+1 for enduro bearings being massively overrated. We’d never dream of using them in my industry (marine ship systems). I’d always specify SKF or FAG. I also like hope bearings from a mountain biking viewpoint. Anyone know who the OEM for them is?
For any mountain bike bearing, the main cause of failure is corrosion from water/mud ingress. Apart from a very well sealed hub bearing, I’ve never seen a bearing failure arising from standard wear to the balls/races. Every frame bearing I’ve ever pulled has had more mud than grease inside by the time it’s failed.
With the cavet I’ve never used them, I can’t see much benefit from the Black Oxide bearings. The balls aren’t coated for starters, and they subsequently can corrode and bind to the cage and race. I’d also have questions over the wear resistance of the black oxide coatings on the races. Frame bearings are constantly subjected to non-linear radial and axial loads which really isn’t good for bearing longevity and I can’t see the coating lasting in these conditions.
The best way to keep any mountain bike bearing going is to repack them from new with a decent marine grease. Most bearings have around a 30% grease fill, because more than that increases friction significantly, which matters when on a rotating piece of machinery at 1000rpm, but not a frame bearing that never completes a full rotation. Even enduromax bearings which have been designed for frame bearings aren’t sufficiently filled imo.
The full compliment bearings are a great idea in theory as most frame bearings are undersized for the load conditions. But again corrosion is the usual failure mechanism, and they need a small grove in the side of the race to fit the balls into the bearing during manufacture. This provides a weak point in the sealing interface and further enables water ingress.
