlam.
    Victor is coming on. The hemp is about finished, which is good because it has played havoc with the airbrush. Stuck a load of aerials on it. Done some work on the engine exhausts but they still need more attention. Looking forward to finishing the bugger if I have to be honest.
    nostrils
    Don’t lose heart, you’ve got another to build after!
    Harry_the_Spider
    Not just yet. Something out of the box that I can rattle off in a fortnight first.
    PJM1974
    A lot of that will depend upon surface prep. I’m rubbish at rescribing either with a scalpel or with an engraving tool. I’ve tried the Dymo tape thing, but the stuff I have isn’t thick enough to deflect a blade. My technique is clearly wrong. What works best for me is to sand and polish the plastic to a fine sheen and then rescribe. There’s fewer flaws in the surface finish to deflect the cutting edge.
    Harry_the_Spider
    Need a break from the Victor as it is all fettling and no actual building, so I’ve started an Italeri F15E Strike Eagle.
    Cockpit had next to no detail so I’ve jazzed it up a bit with some cut out photo copies of the Victor cockpit decals and added masking tape seat belts.
    Will pick up the Victor again when the F15E is at the painting stage and do them in tandem.
    The black paint on the cockpit fairings will get another coat, especially where I’ve got excess PVA from attaching my home-brew HUD.
    Fit is a bit “Italeri”, but the kit was only a tenner so I’m not too upset.
    The Strike Eagle is similar to the Victor K2 in that evolved from a sleek and beautiful aircraft into something covered in lumps and bumps. It looks very “business like”.
    https://en.wikipedia.org/wiki/McDonnell_Douglas_F-15E_Strike_Eagle
    BaronVonP7
    I’ve just found the Titanic!
    It was at the back of a cupboard.
    Revell 1:400 scale, as far as I can tell it’s untouched and looks like it’s got all the parts; comes with 4 unopened pots of paint and a pot of glue.
    Free to anyone who can pick it up – Stafford or can meet at Cannock Chase, Birches Valley.
    PM me.
    Harry_the_Spider
    Free Stuff! Someone needs to jump in and have it.
    The Revell Titanic is one big brute of a kit.
    Sadly I don’t do ships, don’t live in Stafford and have too many kits.
    spursn17
    I’ve got a bit further with the P51! I lost interest in it for a while when I messed up the paint, but after being confined to home with two broken ribs all I could manage to do was watch TV and do some modelling. It’s almost done now, just needs weathering and some final assembly. I was pleased with the way the guns and drop tank plumbing turned out.
    Harry_the_Spider
    What scale is it?
    My F15-E Filler Ball Strike Eagle is getting there. Slowly.
    spursn17
    Hasegawa 1/48 scale
    Harry_the_Spider
    Italeri 1/72
    spursn17
    Italeri 1/72
    I’ve not made a 1/72 kit for about 20 years (Airfix WWI Albatross), I’ve got a couple in the kit stash so I might try one soon if my eyes can take it.
    Harry_the_Spider
    I’d love to go to 1:48 but i haven’t got the space.
    Harry_the_Spider
    £15ish delivered from Japan.
    I suspect that I could be spending a fair bit with these guys as kits start at about a fiver and delivery is about £6.
    https://www.plazajapan.com/categories/Plastic-Model/Hasegawa/Aircraft/?sort=priceasc&page=2
    JonEdwards
    So here’s a couple from me.Taken a while to get here – had major issues with the Martlet when the primer (Stynlrez) absolutely didn’t stick to the plastic and had to be peeled off to start again.
    The Mustang is from the Aldi special deal, which came with the wrong decals. First attempt at a full NMF finish, and a play with pastels for the weathering.
    (also different phothosting, so lets see what happens…!)
    Harry_the_Spider
    Nothing so far.
