Home Forums Bike Forum Cheap wins to make my bike lighter…
Viewing 40 posts - 41 through 80 (of 84 total)
  • Cheap wins to make my bike lighter…
  • nikk
    What is the weight saving going from Shimano SLX triple ring cranks to Shimano XT triple ring cranks?
    1×9 or 1×10 will take off about 430 grams in my experence, but you’ll put on some with a chain device / bash / jump stop, but it is still an almost free upgrade. Worth it IMHO, loose the front derailleur, much nicer.
    Other than that, ride the bike till something breaks, then replace it with a lighter bit. Either that, or buy a new bike…
    gingerss
    Swap the frame for a carbon 456, and maybe singlespeed it. Some carbon forks would save a load of weight but might not be a good match for the bike.
    My own personal answer to myself when this question arises is lose more weight and get fitter. This still carries even though I’m not overweight and I’m reasonably fit.
    njee20
    Pro 2 Evo SP crests are cheaper and stronger but about 150g? heavier.
    I’d not have thought so, my standard Pro 2s (not SP) on Crests were 1585g, even the SP-XC6s aren’t particularly light.
    Personally I’d not bother with any of the Pro 3 wheelsets, they’re a fair bit more expensive than the Pro 2s, and still not particularly light.
    Gotta love singletrack:
    – “I’d like to make my 5″ travel XC FS bike lighter”
    – “buy a rigid carbon SS”
    br
    You’ll save a bundle of weight by fitting a set of Rebas or similar, they don’t necessarily have to be brand new
    But may not…, the 120mm Recon’s (327 Solo Air) I got for my son weighed 1700g with a cut steerer.
    large418
    Weigh everything before you start spending as otherwise you risk wasting your money. I bought some cheapy ebay scales that weigh 0-2000grams – as all the weighing you’re doing is relative, rather than absolute, accuracy is not that important (although mine seem to pretty close to actual weights)
    Then, work out what gives the best £/lb and go from there.
    I have, over the past year, spent a lot of time taking my Stumpjumper hardtail down from 24 lb to about 21 ish, and mostly through 2nd hand stuff:
    MT Zoom bars, KCNC stem (new) – £100
    DT Swiss forks (only saved 100g, but have lockout and only cost £150)
    Roval control SL wheels – £250
    XT Brakes – £75
    KCNC Foam grips – £10
    KCNC seatpost clamp – £10
    Ti bolts – only done a few so far, but once all are done, will save 50-60grams!!
    Next on the list – XTR cranks (2nd hand only), XTR pedals, Woodman seatpost (170g), XTR cassette (2nd hand), Rocket Ron tyres.
    I started on the big saves first, then am working through the smaller but cheap saves ( like a seatpost clamp – only saved 40grams, but only cost £10 or so). Foam grips save 70grams, but only cost £10. Removing shifter windows saves 25grams, but is free. The weight is in the details, but you need to be meticulous.
    Good luck with it – and try to get out before it gets addictive!
    gingerss
    @njee, he said he wanted to make the bike lighter. No other criteria given. 😉
    njee20
    People obsess over things like that, but it’s far more sensible to do what you can with alu (mechs, shifters, brake levers, bottle cages). You’ll save more weight and it’ll cost pence. Look at little bits too like the Mt Zoom integrated top cap and bolt, costs a few quid and saves 10g or so.
    Good pedals as they are, XTR aren’t light. Woodman do a lighter seatpost than that too, think it’s the EL, same as a New Ultimate, really nice seatposts.
    If you’re looking for a lightweight cassette look at XX, a lot lighter than XTR. Not sure about second hand cassettes though, I’d have a new XT over a used XTR!
    davidtaylforth
    Your bike is fine. Theres no point trying to save weight on a budget, its only really worth doing if you have the cash to do it properly. Lose some weight off your body, that’ll make you faster than saving a few hundred grams on bike components.
    wallace1492
    Fill the tubes with helium. Seal the frame and fill with helium. light as a feather.
    chiefgrooveguru
    I’ve noticed my bike feels very light with the wheels, cranks and chain off, as it’s currently inverted in my kitchen.
    njee20
    Pretty sound advice that to be honest!
    mboy
    If you read the OP’s 2nd post, he states he’s already lost 6 stone and can’t really lose any more. Usually I’d say your point is very valid, but in this case it sounds like the OP has already gone as far as he can trimming himself down. Given that, I don’t think it’s unreasonable to want to save a couple of pounds off his bike now too.
    davidtaylforth
    Lol, although slightly heavier than most I can’t save much more weight from me.
