Home Forums Chat Forum Blot on the landscape … solar farm
  • This topic has 112 replies, 44 voices, and was last updated 11 years ago by mt.
Viewing 40 posts - 41 through 80 (of 113 total)
  • Blot on the landscape … solar farm
  • athgray
    Slowoldgit. I would like to meet the person that could solve our energy problems as well as keep the populace happy about it. I don’t think that job exists.
    slowoldgit
    I don’t know about anyone else, but I use more electricity in winter, you know, the long nights and cloudy or foggy days.
    scotroutes
    retro83 – you forgot about this bit
    But it’s OK – coz that’s far, far away….
    http://kakadunationalpark.synthasite.com/
    richpips
    Didn’t mean anything by it rich.
    I know, I was being a smart arse.
    There is no easy answer though.
    grtdkad
    It doesn’t need to be put there and there are other less intrusive locations
    Erm like where? Oh I know, let’s put them up north, they won’t mind.
    retro83
    scotroutes – Member
    Okay, what’s your point?
    grtdkad
    What richpip said “If your community doesn’t generate electricity then you pay lots extra (to show your appreciation to those that do) or even better you can’t have any”
    That’ll learn ya!
    Northwind
    This is the most singletrack thread ever. Well nearly, it still needs someone who powers their own house by woodburner.
    CountZero
    cinnamon_girl – Member
    Just to be clear – I don’t actually live in the area.
    So you’re outraged on their behalf?
    I object to its location right beside the bridleway where distant views of the South Downs can be enjoyed.
    So you know absolutely for certain that this array will be on the side of the bridleway that overlooks the view?
    Sounds highly unlikely to me, the array has to be on the flat.
    It doesn’t need to be put there and there are other less intrusive locations.
    So you don’t actually live in the area, but you know it intimately enough to be able to say that it doesn’t have to be put in that location, and you know better ones? Surely there’s a real change of career opportunity right there; being able to magically produce the perfect location for solar arrays that fulfil all the requirements for optimum power efficiency and still not cause anybody to object to those locations.
    Hoping that there will be a protest group that I can join go and cause a nuisance with.
    I can see all the objections now; blot on the landscape, loss of farming land, yada yada yada…
    Unless you’re a hang-glider or paraglider pilot it’s highly unlikely you’ll be able to see it from ground level, as hedges are planted around them, if not already there, which is more often the case, they’re dark blue, so hardly going to draw the eye, unlike light coloured barn roofs, industrial units, high-voltage substations, pylons, etc.
    They’re raised around a metre to a metre and a half off the ground, on thin tube frameworks, allowing the entire area underneath to be used for grazing sheep, so hardly detrimental to farming. Compared to half a dozen wind turbines, 200′ or so tall, solar arrays are virtually invisible, and work as long as there’s daylight, which is a lot longer than most windfarms produce power. There’s a windfarm at Watchfield, on the way from Swindon to Oxford, which can easily be seen from Barbary Castle. There’s a solar farm near Hullavington, on the way to Malmesbury, and from Morgan’s Hill nature reserve, above Calne, you can actually see further than Malmesbury, but you cannot see the solar farm. You can see Lyneham airfield, Wroughton airfield, Kemble airfield, Portemarsh Industrial Estate outside of Calne, old airfield buildings at Yatesbury, barns, pylons, and God knows what else, but no solar farm.
    I know it’s there, I could just, and only just, see the frameworks through the hedge along the main road. It’s the only way you could know it’s there, though.
    There are far greater things to worry about, c_g, than solar farms which hardly anyone will actually be able to see; I respectfully suggest that you address your time and efforts to those. How about doing something about tracking down the assholes who dump hundreds of tons of rubbish, often harmful, in beauty spots, on rights of way, etc, as shown on Country File tonight?
