Removing cable guid...
[Closed] Removing cable guides from a steel frame, dremel?
[#1985393]
Hi all,
i've got a Cove Sanchez DJ frame that i want to remove the gear cable guides as i'm only going to run it singlespeed. Is it ok to cut these off and grind smooth with a dremel. will this affect the heat treating and weaken the frame?
Posted : 13/09/2010 10:42 am
 Sam
cut them off carefully with a dremel, take it slow and be careful not to damage the tube itself and it'll be fine.
Posted : 13/09/2010 10:57 am
I cut em off my DMR and found the best way was to leave a bit of excess and then file them down by hand
Posted : 13/09/2010 11:04 am
Before you grind them off it might be worth thinking about future value of the frame if you ever decide to sell it.
Posted : 13/09/2010 11:05 am
i got a big file and filed the ones off my inbred. I tihnk what davidtaylforth said is the best way of doing it.
Im awful with a file aswell and the frame is still fine 😀
Posted : 13/09/2010 11:58 am
I dont think any potentially buyers would ever consider running gears on one of those frames anyway.
Posted : 13/09/2010 12:01 pm
Cut them off with a hacksaw, leaving 1mm proud and finish off with a file.
Posted : 13/09/2010 12:04 pm
Don't use a hacksaw, cant get in straight enough IME, I made a nice grove in my fixie frame, doesnt seem to have been structural, but pisses me off whenever I see it.
Dremmel very carefully or file and paitience.
Posted : 13/09/2010 12:50 pm
thisisnotaspoon - Member
It all depends on whether you can use a hacksaw properly or not - I've removed plenty of cable stops and canti mounts this way and never found a problem 😉
Posted : 13/09/2010 1:00 pm
