Home Forums Bike Forum Rockshox RS1 mudguards …. Any ideas ???
Viewing 12 posts - 1 through 12 (of 12 total)
  • Rockshox RS1 mudguards …. Any ideas ???
  • treksuperfly
    Sick of getting mud splattered in the face but can’t find any options for a front mud guard has anyone come up with an idea ?
    benpinnick
    Any of the normal arch fit ones would work, but you’ll get little joy from the small ones as its too far from the tyre. I would suggest a Mudhugger FR is the best bet, that will give you decent conveage. A bit liike the old THE fender…
    eshershore
    Had a customer asking about this yesterday as we were looking at this bad boy
    something with velcro straps perhaps? Nothing on the underside of the carbon crown to attach anything to, unlike a right side up fork with steerer tube exposed
    otsdr
    Topeak DeFender XC1, or go the 3d printing route and make your own:
    l.e. The front race Mudhugger would proably be the best suited, you can anchor it to the crown and upper legs and Bob’s your uncle.
    tomhoward
    My first thought was something that fists with an expanding bung in the steerer? Don’t have any specific examples.
    Failing that, a crud catcher? Or lemonade bottle cut in half. Should really match the aesthetic of a bike with £1200 forks….
    bensales
    The RS1 doesn’t have a traditional steerer, there’s no hole at the bottom, it’s a single piece of carbon.
    I’m just living with it, but as I always ride with glasses, it’s not really a problem. Might pop a down-tube Crudcatcher on, but as above I rail at putting ugly stuff on a 7 grand bike.
    adsh
    My Niner rigid fork isn’t too dissimilar. I mounted a Mucky Nutz Bender Fender. First I prepped the legs with gaffa tape to prevent paint damage then I used cable ties on the legs. Cable ties hold it secure enough you don’t need to worry about the three ties for the fork crown. Added advantage is you can mount it as close to the tyre as you want.
    Works very well.
    breadcrumb
    ^ Which will either be too high to do any good, or get ripped off when the wheel travels upwards.
    I’d say some kind of Crud Catcher would be the easiest solution.
    ndthornton
    A guard that attached at the axles would be the best option…then it could hug the tyre as the suspension travels up and down. Something that doubled as stanchion guards on the way up would look good. I thought about making something like this when I was going to buy some Shiver SC forks. Never bought them in the end…..and don’t have the required tools to fabricate such a thing anyhow.
    Surprised no one makes them though…
    adsh
    I’m feeling slightly/very stupid now. I suspect I might have tried it if I had an RS1 which could have been amusing.
    STATO
    Surely one could just get ones butler to hold a small umbrella over the front wheel to deflect any dirt. Price no object etc. 😆
    treksuperfly
    Id thought of maybe some thing attached to the crown with 100mm long light bristles but making it look good wouldn’t be easy so I posted on here just in case
The topic ‘Rockshox RS1 mudguards …. Any ideas ???’ is closed to new replies.
