Unless the 11 speed kit is quite new, it’s not going to work well with a new chainring. Even if it doesn’t skip, it will increase wear on the chainring so that’ll be knacked when the 11 speed stuff comes to upgrade.
Just bite the bullet and do it all now.
I agree with the sentiment. However, can’t stretch the budget to that right now. Plan is to build the bike up over the coming months as and when I can afford bits. If I can use the 11 speed stuff, then the bike can be finished this year – otherwise, it will have to wait until after Christmas. The 11 speed has done about 600 miles – all looks OK at the moment – chain is not stretched, but I will replace anyway as it is too short. If 11 speed works, I will run it into the ground – don’t mind a sacrificial SLX chain ring for that!
I appreciate the advice though – it would be the ideal way to do it, probably not much to lose trying the 11 speed first though.
