How do I set up a 3...
[Closed] How do I set up a 3 speed shifter for 2 speed
4 Users
Sorry, dumb question.
How do I set up my 3 speed XT front shifter for 2 speed.
cheers
Posted : 11/09/2011 9:02 am
Play with the front mech stop screws.
Posted : 11/09/2011 9:06 am
 mrmo
the way i set it was small chainring in the small ring position, big ring in the middle ring position, then set the limiter on the front mech, so whilst you can push the shifter towards the big ring position the front mech won;t allow you to pull the cable.
hope that makes sense.
Posted : 11/09/2011 9:07 am
assuming you have inner and middle position rings. set up inner as per normal. then dial in fr mech top screw to stop shifting to outer position.
Posted : 11/09/2011 9:08 am
cheers,
Will this stop there being 3 clicks, if you know what i mean. Will you get enough adjustment out of these limit screws?
Ta - I am a total newbire to this 2 x 10 thing, so have never paid any notice to how you change to it before.
Posted : 11/09/2011 9:09 am
Cheers all,
So as it stands I can just by a 2 x 10 slx setup and just adjust the front mech. No other parts required?
Posted : 11/09/2011 9:10 am
Just buy the rings and some spacers and wind in the screw.
Posted : 11/09/2011 9:13 am
cheers all
Posted : 11/09/2011 9:24 am
