Budget Fork: Marzoc...
[Closed] Budget Fork: Marzocchi Marathon LR v Rock Shox Recon Silver
As above, my wife's RST forks are stuffed. Have replaced other bits on her D4W Hardrock, including wheels, (adding) disc brakes and better gears, but the fork is long over due.
Which one would you choose? I note the Marzz LR is air spring, price is £150 ish. Recon is coil spring and £127 ish.
Posted : 14/05/2012 9:56 pm
The air spring will be easier to set up than coil. Coil you will have to spend money getting the correct coil for your weight
Posted : 15/05/2012 1:01 pm
