Formula 1 2025 – WI...
Formula 1 2025 – WILL CONTAIN SPOILERS
 wonder why they bother making them
From what I have heard, the drivers wonder this as well
Posted : 28/07/2025 10:27 pm
Posted by: chrismac
I don’t understand why the start was delayed. Surely if it was that wet the grid should have been on wets not inters. I’m being to wonder why they bother making them
The issue isn’t the (lack of) standing water on the track - if it was then using wets would be compulsory. The issue is where the water goes that the tyres (and the rest of the car) lift off the surface. And visibility is drastically reduced or disappears altogether.
Put that together with several fatalities that have happened at Spa in recent years, and bear in mind the potential legal consequences for the organisers of it goes wrong, then nobody with common sense could blame them for being a bit cautious.
Everyone that is moaning online that they should just get on with it don’t have any responsibility for anyone’s safety, and don’t have any consequences (legal/criminal?) if it goes wrong. I’m sure it’s very different if it’s your neck on the line.
Posted : 28/07/2025 10:33 pm
 Bez
The reason they rarely use extreme wets these days is because the cars have such extreme aerodynamics. Once there’s enough water to warrant the full wets, the spray has already gone way into dangerous territory, because the ground effect cars lift a huge amount more water through the Venturi effect of the floor. Given those factors, Spa is the most dangerous track on the calendar because of Eau Rouge and Raidillon: there’s so much downforce on tap that they’re still barely a lift in the wet, but there’s a relatively high chance of losing grip, especially on the first lap or if the track is getting wetter—and if that happens it’s a big one, with the cherry on the cake being that there’s also a good chance of ending up in the track with cars approaching at knocking on 200mph with zero visibility. And then you’ve got Antoine Hubert’s mother watching the race from the pits.
It would have been great to see Verstappen and Hamilton exploiting their setups for longer before the track dried out, but I think it’s pretty naive to criticise race control for being a little conservative on this specific occasion. If the whole of the circuit was like sector two then things might have been different, but sector one is a uniquely dangerous stretch of race track.
Spa aside, fundamentally it’s a problem that won’t go away while the formula has ground effect, and probably won’t go away at all in any heavily aero-dependent formula.
Posted : 29/07/2025 8:47 am
Posted by: Bez
Plus the F3 race was red-flagged twice as they crashed into each behind the safety car. I think they made the right decision
Posted : 30/07/2025 8:14 am
It's pointless asking the drivers about the conditions because anyone that's gambled on a dryer setup will always be crying on the radio "conditions are too wet, visibility is bad, it's too dangerous" and anyone taking a full wet setup will say "it's perfect, let's race".
Having watched back through the coverage, I think they were a little overly cautious. We lost probably 20/30/40 minutes of good inters condition racing there. Mandate the full wets and send them out behind the SC to clear the standing water, then let them race.
Posted by: nickc
Yeah but the F2 did race in similar conditions to the F1 race, probably worse (and I'm glad they did because it was brilliant, go and check out Alex Dunn's move in Pouhon if you haven't seen it)
Posted : 30/07/2025 10:18 am
It's silly to criticize with hindsight - I think the race director was right to be conservative about the start, there's a good chance of a huge multi-car accident if things go wrong.
Verstappen and Hamilton both wanted to start earlier, when the track was wetter. They both had cars set up with more downforce for wetter conditions. Other drivers who had lower downforce setups seemed to think it was better to have waited. Teams and drivers will always argue for whatever suits them in the moment, then they'll turn around and argue for exactly the opposite when that suits them.
Posted : 30/07/2025 11:27 am
Posted by: thols2
THis is where if they are going to do this I think teams should be allowed to change the set up of the car. If you set the car up on the assumption that ovet half the race was goign to be under wet conditions on inters and then race control say oh perhaps not, lets wait for the weather to get better then you are no longer having a fair race. All that will happen is that everyone will turn up on the start line with a dry set up and assume race control will give into them wanting to race with the wrong set up.
Posted : 30/07/2025 1:27 pm
 jca
Tricky to allow setup changes - are they going to guarantee enough of a delay to change a rear wing, as well as suspension setup etc.
Posted : 30/07/2025 1:47 pm
All the cars at the front had to choose their setup on Saturday based on their best guess about the weather. There was zero guarantee about the weather. McLaren got it right, Red Bull didn't. Wet weekends are always like that - some teams get lucky, others get unlucky.
At the back, four cars chose to start from pit lane so they could take a new power unit and make setup changes overnight. I think they were allowed to do that right up to the warmup lap, but nobody is going to tear the car apart to do anything major just before the race starts.
