How long is reasona...
How long is reasonable for garage to repair car.
Don't get a report done FFS.  You have rejected the car.  Its now the sellers issue.
Posted : 28/08/2025 3:32 pm
If seller is refusing to honour their obligations, or even by the sounds of it not even discussing further then OP has now to involve third parties, in this case either the CC company by a chargeback and make it their issue as is allowed under finance rules, or they could go direct to legal and seek a court solution. Either way they need now evidence that the car is not repaired to an adequate standard hence IMHO they DO need an independent report*.
* CC company has asked for one to progress it. You could go legal without but then is your word against theirs and harder to 'prove' and the cost of the report will be part of the claim anyway. As indeed would legal costs too, AIUI.
OP has most recently done pretty much everything right and is still stuck in this
'but these are my rights' <-> 'I refuse to honour your rights'
impasse.
Any thoughts to actually name the dealer, other than a multibranch car supermarket in Bury, because I for sure wouldn't want to buy from them.
Posted : 28/08/2025 3:45 pm
Ta jonv
Posted : 28/08/2025 3:53 pm
Thanks all.
TO clarfiy: Its the credit Card that have asked for an independant report. As technically I have held them jointly liable(by virtue of paying the deposit on the CC) they need a report to show that the issues still remain.
The way I currently see it is this:
1, Oil usage and occasional smoking. Dealer diagnosed turbo and so got a garage to replace it. Garage have done a shite job and the issue still remains plus additional issues due to the replacement: Whistling noise when on boost plus missing bolts from install, hose left flapping and now the undertray is missing.
2. Headlight levelling. Garage just did a headlight alignment which as expected wont repair a levelling motor issue.
3, knocking from front suspension: Dealer couldnt replicate. I can feel/hear it over rough tarmac and speedbumps.
Posted : 28/08/2025 5:28 pm
Well strangley Ive just had a reply from the dealer manager.
This is what I sent:
FINAL LETTER OF REJECTION
Dear Gregory Jackson (General Manager),
In the following email I refer at times to the Consumer Rights Act of 2015 (CRA), and the Motor Ombudsman (MO) explanation of it. For ease the links to both are:
THEMOTOROMBUDSMAN.ORG "https://www.themotorombudsman.org/knowledge/what-is-the-consumer-rights-act/"
What is the Consumer Rights Act, and how does it affect my vehicle purchase? - The Motor Ombudsman
If you bought your car after 01 October 2015, the Consumer Rights Act 2015 applies. This means that, when you buy the vehicle, it has to be of satisfactory.
LEGISLATION.GOV.UK "https://www.legislation.gov.uk/ukpga/2015/15/contents"
An Act to amend the law relating to the rights of consumers and protection of their interests; to make provision about investigatory powers for enforcing the regulation of traders; to make provision about private actions in competition law and the Competition Appeal Tribunal; and for connected purposes.
I bought WU19ZSZ 2019 Seat Leon FR estate from you Motor Trust Bury on 17/05/2025 for the sum of £14969
On 19/07/2025 I informed you that there were problems with the vehicle. This was by email, and the following issues were noted:
1, Smoking from exhaust & use of oil.
On start up, the car smells quite badly of oil and occasionally fuel. Once the car is up to temperature and after prolonged idle, when pulling away there is a large amount of blue/grey smoke from the exhaust. If stuck in slow moving traffic and then pulling away again there is smoke from the exhaust. If I leave the car running on the drive and then pull off the rear screen gets covered in smoke. In 1400 miles the car has gone from max to min on the dipstick twice. I can see no evidence of oil leaks anywhere. Occasionally there is smoke from the exhaust when revving the engine higher into the rev range as well. More often than not the cooling fans are always running after a drive and continue to run for about 5 mins. When this happens the front of the car always feels hot. Coolant has dropped slightly over the same 1400-mile period. Stop start does not work. The smoke is normally worse before 3000rpm before the turbo starts spooling.
I have not noticed any smoke on start up from cold, but it does smell quite badly of oil and fumes if the windows are down when starting the car.
2, Passenger side headlight levelling motor inoperative.
When turning the car on in dark conditions the headlights do a self-levelling check. The passenger side light fails to do this. When switching to full beam the headlights adjust up slightly. The passenger side light fails to do this. When in operation I was getting flashed by oncoming vehicles due to the glare of uneven headlights
3, Knocking from front suspension over rough roads.
