Home Forums Bike Forum Bashguard for Middleburn Uno
Viewing 3 posts - 1 through 3 (of 3 total)
  • Bashguard for Middleburn Uno
  • Nipper99
    Is there such a thing that fits or can be made to fit. Used as part of a 1×9 set and currently use a Pauls Chainkeeper which is not really up to the job. Want to use an N Stop device with a bashguard if possible. Any pointers. Ta.
    goldfish24
    Middleburn do a trials bash that goes on the splines and takes a 4 bolt ring, but I’m pretty sure it only takes 22 tooth rings and prob weighs a ton. Unless anyone else makes one for the middleburn spline system, you’ll prob need to fit a spider and put a standard bash on.
    Nipper99
    Might be a job for the lathe then.
The topic ‘Bashguard for Middleburn Uno’ is closed to new replies.