Posted : 30/07/2025 2:02 pm
A timely article!...
https://www.planetf1.com/features/why-formula-1-must-abolish-out-dated-parc-ferme-rules
Posted : 30/07/2025 2:05 pm
Doing away with parc ferme would ensure that there were always 20 cars on the grid (which I don't personally care about), but it wouldn't have made any difference to teams who went for a wet weather setup being caught out. Ferrari chose that for Hamilton on Saturday and could have changed it on Sunday morning, but didn't. They wouldn't have had time to change it once they learned that the start was delayed, it was locked in on Saturday night.
Posted : 30/07/2025 2:22 pm
Posted by: chrismac
So then you’ll get 20 cars with the same setup and hardly able to pass each other.
Not allowing changes adds to the jeapordy. All teams have the same info and can decide what they want to do. It’s part of the game!
Posted : 30/07/2025 5:47 pm
For Spa specifically, would it not be beneficial to have a "wet weather only" chicane in place at Eau Rouge?
So, at race controls discretion, they could change the circuit layout to use/stop using the "chicane layout" and revert to the full Eau Rouge experience when the track is "dry enough".
I'm musing that switching layouts would prevent huge crashes in low visibility in Eau Rouge but when the visibility improves, we get the full fat experience...
Rather than ask a brave marshall to run on track during the race with a couple of orange cones, theyd have to install some lights/arrows to point out which part of the circuit to use at switchover point. And, yeah, inevitably some driver is likely to get screwed when they are forced to use the chicane by virtue of their position in track at switchover point versus the car following or just in front of them but that's no worse than the safety car being deployed just after you've passed the pit entry.
BTW, I've patented this idea so don't try to claim my genius idea 😄
Posted : 30/07/2025 6:16 pm
I see Fred Vasseur is now confirmed as having a contract extension to stay at Ferrari and it seems Max won't be able to trigger his escape clause from RB even if he wanted to. Looks like this year's mid season break is going to be a bit quiet after all - unless we get leaks from RB about why they axed Horner.
Posted : 31/07/2025 9:03 am
Yep, confirmed!
Posted : 31/07/2025 9:12 am
 Bez
Edit: doh! Half wrote this before a work call, hit “post” after it, clearly should have updated the page in the meantime 😂
Good to see that Ferrari are trying to prevent people rocking the boat
https://www.formula1.com/en/latest/article/ferrari-hand-vasseur-new-multi-year-contract-to-continue-as-team-principal.5RIg7O4nudaiWncjPjjB7g
Posted : 31/07/2025 9:27 am
Posted by: vlad_the_invader
....... No!
Posted : 31/07/2025 9:28 am
Posted by: the-muffin-man
I don't understand the point they're trying to make in that article at all. Seems to have real been in their bonnet about a full grid, which I can't say has ever excised me at the start of a GP ever, and wants poor qualifying to be punished...which starting in the pit does, and wants to be able to make set up changes...which they can do, but again start from the pit lane (which, again is a disadvantage)
Weird. Have I missed something? (entirely possible)
Posted : 31/07/2025 9:52 am
 Bez
Posted by: nickc
They lost me when they used “myriad” as a noun instead of an adjective.
I think there’s a viable argument for making front and rear wing changes without a pit lane start, though equally you could argue against. Otherwise I think it’s fine as it is.
Posted : 31/07/2025 10:25 am
I think it boils down to...
• It was bought in to save costs - to stop qualifying cars and engines.
• The cost cap does that now.
• If it was scrapped it would open up more strategy options.
I must admit I don't like it when you know a driver is guaranteed a shit race because of a set-up error before qualifying.
Set-up changes should be allowed, but not big items like engine and gearbox.
Posted : 31/07/2025 10:42 am
Joe Saward mentioned this article in his blog. Pretty brutal report on Flav's history of dodgy shit.
https://unlimitedhangout.com/2025/07/investigative-series/first-friends-part1/
Posted : 31/07/2025 2:06 pm
Thomas Maher (planet f1 journo) reporting Max confirmed at Red Bull
Posted : 31/07/2025 4:15 pm
How long before they become a Honda works team?…
https://www.planetf1.com/news/aston-martin-valued-at-2-4-billion-as-car-company-sells-out-of-f1
…Aston back to being a badging exercise.
Posted : 31/07/2025 7:59 pm
 Chew
Doesnt Lawrence own them both?
I'm sure its just a business/tax/funding issue rather than anything more.
Posted : 31/07/2025 8:48 pm
Posted by: multi21
BBC are saying the same too.
Posted : 01/08/2025 5:16 am
Max's escape clause is only triggered if he is outside the top three by the summer break. All that Russell had to do to keep his seat was not be ahead of Max by that point.
Posted : 01/08/2025 5:21 am
I'm kinda gutted in a way, because I was looking forward to seeing what he could do away from the RBR stable.
Posted : 01/08/2025 9:07 am
Who do we think is most relieved to hear that Max will stay at RB - Laurent Mekies, George Russell or Issac Hadjar?