When driving on rough roads that have uneven surfaces there is noticeable knocking com-ing from the front suspension. Possible drop links?
As this is outside the 30 day period specified in the CRA, as per the MO explanation I "have to give the selling dealership or garage one opportunity to repair or replace your car, with repair normally being the best option"
The car was returned to you on this basis on 26/07/2025 and despite being clearly advised of the faults you did not address faults 2 & 3, only fixing the Turbo, which I was unable to verify for reasons further below. When the failure to repair issues 2 & 3 was highlighted for a further time, for goodwill I agreed with you that you should keep the car and fix the further faults. This is why the repair to the turbo was not inspected at the time.
After you informed me that repairs were completed by email on 21/08/2025 I returned to collect the car on Saturday Aug 23rd. On inspection, you had clearly again failed to repair the car as required, namely:
1, Missing bolts / connections on the air intake to turbo fitting (Subsequently rectified whilst we went to get a coffee) Further, when I drove the car on Saturday the turbo does not appear fixed as there is a pronounced whistle from the turbo whilst the engine is on boost, this points to either a boost leak or failing bearings inside the turbo. Additionally, on inspection when we got home there is a further bolt missing from a component fitted to the new turbo and there was a hose not connected correctly and left dangling in the engine compartment.
Disappointingly there is still an issue of smoke coming from the exhaust after being stuck in traffic and the cooling fans are still cutting in a lot/The car appears very hot.
2, Headlight motor not replaced as required, your repair by realigning manually is not acceptable. The MOT requirements state that "Vehicles with high intensity discharge (HID) or LED dipped beam headlamps may be fitted with a suspension or headlamp self-levelling system. If these systems have been fitted, they must work. Whilst we were at stale mate over rejecting the car you suggested that we take the vehicle to a garage local to us to diagnose and then contact the warranty company for approval. Initially we considered this option but on reflection and after finding the issues with the newly fitted turbo we are not going to do this. The fault was clearly described in the original email listing the faults and the car has been at your dealership for 4 weeks which is a reasonable time to repair the issue.
3, I understand the testers were unable to recreate the third fault of knocking from the front. This is immaterial in light of the first two now.
Given the substandard work on the turbo, as per faults above consequently I do not consider the vehicle to be repaired satisfactorily.
Under the CRA after the 30 day period you have one attempt to repair. You have had repeated opportunities, and the car is not repaired, consequently I am rejecting the car as per my statutory rights as outlined in the CRA
Consequently, I require a refund for the vehicle WU19ZSZ to be paid to me in return for the car. No other option is acceptable to me, and I will not enter further discussion about other options.
Please confirm your agreement by return email.
If you do not agree to the above, I require in writing within 48 hours your explanation. Please included which parts of the CRA you feel do not apply, and why you are not obliged to provide me with my statutory rights as described above.
The CRA makes provision for "a refund of what I paid for the car minus a deduction for any usage I've had. This is usually calculated by looking at how many miles you've added to the vehicle, and charging a certain amount of pence for each mile driven"
I have owned the car for 3 months in which time it has covered 1915 miles. In that period it has been faulty and unusable, including at your garage for 4 weeks. 369 of the miles it has covered have been incurred as a result of returning it to you and use whilst at your dealership.
Contract hire purchase usually provides for an excess mileage deduction of around 9-12p per mile. For the miles covered by me that are not as a result of returning the car for your work, I therefore consider the reasonable deduction to be 1546 x 10p = £154.60.
However, in light of the inconvenience (includes travelling a not inconsiderable distance, twice, at a cost, to try and get this resolved) and hardship incurred as a result of the car being of unsatisfactory quality I propose that this is waived, and full refund made, and in turn I will waive any right to further claims for inconvenience.
Kind regards
Ant his is his reply:
Dear Steve
Thank you for your email and it was great to meet you on Saturday.
I have read through this and have provided you with the invoices for the work completed. Please as our agreement Saturday get the diagnostic on the auto leveling headlight and let me know the costs and i will authorise through your extended warranty as we discussed.
Kind regards
Again not responding to the rejection and trying to get me to put it though warranty. to caveat: we did initially consider doing this but after finidng the other issues decided against it and just want to reject the car
Posted : 28/08/2025 6:54 pm
Invoices for work that was clearly substandard and an offer to pay for a warranty repair in return for you keeping a car that whistles and smokes is contemptible. Tell him to **** off, politely.
