So -Steel FS bikes....
[Closed] So -Steel FS bikes...
[#3570258]
...Why not?
The thread discussing Cotics new bouncer the other day got me thinking, why hasn't steel really been generally considered the optimal mateirial for FS bikes?
I know it's a generalisation but I can only think of a handful of FS bikes that used steel:
Keewee Chromo 8
BMW Mini/Race link
DMR bolt
Balfa BB7 (did the Avent version still use a steel back end?)
Curtis Thumper cross? (Rissie racing aluminium back end?)
They all seem to have been intended for more Ruffty Tuffty Gnarcore/DH riding too.
Given that steel HT frames have come back into favour over the last 8-10 years or so, can anyone offer a compelling reason why Steel bouncers don't seem to have so much appeal?
Posted : 16/01/2012 2:23 pm
I would imagine that they'd be bloody heavy! Also, isn't the main argument for steel that it has a bit of give so is more comfortable? On a FS you have a shock that deals with that so I'd imagine it's not an issue.
Posted : 16/01/2012 2:24 pm
I can't think of a single reason why you would use steel in a full suspension bike.
Posted : 16/01/2012 2:26 pm
Xprezo have a range of them.
Really just like that then, a total non-starter for most people then?
I'd have thought that steels ability to offer some compaliance was an advantage, no shock is perfect (well some might be).
It's (arguably) more easily repaired than aluminium and has a very good strength to weight ratio.
I was under the impression you could still make a sensible weight HT frame from steel, why not an FS?
It just seems strange to me that the massive Lob-on people have for steel HT frames doesn't extend to FS bikes...
I'm just questioning the recieved wisdom that steel is not the appropriate material for building FS bikes...
Posted : 17/01/2012 10:04 am
Some people get a 'lob-on' for steel for its supposedly magical ride properties (which only a few steel bikes actually have to any real degree). The other major benefit is it's typically cheaper. The former is irrelevant if you're designing a FS, the latter arguably less so too if you're already spending £1k on a frame.
A FS frame made of steel would typically be very heavy or flexy, neither of which are really desirable 🙂 If you used the lightest steels, then you could get the weight down a bit but it'd then be seriously expensive.
Posted : 17/01/2012 10:08 am
I can't see a problem with it but I don't know why anyone would buy one unless there was a significant cost benefit. Steel is cheaper to buy and weld isn't it?
Posted : 17/01/2012 10:11 am
Some of the statements on this thread are wrong, just plain old wrong. You could do with signing up to the Cotic newsletter as Cy has done a wonderful explanation of why he has used steel for the Rocket. His logic is exactly the same as why we have used it for our full sus, although we have the added benefit of ease of manufacture in small runs/custom applications.
Steel does make sense for several reasons but only for certain types of frame. If you want an ultra-lightweight short travel frame then steel is not going to be the best option, but then again neither are most of the other materials available depending on what other criteria you throw in. Carbon is too expensive and can't be recycled (easily), aluminium isn't light enough, ti is too expensive. I don't think anyone (Cotic, Us or any of the other manufacturers mentioned) are trying to say that steel is the best option for a full sus frame, it can be in certain situations and is just another alternative
Matt
Posted : 17/01/2012 10:17 am
Steel gives more options for custom build (no heat treatment etc)
I think this is what you want:-
http://www.wiesmann-bikes.de/
Posted : 17/01/2012 10:18 am
I always wondered the same about that Litespeed Sewanee: could they have made it rde just the same and weigh just the same if they had used an aluminium alloy?
Excluding al the argos and motorworld specials, there was also an all-steel identiti dh bike a few years back.
The back end of the K9 dh bike is steel IIRC. If there wasn't such a stigma around welded/repaired frames (of any material) I wonder if a lot more DH frames could/would be all steel, or have steel in the parts of the back end that are more prone to failure from prolonged radness.
