Dt Swiss end caps h...
[Closed] Dt Swiss end caps help
[#11722553]
Replacing a microspline 3 pawl freehub with a standard Shimano one and of course the end cap is different. Can anyone tell me where I can buy an end cap for this combination of Shimano, boost, 12mm?
Anyone got one in the spares box I can buy?
Posted : 28/01/2021 6:24 pm
Would boost and non-boost end caps be the same with the difference being only in the hub body itself?
I'm currently on the 3 pawl Shimano HG but was thinking to switch to XD freehub to finally replace out my Sunrace 12spd cassette with GX cassette
Posted : 28/01/2021 6:29 pm
Possibly, my searching has only found 142/12 so that may be the answer. But looking at the prices I think I'll return the freehub. No way am I paying 30 quid for an end cap.
Posted : 28/01/2021 6:34 pm
I don't know that this is true but IF the end cap is the same as you get with a XD driver AND there isn't a difference between the caps for boost and non-boost,...
I'd merrily swap one of those for your oldskool one
(and happy to swap by post and then swap back if mine's no good to you - unless you live near Southampton when we can throw them to each other from a safe distance 😀 )
Posted : 28/01/2021 6:49 pm
The boost adapter kit DT Swiss do has a new non drive side spacer but retains the drive side one, so they may we’ll be interchangeable.
Posted : 28/01/2021 9:44 pm
142 and 148 end caps are the same but driver specific.
Posted : 28/01/2021 9:48 pm
I'd swap you a new shimano hg driver and endcap for your microsokine one if you don't mind waiting for Canada Post/royal mail 😉
Posted : 28/01/2021 9:53 pm
Thanks all for the info. I was going to move them to my hardtail but seems like more trouble than it's worth now.
Posted : 28/01/2021 11:32 pm