I would suggest:
Dear Gregory.
I refer you to my previous correspondence. I clearly state that you have had more than one attempt to repair and have failed to do so, consequently I am exercising my statutory right to return the vehicle for refund. As per my email "No other option is acceptable to me, and I will not enter further discussion about other options"
Further, also as per my email "If you do not agree to the above, I require in writing within 48 hours your explanation. Please included which parts of the CRA you feel do not apply, and why you are not obliged to provide me with my statutory rights as described above"
Posted : 28/08/2025 7:09 pm
oceanskipper reacted
I havent got the fight in me tonight.
Ive got the car booked in for wednesday next week so fingers crossed that will prove useful.
Posted : 28/08/2025 7:50 pm
I wouldn't bother with that last paragraph, just gives an option for more to and fro. Id be stating that the your next correspondence will be a letter before action.
Or I might just send that now.
Posted : 28/08/2025 8:06 pm
I'd go to the letter before action now.
Posted : 28/08/2025 9:02 pm
It’s definitely LBA time. Invoices for work do not prove it was completed satisfactorily, which it clearly wasn’t. He’s taking advantage of your reasonableness - it’s time for him to abide by the law and pay up.
Posted : 28/08/2025 9:08 pm
There’s no hope when the manager can’t even be bothered to sense/spellcheck his response.
Posted : 28/08/2025 9:17 pm
No fight needed. Just copy, paste send what I wrote. Do it now, then you aren't stewing tonight.
I included the last para and would do so because it reiterates that he is accepting that he is breaking consumer law. He won't answer it because that signs his agreement to it, but I'd still include it.
Your reiteration that you know your rights and won't accept any other resolution will win in the end. You might need to send it again, shorter each time.
"I refer you to my previous email, Yours etc." or as other have said, you could say this is your final correspondence before taking action.
At the same time, keep it booked in for Weds but ask them to review all three parts and quote to put all three right, itemised. It'll enable you to either evidence that he has failed to repair via an independent third party, and then CC recharge him. Or he'll shit at paying retail rate and get it back so he can do it on the cheap and sell to another punter who might not be so dogged.
Posted : 28/08/2025 9:33 pm
Cheers all.
Do you think it’s worth seeing how the section 75 claim pans out first or just go straight for LBA to run alongside the section 75
Posted : 28/08/2025 9:41 pm
As you've paid by CC and have benefit of Sect 75 I don't think you have any need of a LBA myself.
If CC reject your chargeback (and I can't for the life of me think why) then you can go legal. I wouldn't do both simultaneously, you might end up incurring legal costs you struggle to recoup, you still have a duty to minimise losses to all parties.
Posted : 28/08/2025 9:58 pm
Yeah agreed.. One step at a time or it will get really messy.
You've got time and due process on your side so no need to jump the gun.
Posted : 28/08/2025 10:42 pm
If I leave it to the credit card would you still advise to reply to his email above with the template above.
Also should I let him know about the other missing bolts and under tray and that I’ve booked it in for an independent inspection ready to take further.
Thoughts welcome.
Posted : 29/08/2025 9:01 am
The earlier you record any further problems you've found the better imv.
The LBA incurs no costs,  it's the last chance before formal proceedings.  So id proceed with that now.
Really sad that you are being put through this.
Posted : 29/08/2025 9:25 am
That's a lot of words.
"Dear manager, I am rejecting the vehicle as per my previous correspondence."
Stop booking it in for things. You are rejecting it.
Posted : 29/08/2025 11:02 am
As I said to TJ when he said the same, if they're now at a 'I want my stat rights' / 'I'm not giving you them' impasse then the OP has to escalate. Via S75/CC, they want an indie report. If OP went to a civil claim, then an indie report is going to be very useful. No harm in prepping for that in parallel to reissuing demand for refund under CRA2015
Re what to do next - For now, I'd send the email rejecting his suggestion of a warranty fix as per previous.
I would tell the CC company that is what you have done but this is last chance and if he does not refund then you will be progressing under S75, etc., and it's booked in for Weds in case he hasn't agreed to refund beforehand.
No harm in saying to him in clear terms this is final correspondence on the matter and if a full refund isn't agreed by ...... then you will be taking steps to enforce your statutory rights via other means. You don't have to say CC-S75 or civil courts, he should be able to work it out.
