Home Forums Bike Forum Recommend me an exotic aluminium crankset for single ring.
Viewing 23 posts - 1 through 23 (of 23 total)
  • Recommend me an exotic aluminium crankset for single ring.
  • I’ve got a Truvativ Noir at the moment, but I’ve pulled the threaded insert out three times already and it’s only a matter of time before it happens again.
    Is there an indestructible carbon crankset I could replace it with, or what bling aluminium ones are there that would look right.
    suburbanreuben
    Rotor Rex , http://www.rotoruk.co.uk/rex.html
    Beautifully made, reasonably light and as stiff as a Sergeant Major on his wedding night!
    Daffy
    White industries ENO:
    There’s one for sale in the classifieds…
    amplebrew
    I’m running a White Ind Eno on my SS and it’s been faultless.
    IMG_0063 by AndyBeirne[/url], on Flickr
    arj256
    Raceface Turbine SL
    shermer75
    That White Industries crank looks amazing
    Daffy
    shermer75 – Member
    Shameless plug, but I’ve got one for sale in the classifieds if anyone is interested….
    reggiegasket
    I’ve got a Rotor 3d on my roadie which is very stiff and well made, so I’d say consider the Rotor MTB cranks.
    Thanks for the suggestions.
    I should have mentioned it’s for the belt drive bike, so it’s got to be conventional 4 bolt 104mm BCD to take the pulley.
    I try to achieve bling on a budget as well, so I’d prefer to buy second hand if possible.
    Northwind
    Older XTR? Not exactly bling, but a better option than most “artisan” nonsense 😉
    I’ve got Noirs on one bike and scabrous M970 on the other 2, the Noirs weigh IIRC 3 grams less.
    Yes, I had considered XTR as they do seem to be better value for money than the more niche brands, and much more widely available second hand.
    It’s just that, well, you know, Shimano, it’s not very exotic is it ?
    One option would be to get them polished and anodised red. 😉
    Daffy
    You can get a belt drive sprocket for the WI ENO…
    Northwind
    MidlandTrailquestsGraham – Member
    I dunno, it’s got a pointless pain-in-the-arse fitting method, that’s quite niche.
    gee
    Really? Bolt on with an 8mm Allen key and adjust the collar…
    GB
    orangeboy
    Can’t see the problem with the xtr fitting either.
    For me xtr or rs8 on the bikes I use the most
    Tried race face ( always seemed to creak )
    Quite like the older xt hollow tech ones too bottom brackets last ages
    Just fitted some xx1 arms to the full sus bike but to soon to see if they survive ok
    Northwind
    …and find the special tool to remove it again.
    Rorschach
    dbukdbuk
    What’s wrong with something like a Middleburn RS8? Not bling enough?
    gee
    Really pleased with my RS8 X types.
    GB
    JoeG
    doof_doof
    As above. C’dale arms are about as aluminium gets.
    frood
    +1 for Middleburn RS8 X types… light adaptable and beautiful. Plus lifetime warranty.
The topic ‘Recommend me an exotic aluminium crankset for single ring.’ is closed to new replies.
