Home Forums Bike Forum Bike products that need sorting out
Viewing 40 posts - 1 through 40 (of 59 total)
  • Bike products that need sorting out
  • cynic-al
    There must be millions to be made…my own gripe is how crap are bar-end plugs?
    They never fit, you wrap a load of tape round them and they still fall out randmoly outside a shop or something so you have to go and buy more.
    Yours?
    thisisnotaspoon
    Specialized rear hubs used on the camber/pitch, no idea who made it but it was the single biggest piece of crap ever.
    ads678
    I’ve the same x-lite ones in for about 7 years…..
    mikewsmith
    front mech adjustment and cable location
    cables that don’t fray
    bearings that just come out
    Rorschach
    Cable actuated derailleur gears.
    Suspension linkage bearings.
    Adjustable seatposts.
    scud
    Joplin seatposts, had 3 of them, all rubbish!
    Trimix
    My Reverb is fine – has been since i bought it a year ago.
    But the Crank bros products Ive used do seem to fail fast – perhaps its the poor engineering and “not riding in the mud” that seems to go on in the US.
    richmtb
    +1 for front mechs. On a mountain bike there position means they are guaranteed to fail.
    Suspension bushes that last
    mikewsmith
    never had a f mech fail just PITA to work with
    esselgruntfuttock
    Never had one fail yet. Had an XT on the old HT for at least 15 years now.
    fasthaggis
    The re-launch of the Hite Rite is long overdue . 😆
    cynic-al
    TBH the thread was intended to be about products that just don’t work, but could/should…most of the above don’t fit that IMO!
    druidh
    cynic-al – Member
    They never fit, you wrap a load of tape round them and they still fall out randmoly outside a shop or something so you have to go and buy more.They don’t fall out randomly. That’s your fanbois stealing them as mementos.
    D0NK
    ahem
    D0NK
    old top swing ones do seem to last forever, all my sus bikes need bottom swing which go wobbly after a few years.
    jota180
    Go to the Crank Bros website …….. anything that’s on there
    Houns
    Hope bar end thingies are great
    XTR front mech approx 9 years old going great
    VanHalen
    my crank brothers oem smarty pedals with the plastic cage and dodgy reflectors from a few years back have been amazing. i use them daily in all weathers, off and on road, ride DH, drops, jumps, stair gaps, xc the lot. still not bent the axles – they just squeak randomly.
    cant vouch for any of their other stuff mind.
    sram x7 & x9 mechs would be my vote for something that ought to work fantastic but are just a bit crap.
    servo
    First thing I do when fitting new handlebar tape is throw away the included end plugs and reuse my ones with a screw in that don’t fall out.
    What about the bits of supposedly sticky tape they give you for finishing the bar tape in the middle. They are the most unsticky things in the universe. Fit one and turn your back to get the other one out of the box and you can hear it unpeeling itself…
    Insulation tape every time.
    oldfart
    The stantions on Fox forks ! Not fit for purpose .
    ahwiles
    as an ‘engineering-problem-to-be-solved’ – mountain-bikes are done.
    most stuff works, and works well.
    don’t like product X? – just use product Y. it’s half the price anyway.
    i’m sure that shimano are working on a new 11-speed system, and specialized are working on yet another version of the enduro, and rockshox are working on a new 12mm thru-axle system, and etc.
    but really, most ‘changes’ these days are just guff.
    there are a couple of things i’d like to see, but they’re just tweaks really.
    example: cheap through axle forks from Rockshox, steel stanchions are fine by me, basic damping is fine by me, but QR’s belong on road bikes.
    onandon
    Singlespeed chain tensioners.
    Why cant someone make a decent light weight version- not really weight weenie (but that would be nice)
    but just something less that a huge lump of alloy and massive chromo bolts.
    batfink
    Strong, light, cheap….
    In all components, I want all three of these things, not just the two that I’m getting at the moment.
    ir_bandito
    Anything made by Raceface with bearings in them. Kind of similar situation to Crank Bros. Use good bearigns and good seals.
    Rucsacs/camelbacks. Why not make them out of waterproof fabric instead of using stupid rain covers?