Those saying issue a LBA - I'm not sure know what an LBA actually is. It's not simply a letter saying that 'this is your last chance, next step will be action'. A LBA is a formal part of the legal process and at that point you then have to start following formal court rules etc., so isn't a trivial matter.
Posted : 29/08/2025 11:24 am
Posted by: theotherjonv
I'm aware what it is, and that would be my route to a resolution but now the credit card refund route has started that boat has sailed for now.
I'd be concerned what happens if the credit card co refuse the claim or offer back way less than you expect, you're into battling a bank then rather than a shady car dealer.
It was also why I asked if the car cost more than £10x because if it's less the small claim process is way easier that getting a proper, (expensive) lawyer involved as I understand it.
Posted : 29/08/2025 12:26 pm
Thanks all.
In the final letter ✉️ send him then shall I say other issues have been found such as the missing under tray and that should he fail to issues the refund under the CRA I have it booked in for an independent inspection and will be taking steps to enforce my stat rights via other means.
Just want to make sure it’s worded correctly.
Thanks for all the help guys it’s well appreciated
Posted : 29/08/2025 12:27 pm
FB-ATB reacted
No need to. KIS, you already made your case clear and that you expected a refund on that basis and nothing else.
Just reiterate that point and (my opinion) ask him again on what basis he feels that the CRA2015 / your statutory rights do not need to be met.
ie: make him tell you he is refusing to (which he won't, because he knows he can't)
The rest can be advised after the indie inspection, if it gets to it.
If it gets to it - I can't see why the CC co would reject, they are jointly liable and the case is clear. Only argument would be the deduction for usage.
Posted : 29/08/2025 12:42 pm
Either way, I really hope you get it sorted Renton, what an utter PITA. Let us know how you get on.
Posted : 29/08/2025 12:44 pm
Actually a LBA pretty much is a letter saying 'last chance, do this to resolve the issue,  by x date, or I may begin legal process to resolve '.  A Google AI generated description  is....
A Letter Before Action (LBA), also known as a "letter before claim," is a formal legal notice sent to another party to formally demand payment or resolution of a dispute before initiating court proceedings. It serves as a final opportunity to settle the matter outside of court, outlining the issue, the amount owed or the action required, a deadline for response, and the consequences of non-compliance, which typically include the start of court action. Sending an LBA is often a mandatory step under the Civil Procedure Rules (CPR) to ensure parties consider settlement and engage in pre-action conduct, though it can be a powerful way to spur the recipient into action and avoid costly litigation.
Posted : 29/08/2025 12:49 pm
My opinion, no. You made your case clear previously, just reiterate that and that you want a refund as per your statutory rights, this is your final correspondence.
Also my opinion, ask him again to clarify why he feels your stat rights are not applicable here (he won't, he can't, but just drives point home that he is breaking the law)
I wouldn't confuse further with other issues now, all was already clear cut. If he continues to reject you can include them as part of the third party inspection of what is wrong and what needs fixing (and what it costs)
Re the CC co not offering a refund....they're jointly liable as if you'd bought from them so same law and deductions apply - only thing they could argue is the benefit you've had from it, which is covered by the offered deduction; they might not be willing to negotiate on this over the inconvenience factor.
Posted : 29/08/2025 12:51 pm
I wouldn't mention anything else that you have found. When you hand over the car for the inspection, make sure *they* know, so then, when you get the report back, it will list all the issues you have found (and the dealer knows about) *plus* a load more of additional issues on top.
Posted : 29/08/2025 12:55 pm
Citizens advice page on LBA, which sets out what to say.
Problems with goods - letter before court action - Citizens Advice https://share.google/0fjDxlphHcafaB4z6
Posted : 29/08/2025 12:58 pm
(I demand a refund on the forum, glitches and posts not showing made me think it was lost so I typed it all out again)
Posted : 29/08/2025 1:10 pm
Just sent the email now.
Appreciate the direction.
Posted : 29/08/2025 2:00 pm
Latest reply from the garage:
Dear Steve
You made an agreement outside and that is why you took the vehicle back home. This is an act of accepting what we discussed and I will honor that agreement.
If this is not the case you would have left the vehicle and travelled back with your wife in the vehicle you came in.
Kind regards
Gregory Jackson
Posted : 29/08/2025 3:39 pm
@Renton you've not named the dealership so far but leaving the guys name above makes it very easy to find out. How poetic that you no longer trust this motor...
