I have a Versa STI shifter for an Alfine 8 hub on the drop bars of my 10yr old Genesis DayOne. However the shifter has now started to fairly frequently not change up from 1st gear (and I think occasionally 2nd gear) which is a real pain. The shifter, gear cable tension, cable location at the hub (set using the yellow lines on the hub in 4th gear) and the hub are all exactly as they should be so it is a problem in the shifter and likley as issue with the ratchet system. I have not yet started to strip the shifter.
Has anyone successfully repaired a Verso shifter and/or found spare parts for one? Any tips on said repairs?
If I cannot repair the current Alfine 8 STI shifter I am going to have to track down a replacement. Thoughts on a suitable replacement in 2024 other than the £180 Microshift option at SJS?
There was a thread 8yrs ago on STW I will follow up on.
Cheers in advance
