Home Forums Bike Forum Recommend me a hammer
Viewing 26 posts - 1 through 26 (of 26 total)
  • Recommend me a hammer
  • jsinglet
    I’ve gone for years with wooden mallet that is falling apart. Every instructional video I’ve ever seen uses a plastic faced mallet for hitting bikes. So I’m going to complete my tookit with one.
    But which?
    http://www.amazon.co.uk/Thor-714-Nylon-Hammer-2-Lb/dp/B0001P0YFA/ref=pd_sim_sbs_diy_3?ie=UTF8&refRID=06N5XFGPXEME3TQMGC1J
    I didn’t realise there would be so much choice. Is biggest best?
    GregMay
    trail_rat
    Thor . Just pick yer weight.
    chambord
    ^^ Still time to edit and replace that with a GIF…
    Northwind
    I’ve got an ancient Thor which I got from my grandad, he probably stole it from the RAF in about 1947. I think it’s this exact one:
    http://www.thorhammer.com/Hammers/Copper/Hammer_id_04-316
    You can spec different faces for it, mine has nylon and aluminium (I’d rather have an iron face on it but I can’t find one). Hope I have a grandkid who’ll get good use from it.
    chakaping
    stevied
    IA
    I have one of these Thors:
    http://www.amazon.co.uk/Thor-Soft-Faced-Hammer-31-712r/dp/B0001P0YF0/ref=sr_1_2?s=diy&ie=UTF8&qid=1426681273&sr=1-2&keywords=thor+soft+faced+hammer
    The two faces are slightly different hardness, which is good depending if you need a tickle or a ****. So to speak.
    tillydog
    If you had a hammer, at what time of day would you hammer? Whereabouts would you hammer? What would you hammer, and where?
    takisawa2
    The real deal…
    stevied
    I prefer dead-blow mallets to the plastic ended ones. Get a much nicer feel to what you’re whacking.
    https://www.machinemart.co.uk/shop/range/guid/55509803-0562-4C90-9293-A9A46C06F75C
    Oh, and LOL @ tillydog 😆
    YoKaiser
    The nylon ends on the thor you posted cut up pretty easily, I’d also say that the hide and copper ends are a bit hard for bike stuff. Personally I’d go with the deadblow above, I have one and it’s fine. I also have a Nupla one and it’s nice too. I’ve used Thors at work for years too but as I say would choose a deadblow.
    IA
    I quite like that aspect of them though, good for ensuring I don’t damaging the thing i’m hitting that isn’t supposed to be hit…
    wilko1999
    When all you have is a hammer, all you see is nails
    Get down your local DIY store and test swing a few
    vincienup
    I have a brightly coloured hammer from machine mart that cost under a fiver I think. It’s a plastic face on one side and rubber on the other.
    Not sure I’d view it as other than ‘disposable’ for use at work, but for bike fettling it’s perfectly adequate.
    z1ppy
    Thor for me, and I really should get some new end caps, much better than the rubber ended hammer I had before and much safer that std metal (nail) hammer
    z1ppy
    Well that popular mechanic links shows we definitely have it easy on here advert wise!
    hatter
    Got my Dad some of the leather handled Estwings, was severely tempted to keep them, lovely things.
    velomechanic
    Got to be this one, for the travelling bike mechanic!
    http://cycleworx.co.uk/collections/abbey-bike-tools/products/team-issue-ti-hammer
    davehast23
    Park tool ones top notch
    julianwilson
    Blimey, i have a hammer with similar dimensions and weight to the ti hammer above, including replaceable plastic ends. I use it occasionally to tap in/out bearings and the odd ht2 type crank. It was A bit less than £110 though, iirc about £2 from toolzone.
    duntstick
    Will be singing this all day now, your fault
    hatter
    Have to agree there, in true Park style it’s hardly the most subtle of implements but it can certainly administer an almighty thwack when required.
    gofasterstripes
    Very much this one.
The topic ‘Recommend me a hammer’ is closed to new replies.
