Home Forums Bike Forum Airwolf & Chinese Carbon Frames – Will I lose my teeth?
Viewing 3 posts - 41 through 43 (of 43 total)
  • Airwolf & Chinese Carbon Frames – Will I lose my teeth?
  • dyna-ti
    Didnt read entire thread, so likely been said.
    Any issues you’ll likely have to return it to the maker in China.
    My 😀 Won’t that be fun.
    ductions
    Hi Simon, I know it’s only been a week or so but how are you getting on with the frame? I’m thinking of getting an airwolf rigid 29er, non boost with pf30, as I have some bits laying around.
    How long did it take it arrive? It certainly looks good in gloss. Are there decals on the frame or is it just a reflection? If so can you remove them?
    simon_g
    Just to update, after a very slow build I’m actually riding this now. Hadn’t ridden much in the winter and when I did I grabbed the bike I knew would work! Enjoying it though, not a weight weenie build (NX 12 speed cassette is very heavy) but was bang on 25lb.
    There’s an insert in the seat tube that limits post insertion (a little way above the bottle cage bosses – 185mm from insert to top of seat tube) but fortunately my dropper is just right with it as far in as it’ll go. No other issues with the build other than internal routing faff. I opted to run a full outer to the rear mech and there’s just enough clearance on the chain stay to get it through. Used the jagwire foam pipes on the internal cables and it’s all nice and quiet.
    It hasn’t cracked or killed me so far.
    (excuse the state of the garden)
The topic ‘Airwolf & Chinese Carbon Frames – Will I lose my teeth?’ is closed to new replies.
