Home Forums Bike Forum Any useful advice for removing a Sram Force Crank
Viewing 19 posts - 1 through 19 (of 19 total)
  • Any useful advice for removing a Sram Force Crank
  • rowlapa1974
    As title I need to remove my Sram Force Crank from my road bike as I’m selling my frame following a warranty replacement. The problem I have is the cap the holds the crank arm on seams to be stuck fast? I have put WD on it but nothing. Just concerned with damaging the carbon crank arms.
    Thanks
    chakaping
    Is there a self extracting nut missing?
    Most Sram cranks have a bolt which loosens and then braces against an outer nut to push the crankarm off.
    You poke the allen key through the wider outer nut to turn the actual crankbolt.
    Hope that makes sense
    rowlapa1974
    It’s just a single alloy cap that gone into the shaft of the crank.
    chakaping
    put a pic up
    rowlapa1974
    [/url]
    Untitled[/url] by rowlapa[/url], on Flickr
    Im trying to undo it against the arrow
    everyone
    Stick a 10mm in there and give it some beans.
    rowlapa1974
    It’s had more than beans
    Rorschach
    Stop being a fanny,
    Have another cuppa.
    Secure the pedal to the chainstay with zip ties/toe clip straps (lots of) and use a seatpost/handlebar as a lever on the hex.
    Then get the wife to do it.
    orangeboy
    Just to check your not trying to unscrew the out cap ?
    rowlapa1974
    PMSL fair play that’s the way mate
    rowlapa1974
    Had an old set of handle bars on the 10mm already and **** all movement. Don’t fancy the chain stay option as its a carbon frame. Thinking the Germans have had the old loctite on it when building the bloody thing arrrrrrrrrr
    rowlapa1974
    Only a single cap no inner section like the older Sram cranks
    Rorschach
    BB30 use an ali spindle and an ali bolt.They just let go all of a sudden with a bit of a bang.
    I’ve done lots (11 years in bikeshops).You’ll not damage the stays.
    You are undoing the correct side are’nt you?
    Is that picture of your bike/crank or a googled image?
    everyone
    Get a hammer involved. Shock loading might just be enough to crack the bolt off. If that doesn’t work then you need to give it even more beans.
    rowlapa1974
    Top men thank you for the advice will give it a go again tomorrow after some bike time.
    rowlapa1974
    That’s my crank, the drive side is the hollow and the cap is on the non drive side.
    Was considering holding the crank arm in the work stand?
    rowlapa1974
    Had no trouble with my X1 crank which the same fixing bolt? So will grow a set and give it the beans
    orangeboy
    As I’ve a shagged shoulder sram cranks are often a two person job at work
    Me standing on a pedal and other on the end of a big bar. As long as your sure the Allen key is in properly it’s just a question of more force
    rowlapa1974
    Thanks orangeboy will be taking the frame with me this morning and enlist the help of one of my riding mates I think.
    Thanks to everyone for the advice
The topic ‘Any useful advice for removing a Sram Force Crank’ is closed to new replies.