Posted : 17/01/2012 10:19 am
I believe the K9 is the other way round actually, steel front and aluminium rear end
Posted : 17/01/2012 10:22 am
I'd have thought the cost of casting/machining steel for pivots etc and weight involved in that would be the killer?
Also easier/cheaper to make stiff light frames in alu - letting the shock do the job, not the material.
Posted : 17/01/2012 10:23 am
 loum
clubber,
I disagree. Aluminium frames are now cheaper than quality steel frames to produce. This is the major reason for their predominance.
The other reasons stem from marketing rather than engineering.
It is a complete fallacy about the stiffness of aluminium.
Steel is both stronger and stiffer than aluminium. The key to aluminium frames' percieved stiffness is the tube diameter, not the material.
edit: just read the posts between, and pretty much agree with what they've already said
Posted : 17/01/2012 10:24 am
It's amazing how the preconceptions people have about certain materials (mostly due to marketing bo**ocks..) shape their views isn't it...
Rather than actually looking at it from a materials/physics/engineering point of view and the *actual* properties of the materials in question and then how those properties change when you arrange them in certain ways.
It is never as clear cut as:
Alu = stiff = harsh = light
Steel = bendy = comfy = heavy
There is a LOT more to it than that, and you can show any number of frames/designs where the opposite is true, or at least the lines are blurred.
(EDIT - looks like a few people already replied while I was typing that ^)
Posted : 17/01/2012 10:28 am
sunn radical:
yeah, steel bouncy bikes are crap.
(if you don't know anything about the radical, go and do some homework)
Posted : 17/01/2012 10:29 am
Beaularks to all that mechanical engineering stuff. The best thing about steel is that you can clearcoat over the raw welds and end up with a frame that looks like it was forged on Vulcan's anvil. 🙂
Posted : 17/01/2012 10:30 am
but steel is????
anyways, I'd like one of these when I win the lottery:
Posted : 17/01/2012 10:31 am
but steel is????
I was meaning compared to carbon. It is perfectly possible to build a steel frame that is the same weight as an equivelant aluminium frame, but only in certain frame types. This is why the steel full sus out there is generally longer travel as the benefits of steel really come into play and the drawbacks are reduced. If wieght is your main concern, buy carbon, if it's not, buy something else
Posted : 17/01/2012 10:39 am
clubber,
OK, the cost thing may now be not the issue.
As to the other I fully understand the 'stiffness' of aluminium but the problem here is that in getting a big tube with steel at a reasonable weight and price, you're talking very thin tubing which then becomes fragile from loads outside of actually riding. Basically, you take one of the benefits of steel (eg the ability to design more flex in without premature fatigue failure) and turn it into a disadvantage - at least according to conventional suspension wisdom where you want stiff frame/linkages and all the movement to be provided through the pivots.
oh, and this:
is spot on
Posted : 17/01/2012 10:40 am
I agree with that actually and if you look through my posts (and even my first comment on this thread) you'll see that's the case. I suppose the only caveat I'll add for clarity is that my initial comments are directed more at the less-gnarlcore end of the riding spectrum. As stated above, if weigh is less of an issue and strength is critical then steel can have a role to play and in some areas be advantageous.
Posted : 17/01/2012 10:43 am
and even that's wrong:
steel is stiff.
aluminium is flexy.
(i'm sorry, but someone had to say it...)
Posted : 17/01/2012 10:45 am
Exactly. Kind of 🙂
Posted : 17/01/2012 10:46 am
You don't necessarily need a big tube, though. Because the material's stiffer.
Posted : 17/01/2012 10:50 am
Also, what is considered a 'big tube' for steel would be a small tube for aluminium so even though we are using a huge (by steel standards) downtube for our full sus, it still looks small compared to most aluminium frames. The weight gap is not as big as people imagine it is so a steel frame can end up being stiff enough, plenty strong enough and still at a weight that is acceptable
Posted : 17/01/2012 11:03 am
 D0NK
RudiBoy - Member
cool didn't know Brooklyn did folding bikes.
