Home Forums Bike Forum Carbon frame respray
Viewing 3 posts - 1 through 3 (of 3 total)
  • Carbon frame respray
  • tomhughes
    How much does it generally cost and does it void the warranty?
    pallymanz
    can cost between £150 – 300? depending on who you go with/ if you do the prep work yourself. do NOT get it baked or blasted though!
    and i dont know for sure, but i would expect that it would void a warranty, as lots of the sprayers not that its AT YOUR OWN RISK! as if you go too deep on the sanding, you can brake the fibers
    andyl
    normally repainting any frame will void the warranty. For prep I would just mildy prep the surface to remove any old flaking paint/lacquer but just with a scotchpad or some fine wet and dry.
The topic ‘Carbon frame respray’ is closed to new replies.