    Or would that be too difficult, unlike standing around waving a placard for the media?
    irc
    Both wind and solar do nothing to meet peak demand on calm days in winter. They are therefore irrelevant from the point of view of preventing blackouts as coal and older nuclear plants get closed down in the next few years.
    As shown below. The peak demand in 2012 was in 12th December (dashed line) when wind was near zero and solar would have been near zero.
    Electricity supply and demand for beginners
    molgrips
    Ok, so we know that solar and wind are not on all the time. But will they actually save coal from being burned *in UK power generation*?
    I suspect so, because whilst coal power stations can’t easily be turned off, surely they can be ‘turned down’ quite a bit?
    Edit – looking at irc’s graph that would appear to be the case.
    grtdkad
    That’s exactly the point molgrips. You’re right and displacing coal and inefficient Gas is good.
    What that does mean though is that no body is currently rushing to spend a few billion to build a new, efficient Gas CCGT because ultimately they’re not going to run as much or as often as they could – making a pretty poor, or extended return on investment.
    Re the data above [Sadly] in my line of work I tend to keep an eye on what power is coming from what source.
    Here’s some real time data (updated every 5 minutes) – http://www.ukenergywatch.org/Electricity/Realtime
    As others have already said above we genuinely need a mix of wind, solar, nuclear, gas, interconnectors etc. the recent spate of political pantomimes will just jeopardise further investment once again. Pretty idiotic IMO.
    seadog101
    Why not this?
    Tidal Comparision
    Unless you’re a seal or dolphin, you’re unlikely to be effected. And it’s predictable.
    andyl
    are there any real working marine turbine farms yet? There is a reason why not.
    JCL
    Thorium MOX. Get a move on UK!
    mikewsmith
    slowoldgit – Member
    You have heard of business you know like factories and offices and things like hospitals etc that work during the day time. They might actually be a big user of electricity.
    irc
    But daily demand peaks at 6pm (as per daily demand graph at link) and during the winter solar is zero at peak demand.
    http://www.gridwatch.templar.co.uk/
    mikewsmith
    So on that logic it’s only worth pursuing sources of electricity that are good at 6pm? No single source of power is the answer, but lots in unison might be.
    mt
    I had a curry last night, could the by product of that delicious meal not be used? There was certainly some power in that last trump, wind and gas fired. What’s not to like.
    Don’t think I can hold it till 6pm though.
    parkesie
    I like the idea of the solar farm and would happily have one here with wind turbines on. When riding in wales i find the turbines add to the views and aren’t a nasty blot on the landscape.
    Harry_the_Spider
    Shame we don’t have the weather for a proper solar plant.
    trail_rat
    just need to find a more efficient way of storing the energy harnessed during the day…… battery tech needs to catch up 😀
    personally i find your house a blot on the landscape , its next to a really nice road i know.
    trail_rat
    haha – harry looks like something from the GIjoe cartoons when i was young. out in texas.
    Harry_the_Spider
    Solar thermal plants (like the one in the above photo) can store the energy using molten salt technology. Sun bounces off mirrors into a collector that heats up salt to a molten state. Molten salt is stored and used to generate steam when the demand is high. Steam is used to generate electricity the same was as in coal, gas, nuclear.
    This is being built right now to supply Las Vegas and will go on line next year. Desert to power plant in 2 years without any significant pollution. Not bad eh?
    Shame they can’t build them here, but they are going up in Spain, North Africa, South Africa, South America and North America right now.
    UK ones are nowhere near the capacity but I’d rather see a bit of wind or solar than something that burns its way through our dwindling fossil fuel reserves. If you don’t want one in your back garden but still want to be able to turn the lights on then tough ****. I’m sure the residents of Ferrybridge, Cottham, Runcorn etc don’t want their power stations either.
    winston_dog
    I was speaking to an engineer who works for a major power cable manufacturer, they are developing technology that will allow the efficient transfer of energy over huge distances.