Posted : 17/01/2012 11:05 am
The main point of titanium FS bikes, as far as I can tell, is that they are made out of titanium. This is a property that no other material has. No other material other than Titanium lets you make a titanium bike.
Steel is similar to this in many ways.
Posted : 17/01/2012 11:06 am
 D0NK
Aren't they going to be pretty light but plenty strong and able to shrug off rocks strikes (all other things being equal) and generally be around for quite a while?
Hellish expensive tho yeah.
Or am I believing marketing hype (again)
my ali FS bike is already "too heavy" so even if it's a small gain I don't want to be pedalling it around all day, not as much of an issue for more gravity stuff I guess. Haven't lusted after a steel FS since the orange X2 (I was young and stupid)
Posted : 17/01/2012 11:09 am
You guys are missing another big factor! Life cycle. Aluminium frames have a much shorter life cycle, ive cracked several over the years. Steel frames are for life. If you put a crack in it re weld it and get out on it again. Yes, you can re weld alu but there's all sorts of issues about heat treating, etc. Steel is for life!
I don't have any experience of the bike industry, but I have spent plenty of time looking at materials substitution across many industries using structural metals. It's actually quite a complex discussion, and the trade off's are likely to be between manufacturing aspects and bike performance..
But if you can get a handle on the engineering aspects of your steels, titanium alloys and aluminium alloys, and decide which are the msot important for your application/market/cost base, such as (and this is not an exclusive list):
Material grade
Density
Tensile modulus
Yield strength
Beam bending
Effect of change of section modulus on Specific stiffness
Fatigue
Corrosion
Available finish
Fracture toughness
Heat treatment
Weldability
Effects of welding on yield stress and fatigue
Post weld heat treatment
Machinability
Formability
Cost and availability of raw materials
Cost of manufacturing process (material and grade chosen will have a large effect on this.
Experience/training of manufacturer/workforce
and finally
FASHION.
Then you will be able pronouncements on which is better.
I have no doubt that you could easily make a steel FS frame as good as an aluminium one but I would wager that the major reasons why aluminium is more prevalent are:
1) Fashion/marketing
2) Fashions knock on effect in the industry where most production outfits are geared up for aluminium manufacturing, so to make a production run of quality, competitive steel FS bike will be more expensive as the availability of mass production machines/workers/facilities is less..
Oh and this
brant - Member
Posted : 17/01/2012 11:11 am
just zip tie a bit of tyre to your down tube if you're worried.
Jeez... who wants a frame for life? Doesn't sound much fun. Buying new things is FUN.
Posted : 17/01/2012 11:17 am
How much do the 18 bikes steel FS and cotic rocket frames weigh (w/shock)?
Posted : 17/01/2012 11:18 am
Never said [b]I[/b] wanted it for life..
Would be nice to be able to sell it on rather than scrap it.
Im sure that's partly why big manufacturers make them from Ali. Short life cycles = sell more frame = more $$$$.
Posted : 17/01/2012 11:20 am
Steel seems to be very much in vogue at the moment, a lot of people like the look of skinny tubes and having just bought a steel hardtail, the ride characteristics are a revelation to me, so I don't see why a properly designed steel full suss shouldn't be viable.
I agree that fashion/marketing is the driving force however.
Posted : 17/01/2012 11:23 am
ska-49 I used to think the same way about steel lifetime, but as Brant [url= http://singletrackworld.com/forum/topic/any-mechanical-bike-engineers-in-the-house-opinions-needed#post-1064383 ]once said[/url] in response to my pushing this idea on this forum: (I'm paraphrasing from memory) he has never known of a bike frame that was designed below the fatigue limit, it would be very heavy if it was.
Therefore the lifetime argument is not relevant here..
Potentially this also means the steel feel argument is also a red herring..
See [url= http://singletrackworld.com/forum/topic/metal-fatigue ]also[/url]
Posted : 17/01/2012 11:25 am
I often wonder why no one presses things in steel ,well I dont but it would be nice for some things.