    Slightly heavier than most?
    mr_mills
    Spokes weigh a tonne, so remove a few. Start with 12 from each wheel.
    br
    There is always a point to saving weight on both you and the bike, either and/or both will make it easier to get up hills.
    And good components can always be moved onto a new frame.
    swompy
    going back to one of the earlier questions,’ What is the weight saving going from Shimano SLX triple ring cranks to Shimano XT triple ring cranks?’ , I think its about 40 grams, aproximately a packet of crisps
    dee66
    I’m about 70Kg kitted up for a ride and the bike adds another 11Kg. To lug 1% less weight up hills I’d need to shed 810g from the bike. Not a cheap thing to do and I wonder how much I’d notice it. Can’t say that when I’m stopping for a coffee and I take a lock with me I’m suddenly struggling.
    If your a competitive racer then go for it but your bike says your not.
    And yes I do weight stuff and spend silly money shaving a few grams but I question my sanity in doing so. 😀
    grtdkad
    +1 for a few bits from KCNC…
    KCNC Scandium Wing Stem 90g for about £60
    KCNC Scandium Bone bar 115g for £45
    KCNC grips are about £10 and only 20g !
    and a nice new saddle – how about a Selle Italia Fibra SLR … Comfy(ish) and 135g
    Start weighing stuff but recognise it is a slippery slope!
    Superficial
    No one wants a heavy bike though. If there are a few simple things you can do to save a few grams and make your bike feel more special then I say fair enough. The only problem is the unfortunate law of diminishing returns for your dollah – and if you’re sacrificing function for weight then it’s time to take a long hard look.
    My new favourite component is a Flite SLR seat I bought in the classifieds from here. £15 and it’s half the weight of my old seat (SDG Bel Air) and just as comfy.
    HermanShake
    2×10, lighter stem, ti skewers, lighter tyres. Then methodically swap out the steel bolts for ti.
    Or sell your frame and get a carbon whippet.
    Superficial
    How much weight can you save with ti bolts? I’d imagine it’s not a good $/weight saving investment?
    radoggair
    what about your brake rotors. Could save 100grams each rotor by going ashima, kcnc etc for £15 each.
    cables. Are your cables right length, weight savings in there as well
    21lbs is a good weight for a bike, there’s no noticeable difference between that and say a 19.5/20lb bike
    bigrich
    buy a turbo trainer and do one of those sufferfest interval vids.
    Pawsy_Bear
    Think you will have to throw a lot of money at the bike to make it any lighter. Buy sometghing like a Zesty 714 – 914 and you wil have about as light a bike as you can get. As said above turbo and gym get fitter not too loose weight but get stronger. The bike isnt holding you back for example I run tubeless 2.4 HRII up front and HR2.35 on the back for winter. Large tyres maybe but I can power them and I can use the traction.
    stevewhyte
    Only 2 things stand out but niether cheap.
    SIDs would save you close to 500g and could be picked up second hand £200-£300
    And new wheels should be abe to save you 300g no problem.
    Tubless wont really save much.
    Other than that dont bother
    tomaso
    If your Recons have a steel steerer then pretty much any similar fork with an alloy steerer will be a chunk lighter.
    Have a look at weight weenies website for pointers on weight saving – but carbon bars stem and seat post never hurts.
    Although the cheapest way to make your bike feel light is to ride it with 2.7 inch dual ply tyres in a soft compound and then swap back to the nobby nics and it’ll feel like lightning.
    thisisnotaspoon
    Could be worse, my Pitch is ~34lb, and there’s nothing on it that ‘needs’ replaceing, 34lb and I’m already att he marginal gains stage!
    Current plan;
    Ritchey foam grips (tried them before hated them, got them on the Swift and they’re ace, not sure whats changed).
    Aries disk rotors.
    1×10
    Saddle, possibly charge spoon Ti, or possibly some lighterweight cast off from my road bikes.
