I have the blue Amazon/ebay one mentioned above, I put a review of it here…
I picked it up from amazon for about 40 quid so worth keeping an eye on prices.
For removing bearings, I tapped the main ones out, small chainstay ones (two bearings back to back) I used the bearing tools puller from above that screws in.
For some of the others I managed to use the installation tool to remove them. My bearings were slightly inset into the frame, so i used a larger drift on that side (to push against the frame) and a smaller one on the inside to push the bearing the first few mm out of its seat, then it came out easily.
