Blindingly Obvious ...
Blindingly Obvious Things You Somehow Missed
[#13535410]
Removed a Hope BSA30 bottom bracket from one of the bikes today and set it aside.
The drive side cup is longer than the non drive side. It's obvious as the drive side always has one more spacer than the non drive side so of course it's longer. Somehow, I've never noticed this before.
What blindingly Obvious Things have you missed?
Posted : 04/05/2026 8:06 pm
Many moons ago, after spending hours trying, and failing, to fit some Panaracer Fire DH tyres I picked up mega cheap I saw, in big white print on the black and red sidewalls…
24x2.4
Posted : 04/05/2026 9:00 pm
Haha, I assume that was NOT a 24" wheel!
Posted : 04/05/2026 9:14 pm
 It was not 😐
Posted : 04/05/2026 9:17 pm
Eldest next bike. I was replacing the bearings on the rear wheel. I spent ages trying to knock out the axel with emails to the company, only to then discover it needed a hex key to unscrew it.
Posted : 04/05/2026 9:19 pm
Maxles are really easy to adjust. Years of rubbish qr sorted in less than two minutes.
Posted : 04/05/2026 9:36 pm
Posted by: jamiemcf
You've reminded me of my bearing change on a Hope freehub back in the 90s.  I was hammering the shit out of that thing before I realised how much easier it would be if I removed the circlip first
Posted : 04/05/2026 9:45 pm
Definitely did the bearing thing with a Kona Hei Hei Trail. Even bought a blind bearing tool trying to get it out. Eventually found a diagram buried deep in a forum that explained there was some kind of two sized Allen key set up going on.
 I don’t think it was all that obvious though. There was no way of seeing it was the case even shining a torch.
Posted : 05/05/2026 2:47 am
Riding around a couple of years ago I Couldn’t work out why my back wheel was all squiggly and gears wouldn’t index or work as they should at all
Got home and decided to look into what was causing the issue to find the rear axle sticking out a good half inch  😖
Posted : 05/05/2026 4:32 am
I rode behind a friend once who had the axle sticking out like that. It took me a while of thinking "Is that some kind of intentional design to protect the frame?" Then i mentioned it to him and it turned out the LBS hadn't done it up properly. The same LBS that didn't fully tighten handlebars on a new build another friend crashed at the first corner he went around... and the same LBS who didn't fully tighten up the crank arm on the other friend's new bike.
Posted : 05/05/2026 4:44 am
This thread won’t be truly complete until @Northwind turns up.
Posted : 05/05/2026 6:38 am
ChrisL, Ambrose, Riksbar and 8 people reacted
 beej
Quarq powermeter kept reporting low/critical battery level and dropping signal, even with a new battery in.
I hadn't done the cover up properly.
Posted : 05/05/2026 7:35 am
Replaced some 23c with 28c on the road bike last week in a bid for a bit more comfort. Refitted the front wheel and it rubbed the top of the forks, slightly off centre but never a problem with the narrower tyres previously. So off I go to find some youtube videos on re-dishing to pull it across slightly. First step on the video is "check the wheel is properly in the dropouts first". Yeah right, I'm not that stupid... goes to check anyway... oops. Ah well, all fixed and no spoke adjustment needed now 😀
Posted : 05/05/2026 10:10 am
Torque values, for about 25 years.
Posted : 05/05/2026 10:13 am
I once had a stuck rear shifter. Decided that the best thing to do was take it apart at the side of the track (it's not like shifters are full of little springs and screws or anything, what could go wrong?).
Flipped bike onto seat/bars. Took shifter apart. Realised I'd taken the front shifter apart...
Posted : 05/05/2026 10:18 am
Our youngest came downstairs late one night last week with part of the bathroom light switch in her hand that had broken away. I ordered a new one to be collected from Screwfix the next day.
After collecting it, disabling the power to the upstairs light, hunting out tools and step ladders off I go to repair it. Came up with genius idea that I only needed to replace the outer part, not unscrew and rewire the base, was dead please with myself after doing that. Then I realised all i need to was it tie the original pull cord back on and never needed a new switch.
Posted : 05/05/2026 10:20 am
ads678 reacted
After a lot of backwards & forwards wondering why I couldn't get any fresh brake fluid through the brake I was trying to bleed I realised I was following the correct procedure but doing it on the front lever & rear caliper 🙄
Posted : 05/05/2026 10:21 am
nickc, ayjaydoubleyou, ads678 and 2 people reacted
Working from home last week, trying to join a meeting. I couldn't here anything and my microphone didn't work. Sat there looking confused for a while trying to work what I was doing wrong. It work an hour ago. Left the meeting. Came back into the meeting still didn't work still looked like a confused idiot.
Sent a message and left the meeting again for good this time.
About an hour later after looking at a few different things, I though to myself, "why didn't you just put your headset on"?!?!?
Laptop speaker and microphone have disappeared but headset works fine...
Posted : 05/05/2026 7:37 pm
Car oil change, put most of a 5l bottle of oil into the top without having replaced the sump plug in the bottom.
Posted : 05/05/2026 8:40 pm
For a couple of years I dutifully bought a new pair of tubeless valves each year when they started to clog.
then realised it was only the core that was the problem and a pack of 50 was £10
Posted : 05/05/2026 9:16 pm
Posted by: Rubber_Buccaneer
I stripped the thread on my bearing puller properly cranking the thing trying to get a couple of freehub bearings out, only to discover the circlip between them once I got the first one out with a blind puller
Posted : 05/05/2026 10:09 pm
