Anyone bodged anyth...
[Closed] Anyone bodged anything useful to attach to Spec saddle SWAT mount?
10 Users
Offline  Poopscoop
Share this post
Getting a saddle soon with the swat mount. Anyone made/bodged a useful attachment or whatever to fit to it?
Posted : 29/03/2018 6:23 am
Offline  BoardinBob
Share this post
Why bodge?
https://www.bikemag.com/gear/accessories/review-specialized-bandit/
Been running that for a couple of years. Really good
Posted : 29/03/2018 8:07 am
Offline  DickBarton
Share this post
A bike that can be ridden...
Posted : 29/03/2018 9:25 am
Offline  nwmlarge
Share this post
The bandit is very interesting as an option, does anyone do anything similar for non specialized saddles?
Posted : 29/03/2018 9:30 am
Offline  TiRed
Share this post
All Fizik saddles have a clip that allows a direct mount saddlebag or Cateye light bracket. Works perfectly. There are also 3D printed accessory mounts for other toys.
Posted : 29/03/2018 11:46 am
Offline  tthew
Share this post
Yes. A saddlebag. Comes in a range of sizes and prices from a surprising range of sources.
Posted : 29/03/2018 12:20 pm
Offline  scaredypants
Share this post
that bandit thing,
like a saddlebag but smaller and gets kack all over your stuff; is that about right ?
Posted : 29/03/2018 12:26 pm
Offline  steve_b77
Share this post
This, I don't get the current obsession with strapping things to saddles that leaves them open to the elements, just fit a saddle bag and they're safe from the elements.
Yeah I know it "might" foul your dropper, if it does, experiment and get one that doesn't.
Posted : 29/03/2018 12:31 pm
Offline  nwmlarge
Share this post
I realise that Saddle bags are available.
Saddle bags:
Keep stuff clean and dry
Don't keep anything secure unless you are ramming them full of stuff
Bandit:
Keeps stuff secure and not bouncy
doesn't keep anything clean, unless you put a plastic bag over it
Need the secure load aspect of the bandit with the flexibility of fitting any rail.
Must be do able without a DIY effort.
Posted : 29/03/2018 2:05 pm
Offline  PeterPoddy
Share this post
The bandit thing works well. It’s unobtrusive and carries the bare minimum: tube, tool, tyre lever in my case. Plus a gas cartridge if you like that sort of thing. I prefer a pump. Tube gets dirty but that doesn’t bother me. I’ve got the chain tool that fits inside my steerer too. Never used it but it’s there if I need it.
Posted : 29/03/2018 2:21 pm
Offline  steve_b77
Share this post
But doesn't having a dirty tube (ooo'errr) mean you've got to clean it before you put it in the tyre, otherwise you're at risk of little bits of grit causing punctures as they rub against the tyre?
Posted : 29/03/2018 2:25 pm
Offline  nwmlarge
Share this post
You probably do have to wipe the muck off of the tiny bit that is exposed.
Bearing in mind its rolled up you will get about 10% of it dirty.
Posted : 29/03/2018 2:43 pm
Offline  SirHC
Share this post
Stick the tube in a thickish plastic bag.
Posted : 29/03/2018 4:20 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