Posted : 29/08/2025 3:47 pm
What agreement, verbal or otherwise, did you make?
I'd suggest even if you did it is voided when the quality of the repair was revealed.
At least you now know why he feels you have accepted the repair option.
Posted : 29/08/2025 4:09 pm
And he did name the dealership, in the text of the letter.
Posted : 29/08/2025 4:10 pm
When I realised the headlight hadn’t been sorted I tried to reject the car again and he refused stating iit was sorted.
Then when I pointed out the actual issue he agreed it hadn’t been fixed and suggested that we take the vehicle and get a local garage diagnose and then he would approve a warranty fix.
Obviously I wasn’t happy with this but felt pressured and didn’t think we had any other option.
I did make him aware that I wasn’t happy with this and it wasn’t followed up by either party in an email.
The thing is as the further issues came to light with the turbo install etc I decided I didn’t want to do that.
Have I screwed myself.
Posted : 29/08/2025 4:17 pm
I have just replied to him referring him to a previous email that state me taking the vehicle does not constitute my acceptance of the vehicle.
Posted : 29/08/2025 4:20 pm
No, because the facts remain, he has had chances to fix it and has failed. You have made it harder, as others have said wtf did you agree to take it away when the situation was clearly not fixed? Why didn't you follow up any verbal agreement by email?
If it comes to a true impasse / legal case then before that you are expected to try to find a compromise and what he is now suggesting doesn't seem unreasonable tbh. Especially if you kind of accepted that basis. Except it doesn't deal with your lack of faith in the car now.
My instinct is S75 it through the cc company but you're going to have to be honest about what you 'agreed' and why you took it away again.
And in parallel get that indie report covering all its faults which you'll need either for the s75, or to make a claim, or opt3 to give back to the dealer saying that this is what needs doing and you'll arrange it as his garage is shit, and he can either pay for it or you'll small claims court it as the repair will be under £10k.
Posted : 29/08/2025 4:31 pm
“Dear Gregory,
I don’t recall agreeing to give my rights away. Please swivel.
Hope your chickens die,
Renton
x”
that should do it
Posted : 29/08/2025 4:48 pm
This is what I’ve just sent in return:
Gregory
I refer you to my previous email dated 22nd Aug where I state:
/ Given my lack of confidence in you, taking the car back does not constitute my final acceptance. If any of these faults recur, or new faults connected to the repairs occur, within the 6mo period after purchase I will consider that you have failed to meet your opportunity to repair and I will expect a refund as per the CRA
You refused point blank in person to accept my rejection of the vehicle whilst we were there when I pointed out the issues.
With us not being experts in UK law we felt we had no option to do anything else other than take the car despite point out numerous issues.
This isn’t for us to claim on the warranty this is your responsibility under the CRA to repair the vehicle in a timely manner with in the first 6 months.
Having driven the vehicle home with issues still occurring and other issues with the turbo replacement coming to light we are not going to get a diagnostic done on the headlight.
Given you have had the vehicle for 4 weeks to be able to do this and there are still issues that were mentioned in the original email you have failed to carry this out.
Again, also as per my email "If you do not agree to the above, I require in writing within 48 hours your explanation. Please included which parts of the CRA you feel do not apply, and why you are not obliged to provide me with my statutory rights as described above"
Kind regards
Posted : 29/08/2025 4:55 pm
Watty reacted
Even if I have screwed myself over the headlight the face remains that the oil and smoke issue and also the knocking issue remain.
They have attempted to diagnose the oil and smoke issue by replacing the turbo which hasn’t fixed the issue and has also thrown up further issues with the standard of workmanship
Posted : 29/08/2025 5:26 pm
do compo sad face for the local paper
Posted : 29/08/2025 8:06 pm
No you haven't undermined your case.   You've not given up your statutory rights and taking the car didn't incur extra costs for the garage.   You're fine, and doing well in the face of a very awkward garage who,  no doubt, have had lots of experience of similar and this isn't a stress for them.
Keep going
Posted : 29/08/2025 8:21 pm
Aside: given that I'm just up the road I'd appreciate knowing who the dealer is so that I can tell everyone I've ever met to avoid them. Feel free to PM me if you don't feel comfortable publicly name-and-shaming.
Posted : 29/08/2025 11:17 pm
It's in the big letter of yesterday, Motor Trust Bury, and almost £15k paid.
