Hope E4 caliper bor...
Hope E4 caliper bore cap swap. (O Ring lube)
3 Users
I watched a fair few YouTube videos but none show or mention anything about lubing the O Ring on the new bore cap. Does this have to be lubed (I wouldn't think it likes going in dry ;0)   and if so, what should be used, just a little wipe of brake fluid, or Hunter Silicon lube ?
Cheers.
Posted : 11/10/2024 11:04 pm
Just a smear of brake fluid has always worked for me.
If you've got some red grease that may be a bit better, but meh.
Posted : 11/10/2024 11:09 pm
If you've got Hunter's use that. While DoT fluid is wet which will help, silicon lub is actually slippery
Posted : 12/10/2024 6:56 am
