Horizontal sliding ...
[Closed] Horizontal sliding dropouts how do I mount rear mech
As per title I've got a Cotic Roadrat with an 8 speed Alfine rear hub which I'm thinking of converting to 1 x 11.
The frame has horizontal sliding dropouts so was wondering what I need to do to allow me to fit a 11 speed rear mech and ideally bolt through axle without having the frame modified?
Posted : 28/01/2021 6:58 pm
Just push the axle all the way to the front of the sliding dropout and clamp it in place. Fit your derailleur hanger and away you go. This was with a regular qr wheel mind. You might need to adjust the brake caliper position too.
I emailed Cotic to ask as I was in the same position as you.
Posted : 28/01/2021 7:22 pm
Similar vein to the above but possibly in stock is the sun xcd one. No idea if it works but spotted it a while ago and have no need for it.
https://www.velovitality.co.uk/collections/transmission/products/sunxcd-horizontal-dropout-mech-hanger
Posted : 28/01/2021 10:05 pm
I’m using something very much like that on an old road rat. A bit annoying when the rear mech escapes as you take the back wheel off but you get used to it.
If you can convert your hub to take it a 10mm ‘through axle’ makes it easier to get the wheel out if you use mudguards- take the axle out and the wheel can drop down.
Posted : 29/01/2021 12:29 am
Cheers guys afew options for me there to explore.
Posted : 29/01/2021 8:03 pm
Cotic did used to sell a tensioner & hanger combo for the Roadrat.
No idea if they have any in stock anymore, but might be worth emailing them.
This one:
Posted : 30/01/2021 1:36 am