I just googled them and their Trust pilot suggests you aren't the only one to have had this experience....I'm increasingly thinking make it a CC S75 issue.
Posted : 29/08/2025 11:37 pm
Crikey, your car is still not fixed? I feel your stress.
How can a garage be so poor in customer service and fixing a car is still survive as a business.
What is the garage problem?  Sounds like they cannot even take a hit (loss making) for just one car.  If so their business must be bad.  I foresee the garage will not last long in current economy climate, if they cannot even fix a car.
I think once the car is "fixed" just sell it and get a non-turbo version boring but reliable Japanese/Korean car (they are generally  reliable, easy to fix but boring and not as good looking as the German brands).
Posted : 30/08/2025 12:16 am
I mentioned early on in the thread I'd been to this garage looking for a van sized people carrier. There was one missing all three rear seats and another in terrible condition at the back of the showroom with knackered electric doors and ripped seats. There were other cars in the sales are that weren't good.
Mentioned the place to my son and he had heard of their bad reputation. That's when I looked them up.
Posted : 30/08/2025 8:01 am
The garage doesn’t employ its own mechanics apparently and so everything that is requiring a repair is farmed out to ‘trusted’ garages.
I could give you the name of who did the turbo replacement but don’t think that would help.
The dealer manager who I have been dealing with is adamant that his trusted mechanic has done an excellent job of replacing the turbo and that he hasn’t done anything wrong. So far there is a loose hose flapping about, two bolts missing that I can see from the top side and the massive under tray missing. Coupled with this the car now has a whistle when the turbo kicks in, not loud like some cars but enough for me to hear with my dodgy hesring. If you google turbo whistle it says it could be either a boost leak or suspect bearings in the turbo.
He is also blatantly taking the piss with the headlight. I gave a very good explanation in the first email I sent to them back in July saying what I thought the issue was which is probably something to do with a headlight leveling motor. Originally he claimed to no know anything about this issue after 3 weeks of having the car even after me chasing a number of times and specifically asking about it. In the end all he has done has had the headlight beam alignment done and said it’s fixed.
As for the suspension knocking. I can still hear it over rough tarmac and bits of the road where there are different surface types.
The manager is so nonchalant and smarmy about it all. Refusing my rejection in person and claiming the car is fixed.
I felt really put on the spot and pressured to take it when we were up there. My wife bless is 6 weeks into a full hip replacement and offered to come with me so she could drive her car back.
Posted : 30/08/2025 8:21 am
from the trustpilot reviews, seems like they do this delay, deny, avoid stuff and trouble is, too many seem to have caved and ended up with 'in the end I just fixed it myself' type outcomes.
DON'T BE THAT PERSON, YOU HAVE LAW ON YOUR SIDE AND YOU ARE BETTER INFORMED THANKS TO ADVICE ON HERE
My inclination is to say that you don't accept his version as a solution, the car still isn't repaired so your statutory rights haven't been met. So you will now be referring to the CC company for a S75 chargeback, and follow that through. Then ignore anything else he sends unless it's an 'OK, I agree to the refund'
Posted : 30/08/2025 8:38 am
jp-t853 reacted
Oh dear,  with reviews like that it would seem they won't back down.  It's credit card or court.
At some point you're going to have to take the car back to them and hand back the keys. Is it worth speaking to the credit card issuer to see if you need to do that before they let you know the outcome of your claim?
Posted : 30/08/2025 7:32 pm
I’m not sure but I think if I get refunded by the cc I just have to make the car available for the garage to collect.
Let’s not get ahead of myself though !!
Posted : 30/08/2025 9:14 pm
I'm reticent to ask but.... any progress?
Posted : 03/09/2025 8:41 pm
No news really.
Garage haven’t replied to my last email.
Car is currently sat at a local vw/audi specialist for them to do the independent report. Was meant to be done today but two technicians were off sick so being done tomorrow hopefully.
Posted : 03/09/2025 9:30 pm
Just been and collected the car from the garage and now have a report. Doesnt make for great reading to be fair.
Suspension wise: The knocking is down to the one of the front shocks leaking and both lower control arm rear bushes delaminating. Both rear shocks are worn/weak and noisy in operation. Garage have said the shocks need replacing. As they are adaptive dampers this isnt going to be cheap.
Headlight: Levelling motor not working: Needs a new headlamp as the motor isnt replaceable on its own.