    I know he is obviously biased but he seemed to think that a lot of the Globes energy problems could be resolved by the transfer of energy across a number of time zones, so that a power station would be exporting it’s energy 24/7 to areas of peak demand. Seemed pretty logical to me.
    Current renewable technology is not good enough. At the moment it is just being used by OEM’s and operators to milk subsidies out of gullible politicians to make huge amounts of money for investors. Especially offshore wind!
    molgrips
    Why molten salt btw? Presumably high melting point and high heat capacity?
    yunki
    I think reactionary backlash against renewable energy sources is one the most irritating traits of the bored pseudo-traditionalist malcontent..
    It makes me wanna pick ’em up by the neck and shake ’em
    The argument that it’s making a rich landowner richer is just perverse twaddle as well.. are other energy suppliers usually simple common folk, struggling to get by on minimum wage..?
    molgrips
    Most people are happy to admire country houses and castles as a lovely part of the countryside. They were built by very rich landowners, but you don’t hear people complaining about that.
    hexhamstu
    We have bluebells, its so beautiful, horses wah wah wah. What’s your recommendation? Build it all up north in the desolate landscape?
    winston_dog
    No. Obviously not. In fact they are frequently the same Companies.
    I think the supporters of current renewable technologies, who want to invest billions into flawed systems, are just trying to make themselves feel better about living a lifestyle that consumes vast amounts of energy without actually addressing the problem.
    It makes me wanna pick ’em up by the neck and shake ’em.
    I have seen first hand how much resource and energy is required to install offshore wind and the vast majority of the current windfarms will not generate as much energy in their operational life that it took to build them. How can that make sense?
    MSP
    And complain about damage done by mountain bikes in places criss crossed roads and motorways.
    trail_rat
    “Why molten salt btw? Presumably high melting point and high heat capacity? “
    complete stab in the dark here – but probably your points and the fact its pretty common around LA ?
    molgrips
    Winston. Most supporters of renewables know that they are currently not a complete solution to the problem. But it’s better than nothing. We may not yet be in a position to eliminate the burning of fossil fuels (well, we could be, but that’s another issue) but we might as well reduce it – don’t you think?
    That’s going to need backing up.
    trail_rat
    http://www.spectator.co.uk/features/8766481/the-great-british-wind-scam/
    this is more of an issue than the input / output situation
    wind was the governments answer to sticky plaster the C02 emissions is must by law reduce over the coming years.
    i have relitives that work for SSE and they have said something similar to winston – to the extent that no new wind projects were being considered by SSE.(note that was at Xmas last year so their stance like any companies may have changed in the last 11 months ;))
    winston_dog
    A project I was involved in was based around the windfarm having a 25 year operational life. It would pay for itself after 23 year’s with subsidy. That also didn’t reflect the realistic down times due to the frequent failure of the the generators themselves. Without the subsidy it was not viable.
    Onshore wind is better because of the massively reduced installation and maintenance costs.
    A typical offshore turbine is 5 – 6 mw. The base is made of large quantities of steel and/or concrete, the blades are carbon fibre and the whole lot has a huge CO2 footprint in its manufacture and transport. All this to put a relatively small generator in place that does not run 24/7.
    Maintenance costs are massive and if you think cars use a lot of fuel have a look at the fuel consumption of even the small crew boats used to access the turbines. Never mind the fuel used by the installation vessels.
    You can try and get a straight answer out of the operators but they will not give it.
    Harry_the_Spider
    Dunno for sure but I’m guessing it has the correct thermal properties, is easy to pump around the system and doesn’t poison the place if it leaks.
    Junkyard
    Backing up with actual peer review science rather than anecdote
    wrecker
    If it means less wind turbines, them I’m all for solar PV farms.
    molgrips
    Compared with the construction and running of a coal plant?
    trail_rat
    http://www.epaw.org/documents.php?article=backup7
    there you go junkyard – just for you .
The topic ‘Blot on the landscape … solar farm’ is closed to new replies.