Can we readress the old chestnut ? chinese manufacturing thing they do things in a certain way
I have a clever calculator that does just what CY explained in his little write up you can simply compare tubes.
Comparing an apple to an apple steel tube x dia and y wall against a carbon tube x dia and y wall doesn't give you a carbon tube that has any advantages to get the same properties as an 853 down tube your wall is 3.5 times thicker in the centre compared to the thinnest section(in fact for certain fibre types steel is stiffer at the diameters being used in steel frames)
Posted : 17/01/2012 11:33 am
So it wont be as stiff, strong, or light as an aluminium frame?
I think the point is you can't make a 4" diameter steel downtube like you can an aluminium (or carbon) one. So while steel is stiffer on paper you're forced/able to use much smaller tubes, which aren't as stiff.
In MTB's we seem to have been drawn towards 853 by the marketing, look at BMX's (and some dirt jump frames) and a lot more frames make a bigger deal about the headtub/dropouts/BB beeing heat treated, or the whole frame being 100% post weld heat treated.
Yet we're also convinced that aluminium must be heat treated, when IIRC it's only certain alloys that do and plenty of popular frmes have been built from alloys that haven't required this. (Mountain cycle and 6000series alloys spring to mind but don't quote me on that).
I'd buy a cotic rocket if I didn't already have a similar FS and could justify the premium(ish) price. But then I'd also buy a gaff rigged sailing boat, or a rigid 29er mountainbike, knowing that there are better performing options, but sometimes it's the little things and the quirks that make you happy.
Posted : 17/01/2012 11:53 am
That's more like the debate I was hoping for.
My original point was that with some rare, notable exceptions, the entire history of FS bikes has been Aluminium and more recently Composites.
Many other industries have been the complete reverse of this Steel has only been partially displaced in Automotive and Civil engineering relatively recently, and the work done there to create strong, light efficient structures using steel has been very significant.
I'll be honest it wasn't a well phrased opening question really, I'm not expecting anyone to tell me the next Anthem will be made from steel, but like I said in my OP the Cotic Rocket was the frame that got me thinking again, probably because its a 7.2Lb, 150mm, Trail/AM type bike made ~70% from steel (or at least from what I can gleen), to my mind it sounds like a reasonably good bike on paper...
We've sort of become the natural home of the Steel HT (The UK I mean) in recent years with a few companies popping up who've built some expertise in the design and construction of bikes made out of the steel; I'd contend that the little bit of knowledge/experience over which stock tube has the right balance of wall thickness, and diameter to give you the flex/stiffness, weight and weld area for a given application is sort of dropping off the radar for many bigger companies where it's become more and more Hydroformed Aluminium or CF monocoques and big batch numbers, I think it's where we might have a chance to excel and dare I say it lead, so I wouldn't discount applying those expertise to an FS bike or two...
Posted : 17/01/2012 11:55 am
 was
Orange's first FS bike was steel - the X1. And it was "fully floating"!?
Posted : 17/01/2012 11:59 am
^^^^ rubbish.
Posted : 17/01/2012 12:01 pm
Have a look at Cy's lectures on youtube that he gave at Sheffield Uni. He makes the point you make big solid components (like trains) from steel as it's strong and the stiffness is adequate even when you use the minimum ammount required to make a strong component. But at the oposite end of the scale on bikes if you made it strong enough and light (his prototype 953 soul for example) it's not stiff enough. Where aluminium alloys alows you to be more efficient as you need the same ammount of material to be stiff and strong enough (so you add less weight making it stiffer/stronger once youve reached the minimum required to meet the other criteria).
Posted : 17/01/2012 12:03 pm
^^^^ rubbish.
Are you 100% sure?
When I was at Mountain Cycle they were definitely heat treated.
Posted : 17/01/2012 12:06 pm
Page 1 / 3