Oil usage and smoking: PCV system and solenoid have failed which is causing excessive crankcase pressure which in turn is causing the engine oil to be burnt off. This means the original garage have misdiagnosed the issue and the original turbo potentially didn't need to be replaced. The inspecting garage have also noted the missing bollts and undertray on the report.
Just need tro send this off to the credit card now and really keep my fingers crossed they accept it.
Posted : 04/09/2025 6:09 pm
Damn! That report is really bad!
Well.. Good for you but bad news for the moocher who sold it to you.
Follow process... Don't get emotional about it.. And you'll easily nail them to the wall.
That's utterly shocking.
They totally sold you a pig in a poke, and they damn well know it. They are just hoping you'll go away as I suspect they probably have form for this and have gotten away with it in the past.
Posted : 04/09/2025 6:21 pm
theomen reacted
I'd let the credit card charge back play out...
But I feel somewhat frustrated for you as going to court you could also claim back the costs of the diagnosis and dicking about...
I mean these are all faults that would be fairly apparent when they were prepping the car for sale..
Bloody thieves!
Posted : 04/09/2025 6:32 pm
The irony is that the car supermarket put it through a MOT before sale.
Posted : 04/09/2025 6:45 pm
Can shop them for that too
https://www.gov.uk/guidance/report-an-mot-tester
Posted : 04/09/2025 6:50 pm
Posted by: renton
 Might be worth reporting the MOT tester in question to VOSA at the same time - clearly a fudged MOT.
Call me a cynic - but I'd bet the 'car supermarket' use this 'friendly MOT tester' to push a lot of lemons out of the door.
EDIT:
The Vehicle and Operator Services Agency (VOSA) has closed. It's been replaced by the Driver and Vehicle Standards Agency (DVSA).
Posted : 04/09/2025 7:02 pm
ThePinkster reacted
shittinell
Did they give an estimate to repair?
I know as another poster has said, don't get emotional about it / I know what the mature response is - put it now in the hands of the CC company and let it run its course.
But at the same time they've been such a dick about it, I think you're entitled to now be a dick back, and at least make him sweat a bit.
Dear Gregory
As requested I took the car to a garage and asked for a full condition report. Given their findings I have asked them to formalise this for me including a cost to repair, but in summary they have identified the following:
<short list of all the faults>
Once i have this report I shall be forwarding along with our correspondence to appropriate parties in order to seek full recompense for the vehicle and additional out of pocket costs incurred in resolving this matter.
They also confirmed that the vehicle has clear faults that make it an absolute MOT failure, which make it unlikely to have passed prior to sale, and that the MOT tester should be reported to DVSA. Please confirm the details I have from the MOT checker are correct for the garage you use. <you can get this with Reg and VIN from https://www.check-mot.service.gov.uk/results?registration=WU19ZSZ+&checkRecalls=true>
Love and kisses;
Posted : 04/09/2025 7:46 pm
They haven't put a cost on it as its going to be quite a lot to sort. However they did say that if needed they could break it all down. I cant imagine adaptive dampers are going to be cheap.
Posted : 04/09/2025 7:57 pm
The year is 2854. The last traces of human civilisation are little more than dust, except at this garage where they are still disputing their liability over a shonky car.
Posted : 04/09/2025 7:59 pm
Section 75 might take time, but you will be successful. Good luck.
Posted : 04/09/2025 8:20 pm
Shocking, but your case is now very clear and strong, the Credit card charge back thing should be simple.  The card provider asked for the report didn't they?  If so id ask them to pay tne costs of it.   The other option i guess is small claims court to recover from tne garage.
The letter suggested by the other jonv seems about right,  other than asking for the reimbursement of the report costs.
Posted : 04/09/2025 8:21 pm
Posted by: neilnevill
And the time spent taking the car back and fourth @ minimum wage, £12.21 per hour.
Plus petrol
Posted : 04/09/2025 8:37 pm
Think I'd be tempted to drive it back to the dealership with all paperwork and keys and leave it there with him, stating as per correspondence you've rejected the car and expect the refund to be processed within the week.
Then just walk away.
He doesn't think you've the balls to go through with your rejection hence he's stringing you along.
Posted : 04/09/2025 8:43 pm
I agree.
Posted : 04/09/2025 11:36 pm
I agree.
I'd be careful... If the situation escalates you need to demonstrate you're as pure as the driven snow...
And show their actions to be in bad faith all the way along, which shouldn't be too difficult by the sounds of it.