Also, what is Stroll doing in P4 in FP2? You can never tell with him, whether he's going to embarrass everyone else or himself
Posted : 01/08/2025 7:24 pm
 Bez
I’m not sure Hadjar would be have any reason to be disappointed if Max were to leave. A seat alongside Yuki is not the poisoned chalice that is a seat alongside Max.
Posted : 01/08/2025 10:19 pm
So... Thoughts on Lewis' comments post qualifying? Sounds like a broken man.
So much of driving a car fast is about confidence and self-belief and he seems to have lost his mojo (especially as Charles managed to put his car on pole)
Posted : 03/08/2025 7:57 am
Yeah, Hamilton just seems lost at Ferrari, he'd had a dip at Mercedes, not sure how much of it is due to the ground effect era. But it's the same for all the drivers.
Posted : 03/08/2025 8:09 am
 Bez
It’s not even just the low itself, it’s also an astonishing swing from him saying recently how determined he was not to leave Ferrari without a title, like Alonso and Vettel did.
It seems that, just as Red Bull chews up and spits out rookies, Ferrari chews up and spits out champions.
He’ll get over it, I’m sure: he wasn’t that far off Leclerc in Q2 and no-one seems able to explain how Leclerc ended up top in Q3—so a lot of this is just small differences creating a perfect storm. But from what I recall seeing, Hamilton did look to be fighting mid turn oversteer quite a lot, so that clearly seems to be a thing he’s still not getting on top of.
Posted : 03/08/2025 9:14 am
To put things into context it was the closest top 10 qualifying for 64 years. So even ‘useless’ Lewis was only a few tenths off a decent grid position.
Having said that do you think we’ll see him after the summer break? He did say there would be a lot of tears.
Posted : 03/08/2025 9:47 am
Pretty sure he'll be back after the summer break.
If he's put in front of the press and gets asked "Charles is on pole, and you're 12th, where did it go wrong?" Being chipper and upbeat would be a struggle.  Fred will be massaging his ego straight after the press duties.
Posted : 03/08/2025 10:14 am
Hamilton has always been a bit emotional in the heat of the moment. At Merc he'd often sound like a whiny brat on the radio. Then he'd cool off after the race and everything would go back to normal. After the summer break, all the teams will be focusing on the new regs for next year. I'm pretty sure Hamilton will want to stick around long enough to see if Ferrari have a competitive car or not.
Posted : 03/08/2025 1:04 pm
Lovely win by Lando there, way more exciting than a Hungary GP deserves to be, really nail biting stuff. Loved it!
Posted : 03/08/2025 5:38 pm
Yep, fair play to Lando for coming back for the win. Expected Piastri to breeze past him with the tyre advantage, so pleased Lando held on to it.
Posted : 03/08/2025 7:26 pm
Yeah good race.
George Russell is such a knob.
Posted : 03/08/2025 8:38 pm
chrismac and bruneep reacted
 Bez
So, what do we make of this intriguing remark?
Pushed on whether he is finding it difficult to pick himself up, and whether he could help viewers understand his remarks, Hamilton said: “Not particularly. When you have a feeling, you have a feeling. There’s a lot going on in the background that is not great.”
(source)
Posted : 04/08/2025 8:31 am
Wonder if he's talking about within Ferrari or in his personal life
Posted : 04/08/2025 8:47 am
Posted by: Twodogs
Within the team I'd say.
I'd put my money on him not being made welcome by some elements within Ferrari. He'll have ruffled a few feathers and my guess is people are digging their heels in and refusing to change their way of working. They'll see him as a temporary hire that got another latin driver the sack.
The grand arrival and Lewis being off the pace won't be helping his cause.
Posted : 04/08/2025 9:03 am
Posted by: Twodogs
Yeah good race.
What did he do?
All I saw of him was a bit of moaning about Leclerc moving under braking which was valid, and talking about Ferrari running a marginal ride height on Charles car which also looks like it was correct.
Speaking of which, I reckon Hamilton will be less bummed out when he hears about that. Charles would have had a lot more downforce yet Lewis was only two or three tenths off him in Q2. Okay so it was a very costly couple of tenths but still, not as bad as it looked.
The "things going on in the background" comment was intriguing though. Wonder if somebody told him to wind his neck in with the documents he's been giving out or something like that.
Posted : 04/08/2025 9:46 am
Millionaire F1 driver being a whiny ****. I'm shocked. SHOCKED!!!
Posted : 04/08/2025 10:29 am
Posted by: multi21
Posted by: Twodogs
Yeah good race.
What did he do?
He's always super quick to get on the radio to try and get other drivers penalised. I don't like it when any driver does it, but he seems to do it more.....even Leclerc has commented on it... “But I can imagine George being quite vocal on the radio, it’s normally the case.”
Posted : 04/08/2025 11:01 am
Out of interest, is anyone using Gridlock?
https://www.gridlock.one/
Posted : 04/08/2025 11:15 am
Page 23 / 33