    The whole drivetrain. Why use material that will rust when it gets wet? Why have all the gear-changing gubbbins on the OUTSIDE where it can get damaged?
    franki
    Bottom brackets. They used to last for years. Now they last for months. (Or less.)
    ahwiles
    because chains are very efficient.
    hub gears aren’t. if you still want a hub gear, you can get one, they work very well.
    you can even ditch the chain, and use a rubber belt.
    see? – all the real problems have been solved…
    franki – Member
    i get years out of external shimano jobbies, and when they finally develop a small amount of play, i can replace them for £15. i don’t even need to use a crank extractor (and the terrifying, delicate threads in the cranks)
    i’m going to guess that you’re a jet-washer…
    Mackem
    Although it’s not really a problem, what I’d like to be able to do is replace all the screws and bolts with ones that use the same tool to install/remove. One allen key to fit them all sort of thing. Probably there’s some reason it cant be done, but I can never find the size I actually need. (hopes someone has already solved this non-problem)
    ahwiles
    you can pretty much dismantle any bike with a 5mm allen key…
    PeterPoddy
    The riders. Most of them are crap, fall off, faff too much and generally think they are better than everyone else if their bike is more expensive.
    ir_bandito
    I have, on both counts 🙂
    ads678
    Not if you’ve got lock on grips!
    Admittedly you can still take the bars off….
    relliott6879
    Torx bolts on rotors. What exactly is wrong with allen key bolts?
    After rounding one out (removing a seized-in bolt to in turn remove a corroded-beyond-rescue rotor from a wheel of a bike I bought) recently, I went online to buy more but could only find Torx heads. I ended up ordering a job lot of allen headed bolts from XYZ Random Bolt Manufacturer off eBay, but found they can only be used on the rear rotor as the heads are to large to fit between a rotor and fork leg. I got round the problem by stripping the very old bolts out of my Hope rotors on my road wheels (with allen heads!) and using 6 in the front rotors on each pair of wheels, with 6 of the new ones in each rear.
    D0NK
    pretty sure I’ve got some XT external bearings from 2008 still running sweet
    but yes I’ve had other external bearings that have died within a few months. Square taper used to consistently last ages, external bbs are like disk brake pads sometimes they last years sometimes they die early YMMV.
    Mackem has a point, fewer different bolts would be nice and while we’re at it 8mm bolts and friction fit should be binned now (part of sq taper I don’t miss), hate installing the RF cranks I have, shimano cranks are much better for fitting, maybe a 5mm allen bolt end cap instead of the star thing they have now tho.
    Relliot aren’t torx supposed to be longer lasting? Less prone to rounding?* but all or nothing would be better, wholesale switch to torx or stick with allen please.
    *no idea if either are true
    fuzzhead
    Race Face external BBs – crap incarnate
    PJM1974
    +1 for anything Race Face that involves bearings, splines or that rotates. Avoid.
    Lock on grip bolts which round long before the grips themselves wear out.
    Standards…whilst we all reap the rewards of progress there are a proliferation of artificial standards designed simply to prevent two products in the same range from competing against one another. I give you the following:
    15mm forks – Why not simply make them all 20mm bolt through?
    Headtubes – 1.5 only please. Yes Giant, I’m looking at you.
    ISCG – How many standards are required to stop your chain dropping off?
    Hub widths – 135mm Maxle works for me.
    If we have to have yet another standard, can it be a standardized system of frame sizing?
    pdw
    After rounding one out…
    You just answered your own question.
    Hex key is actually a poor design as it puts all of the load on the corners of the hexagon, leading to easy rounding out of both the tool and the bolt. Torx puts the load onto flats of the tool/bolt.
    My problem is with the people who use hex bolts on rotors in the first place.
    Junkyard
    is it on your only comes out in the summer when it sunny bike?
    yes what he said hex bolts are much better/less likely to strip out
    dropper post that are play free
    Cleats that dont wear
    Tyres for all surfaces
    Non clicky **** loudly rear hubs that are not cup and cone or the same price as my bike THIS above all else
    pdw
    + 1. And I don’t jet wash my bike.
    Admittedly my last one lasted 18 months, but that’s still underwhelming. It did finally occur to me what the advantage of external bottom brackets is: no danger of them being in the frame long enough to get stuck.
    I’ve mellowed a little since discovering you can get replacements from bike-discount.de for under €10.
    relliott6879
    pdwMember
    The bolt I rounded out was a Torx.
    D0NK
    😀 awesome
The topic ‘Bike products that need sorting out’ is closed to new replies.
