FAT TYRE FOR 29ER
[Closed] FAT TYRE FOR 29ER
22 Users
epicyclo.
how's your home built fat frame coming on?
Posted : 12/08/2010 9:09 pm
tazzymtb - Member
4.5 psi, bloomin heck! I take it you just blow it up with your mouth like a big balloon then?
with 4" tyres (endo/larry) 5 psi equates to about 100 pumps with a top peak mountain morph 😮 i ride sand at 9 psi front 8 psi rear, for trails etc 12 front and 13 rear as under 12 psi front and steering gets a bit wierd, 😮
Posted : 12/08/2010 10:51 pm
Coastkid, what rims you on?
70-80mm or wider (100 is huge) makes all the difference to tyre pressures as I'm sure you know. Marked difference between even 50mm rim and 70mm in how the bike steers at a given pressure.
I can run 20psi in my werwolf on a 35mm Gordo rim tubed no problem unless very rock then only 22-23psi.
I really fancy a fatbike, Fatbike, Wildfire, 9:Zero:7, now Salsa etc.
Alloy seems good value although Wildfire steel ok, alloy stiffness not an issue with huge tyres, although imam a bit allergic to it!
Posted : 13/08/2010 10:58 am
Page 2 / 2
