I very rarely use the lighter socket , except when topping up the tyre pressure with a mini compressor.
I came to do it the other day and all was dead . I located the fuse , it was blown so I replaced it. The compressor then worked fine.
Next time I came to do the same job ..the fuse had gone again. Replaced yet again , used the compressor several times , switching it on and off and no issues yet again .The compressor also has a 20A fuse in the plug end which had never blown. The fuse in the car circuit is 15A . Guess what ..next time it’s gone again ..without any usage. What’s going on here ?… any pointers to common reasons for this problem ? I suspect people will say “short circuit” but there’s no obvious damage or corrosion anywhere . Just trying to avoid getting the multimeter out and tracing wires etc.
Any help / ideas much appreciated.
Thanks in advance , Bill.