Does it really matter where the car is? Having a standoff and them refusing to accept the keys back etc. won't help the situation.
The car is rejected and that's all that really matters. The garage can collect it at their expense, or the OP can deliver it to them via prior agreement & arrangement. There's no amicable relationship now, the relationship has irrevocably broken down.
Turning up, slinging the keys at them and stomping off, is probably not the best course of action.
Posted : 05/09/2025 12:22 am
I'm guessing Renton is still using the car though. If he's rejected it, should he still be driving it?
Posted : 05/09/2025 6:53 am
I don't think so.
Posted : 05/09/2025 7:08 am
Nope.
I’m not using it. I’ve literally driven it back from the car supermarket when they said it was fixed and the yesterday to and from the independent garage.
Struggling around to get a car to use within the family at the moment.
Posted : 05/09/2025 7:40 am
That must be very awkward but I think it's right not to use it.
Posted : 05/09/2025 8:01 am
Legally he can't. The indie garage has notified him of at least one, maybe more MOT failure points, so using it other than to drive to a garage to get it fixed would break the law. Insurance void, etc.
I'd add a comment to this effect to the bottom of my suggested response:
As I have now had it confirmed that the vehicle is not roadworthy (MOT failure faults) I am without use of the vehicle. Up to now I have managed to work around this at great inconvenience but I am not prepared to accept this any longer. I shall be hiring a car - I will of course minimise costs as much as possible - and I will be including this cost in any future claim I make against <garage name>
If you have a courtesy car you can provide in the meantime, I would be happy to use that, but note it would have to be delivered to me as i have no means to get to you to collect it.
even if the CC company refunds, I still reckon you can small claims for this (and the cost of the garage report, etc.)
Posted : 05/09/2025 8:17 am
Good point.
Posted : 05/09/2025 8:52 am
Car cost £15k so it's above the small claim ceiling. It'll be proper lawyer and court if the credit card don't come through.
Posted : 05/09/2025 8:59 am
They probably would though!
Be careful of the indy report if you've explained to them what's going on and why you want the report - there's a chance they'll add literally everything they can find to the report in the hope that they get to replace lots of stuff regardless of how 'worn'.
It's a used car and all parts are going to show wear but the question is whether that wear is within acceptable limits.
(I know the suspension on my car is worn but it still flies through its MOT's)
I'd be tempted to have it MOT'd again somewhere else without supplying any back story to see if the supplying garage have fudged the MOT.
Posted : 05/09/2025 9:24 am
Posted by: sharkbait
Why ? He's got plenty to go back to the vendor and the courts/claims, no point doing anything else unless he was considering keeping it.
Posted : 05/09/2025 9:34 am
Trouble with MOT's is they can be a bit variable/subjective. I know they're supposed to be held to a common standard but in practice,  they're often not. We all know of the dodgy garage locally that would pass almost anything. This doesn't help Renton, just beware.
Posted : 05/09/2025 9:35 am
Posted by: weeksy
Why ?
Because it could be argued [in court] that the indy has given a biased report in the hope that they get a fat repair job.  By having an anonymous MOT done it might give a fairer picture.
(if the indy didn't know the back story then this is all mute)
Exactly - two MOT's failing the car on the same things has more credence.
(and the headlight motor - it may well be frozen but if the light is still pointing within the target area for the MOT then it's not a fail)
Posted : 05/09/2025 9:48 am
 irc
If a headlamp motor is fitted it needs to work.
"Vehicles with high intensity discharge (HID) or LED dipped beam headlamps may be fitted with a suspension or headlamp self-levelling system. If these systems have been fitted, they must work."
https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-5
Posted : 05/09/2025 9:53 am
Posted by: irc
ahhh fair enough 👍
Posted : 05/09/2025 9:56 am
I'm not talking about small claims for the cost / refund of the car, that's a statutory right that the garage, and CC co because of the fact he used a CC for part of it*, are jointly liable for.
I'm talking about incidentals that are being incurred because of the garage's inability to resolve this quickly.
Headlight motor covered above and I flagged that several days ago, but makes this a clear MOT fail / illegal to drive / uninsured and just strengthens the need to rent or be given a courtesy car instead.
* another reminder for all, especially those that 'will never buy anything on credit' that there are some reasons to do it, even if you then pay the bill off at the end of the month.
Posted : 05/09/2025 1:10 pm
Page 2 / 4