    XTR chainset off the singlespeed to replace the current XT.
    Magnesium (or at least sensibly light alumnium) pedals
    New stem (Easton Vice is stiff but hevy, OEM spesh is light but flexy)
    And I realy need to work on making it a little more colour co-ordinated rather than the current mishh mash of old kit!
    T666DOM
    A saddle is a luxury you can ill afford, stand up all the time and you can ditch the saddle, seatpost and collar, plus with no saddle you won’t need a liner in your shorts…win win win
    Milkie
    Everyone wants a light bike… I don’t know why, and I’ve spent loads making my bike better/lighter.
    Save the money and go on a skills course with Jedi, best money you will ever spend. 😉
    njee20
    Not a lot, as I said previously it makes more sense to replace what you can with alu, rather than everything with ti! It should be a proper ‘last resort’ for weight saving!
    mogrim
    Not necessarily true: the massive thighs the OP would develop would surely limit the possible gains, everyone knows muscle weighs more.
    flange
    There’s some rubbish spoken on this forum
    Don’t bother with 1×9 unless very fit, or living in the Fens.
    I did W2 yesterday on 1×9 (32t ring) on a 30lb Orange 5, in the snow, slop and muck. It was fine.
    You’ll need a chain device but an E13 XCX will do the job and be much lighter than the front mech with all its gubbins. Or just wind the adjuster screws out on the front mech. See if it works for you by using only the middle ring for the next few rides. If its ok, get shut of the shifter, two redundant rings and cables. That’s a fair old chunk of weight gone and if using the front mech for chain retention, free…
    If you’re going to spend money anywhere, I’d say wheels and tyres are the place to do it. A nice light set of wheels will make more of a difference than anything else. Go tubeless if you can, its a bit of a faff and there isn’t much weight saving but they’re so much nicer to ride. Out of all the stuff you change, you’ll notice the wheels the most
    andypaul99
    Youve got a good spec on your bike as it is, i dont think it can be improved much. Id get some 2nd hand Rebas or even better Fox RL’s, have a look around flea bay im sure some will come up soon. That would save about 1/2 lb
    The frame is fine, if its the M5 you wont do much better, the carbon frame isnt much lighter anyway.
    I managed to get my Stumpy down to 25.5lb but it cost a mint (XTR etc etc) i gave up in the end im not sure its possible to get this type of bike much below that
    njee20
    Youve got a good spec on your bike as it is, i dont think it can be improved much on the cheap
    Plenty of room for improvement, but the budget is key.
    I’m not sure its possible to get this type of bike much below that
    Of course it is, just depends how much you want to spend and whether you actually want to make it light!
    br
    So you should, the Skyline climb is middle-ring for most.
    B.A.Nana
    Like others, I would say a cheap win is changing the inner tubes to supersonic or the Schwalbe equiv. That will probably save you upto 250gms for less than £20. beyond that I think I managed £1 = 1gm and mostly not new kit.
    jedi
    Milkie – Member
    cheers milkie! 🙂
    flange
    Considering the state of the trails yesterday, is the OP really going to ride anywhere steeper than that? 1×9/10 is fine, do it!
    duckman
    singlespeedstu – Member
    That sounds like a great idea.Can you recommend an acid that works on Ti?
    I also drain out all the brake fluid from my hoses and replace it with compressed air. Much lighter.
    Posted 17 hours ago # Report-Post
    I cut the outer two fingers off from each hand,don’t need em for shifting and that bone was heavy.
    AlexSimon
    Weight off a bike really makes a difference to me, but also the tyres (not necessarily weight but rolling resistance).
    My Ardents roll a lot faster than my Advantages and it makes a big difference. (Similarly, my bike feels like a downhill sled as soon as I put 2.5 super tacky HRs on).
    I have nobby nics too and they are great at rolling (I think because of the soft compound). But you might find it a really win win, by trying something like Racing Ralphs, or Crossmarks. Cheapish to try and there’ll always be times they come in handy.
    I’m not too up on the weight/£ info, but some of those KCNC, MT Zoom, Ashima bits mentioned above sound great.
The topic ‘Cheap wins to make my bike lighter…’ is closed to new replies.
