chakaping
I’m no expert, but it’s generally claimed that motorbike suspension fluid is the same as bicycle suspension fluid.
In the past, Rockshox and Fox have used Silkolene and Torco motorbike oils. It used to be really obvious as the bottles were the same. Not sure where we are with that now though.
TBF, lowers are just a bath/lube so it just needs to be the right amounts, vaguely the right thickness and slippyness, and not have any additives that cause problems (some fork oils include agents designed to slightly swell up seals, to give better sealing, but pushbikes tend not to want that- difference between motorbikes that might realistically never get a fork service over tens of thousands of miles and many years and are suspending 200+kg, and pushbikes that are supposed to be serviced every 5 minutes and want really low stiction)
I used Ford diesel engine oil in my Lyriks for a long time. Can’t remember why, someone recommended it.
