Home Forums Bike Forum Best method to fix new pannier clips to old Karrimor bag
Viewing 6 posts - 1 through 6 (of 6 total)
  • Best method to fix new pannier clips to old Karrimor bag
  • sefton
    The original clips on my Karrimor bags won’t fit a 12mm rack
    So I bought some other clips to see if they would work
    The original clips (red coloured) have grooves in the plastic that kind of clip into the rail on the bag. Then you simply screw a small screw in
    The replacement clips (blue) are a flat profile.
    What do you think the most secure method of securing the new clips onto the rail might be.
    There isn’t much space behind the rail btw. (I’m not sure a bolt would fit behind)
    Clips
    Clips
    Clips
    Clips
    Clips
    tthew
    I’d put a washer on it and a screw with a corse/self tapping thread.
    or drill the rivets out and replace the whole rail assembly with a replacement full kit, you can buy Ortlieb ones.
    richmars
    Did the same swap and I think I used the self tapping screws in the above link.
    csb
    I ended up doing this to refurb an old pannier. Worked perfectly.
    sefton
    Would a self tapping screw be strong enough. I know that’s how the original clips are fastened on but they have a ridge in the plastic that also kind of clips into the rail.
