Home Forums Bike Forum change of handlebar …pain
Viewing 10 posts - 1 through 10 (of 10 total)
  • change of handlebar …pain
  • voodoo_chile
    Gone from 660mm 30 mm rise carbon riser to 760mm flat aluminium bar ..back hurts ,shoulders hurt and hands hurt …. Kept stem same height seemed very low with twitchy handling ..
    Just going to change back , worst 30 miles I have rode in a long time
    Damn you flat bars
    shifter
    That’s quite a big change in one go.
    tmb467
    Indeed.
    Stem will put you too far forward, wide bars will pull your shoulders apart and no rise will just pull all your weight onto the front / onto your hands and wrists
    If the old one was ok then just go back – or buy a new stem / spacers.
    neilwheel
    With original stem?
    What size stem?
    voodoo_chile
    Thomson 90mm 5 degree , big steerer ..I used to ride with wide flats a long time ago …switched it all back as before anyway I think ideally 700mm wide riser 20 mm rise would be ideal 760 mm feels so wide didn’t feel any difference with my breathing with the wide stance
    nickdavies
    Play with the angles. Try rolling them forward slightly so the backsweep is kind of aimed at your torso and roll the brakes to a flatter angle. I would find 760 flats far too wide though, 720 is about perfect for flats for me.
    This bike does have a 30mm longer stem than recommended, downswept with no spacers so I may not be an ideal example!
    tmb467
    If you’re near Leeds I’ve got both 20mm and 38mm rise 740mm bars if you want to try different sizes out?
    Can do a very cheap price if they suit you!
    Edit: and a short stem
    voodoo_chile
    Thanks tmb I have loads of combos to try anyway , kind offer though
    neilwheel
    I think you need to change the stem to get a balance, or go back to the original set up.
    I have 720 flats on my 29er with a 70mm stem, 750mm risers on the ‘Ardcore 26er with a 50mm stem.
    voodoo_chile
The topic ‘change of handlebar …pain’ is closed to new replies.
