Viewing 40 posts - 441 through 480 (of 932 total)
  • light bicycle carbon rims
  • futonrivercrossing
    Mine is arriving tomorrow :)) £32 duty/vat
    Jamie
    I’ve got some CX rims on Novatec hubs. Should be arriving today
    What’s the total, inc duty etc, cost of something like that?
    davosaurusrex
    Oscillate; 35mm 29er rims £260 (dodged customs charges), Hope Pro 2s (15/142) with DT supercomps and build £340 at LBS so £600 on the nose. Can’t help with the XD driver. Weight 1700g
    mst
    Jamie – $665.00 USD plus ~£30 for ParcelFarce
    oscillatewildly
    cheers dave – very informative , for some reason (no idea why!) i thought it would be slightly cheaper than that, especially given id need a xd driver too at 65quid
    bigjim
    Have people been putting a little oil inside the nipple eyelet before building as usual? Part of me thinks cheap carbon might soak it up lie a sponge and it’ll disintegrate into a bundle of fibres.
    njee20
    That’s expensive for hubs particularly.
    I bought Amercian Classic hubs from here, which come in whatever freehub body and axle spec you need as stock. Hubs are $363, which according to Google is £214, I paid £35 taxes or so, so £250. Spokes from Germany for £40 or so, and that comes out £50 cheaper for a far lighter hub. FWIW, mine on the hookless narrower 29er rims with Revolutions are 1370g.
    I’d not want to pay £600 to end up with Hope hubs myself.
    oscillatewildly
    cheers njee – is it an issue with the american classic hubs in the uk if something goes wrong?
    im one of those people thats really not to arsed on the hub front, as long as bearings are replaceable and they spin nicely that’ll do me (not that id want to run some cheap deore etc mind), the rims on the other hand are the main concern
    so i could really get a decent set of hubs and spokes and carbon rims for 550ish then which isnt to bad in comparison to a set of enves i guess
    njee20
    No reason for it to be, they have full UK support, they’re just a chunk more expensive over here £207 and £109 plus the XD body from JRA. They do all the spares though if you’re worried.
    thisisnotaspoon
    £340 at LBS
    For that you could buy the hubs from CRC and spokes from bike-discount, and sepend the change on a jig and tension meter and still be in profit.
    davosaurusrex
    Much as I’d like to build my own wheels I really don’t have time, probably not the patience either to be fair. I also draw the line at buying the rims from China and spokes from Germany and then asking my LBS to build them at minimal profit. God knows I spend enough with online sellers, nice to support the LBS now and then (although after they rebuilt them with Supercomps as I originally asked for I doubt they made much out of it, hey ho).
    I’m happy with Hopes, had a set of E13s which were a pain in the arse, good to go back to simple reliable hubs with top drawer UK customer support. My main issue with the old Pro 2s was pickup lag, the new 40T has improved it enough to make it a non-issue for me. So yeah, happy with the price I paid for what I got, happy with the weight too.
    Northwind
    My LBS is doing mine- I provided rims and my used hubs, he’s getting the spokes, seems fair to me and he’s happy too. Oh and he’s getting a go on them too to testride them as a perk.
    proutster
    <in the style of a Ferrero Rocher advert>
    with your testride Mr Northwind you are spoiling them
    <end>
    bigjim
    Isn’t he insanely fast?
    Northwind
    Yup but I’m sure he’ll look after them (after all, his reason for wanting to try these is that it’s too expensive replacing broken Enves. Hang on…)
    bigjim
    well if they can survive him then they’ll be more than adequate for my flumping down the hill.
    RickDraper
    But ENVE have a limited lifetime crash replacement warranty so not expensive to replace.
    davosaurusrex
    Isn’t it in the region of £450 per rim though? I’s say that’s still pretty bloody expensive. Makes my overpriced complete wheelset seem positively bargainous at £600!
    Northwind
    Rick Draper – Member
    50% of RRP for the crash replacement, still expensive in my book!
    RickDraper
    No idea as I have not had to use it.
    davosaurusrex
    Erm, makes your “not expensive to replace” statement somewhat uninformed doesn’t it?
    Yetiman
    The Light Bicycle warranty is pretty good. They replaced a friends rim for the cost of postage, which I think was somewhere in the region of £60 all in (there was also VAT and import duty of course). It was an older 26” 28mm rim that split, and it was replaced with a 33mm version.
    I also emailed LB asking if my new 29er hookless rims bought unused from a mate would still be warrantied should I have an issue (I have a copy of the sales invoice), and they said yes, which is nice 🙂
    bigjim
    Just built up my front wheel, which was very satisfying and amazingly it is round and all good!
    Noticed the rims aren’t totally perfect as I was building, the bead walls have obviously been sanded so there is some variation in them as the wheel rotates, and there is a bit of a dip at the seam in the carbon on the bead seat, doesn’t bother me but someone expecting perfect rims might be disappoint. I used the inside of the rim to check radial trueness given the variation in the bead seat surface.
    i_like_food
    Am v tempted by a set of rims to combine it with a home-build challenge but…
    What is ‘hookless’. To my mind I’m thinking like a tubular road rim, but I know that’s not right.
    Also widths… wider is better, or not always?
    I’d be using them for XC racing, and I’m 75 kg (11.5 stone)
    bigjim
    So the kitchen scales of infinite wisdom and accuracy give me
    760g front
    895g rear
    26″ 33mm on hope pro 2 evos and DT comps, brass nips.
    I used 251mm spokes all round but with hindsight would use 252/3 for the front right side if i did it again.
    Just wondering if a weekend in torridon is really the best test bed for my first built wheels, first cheap carbon, and first bead-hook less experience, or if that is too much random factor in one go in the mountains.
    njee20
    Hookless don’t have a ‘bead hook’ – a lip on the top of the rim to help keep tyres on, no longer needed as QC of rims and tyres is better.
    Wider will give a better tyre footprint on wider tyres, but can be an issue with narrower tyres, plus they weigh more.
    For XC racing I’d go for the narrower 29er hookless rims. They’re still wide, but a chunk lighter. I’ve built mine into American Classic hubs at 1370g.
    jimification
    Just built up some 35mm hookless 29er LB rims. I’m really impressed at how good LB were to deal with and how solid and well finished the rims are. They were also the easiest wheels I’ve ever built (even with revs)as they are so stiff they’re actually quite hard to get out of true! The hookless design seemed to work fine with 1 wrap of wide Stans tape – they went up very easily with a trackpump.
    I’m using them for XC (they’re actually only 50g per wheel heavier than the Crests they replaced) Only had two rides so far but they’re certainly very nice to ride. Incredibly solid feeling for the weight. I’m not sure yet if I actually miss a bit of the flex of my old Crests but the solidity they add when riding over rocks / roots is really nice I must say. For XC I probably would go with the narrower rims, as suggested above. but the 35’s aren’t too much heavier if you fancy something wider / beefier. I don’t think you can go wrong with LB though, will have to see in the long term but so far I’d say they’re pretty sweet rims for what they cost.
    martinh
    Just built up a pair of 35mm 29ers too. About 1650g the pair which is a pretty good
    Not got tyres on them yet so can’t comment on the ride
    jimification
    I see LB have some crazy light 29er XC rims up there. (320g +/- 15g) 27mm. Has anyone tried those?
    http://www.light-bicycle.com/tubular-mtb-rim-carbon-mountain-29er-XC-super-lightweight-27mm-wide.html#.U7pRKD9MRXM
    u02sgb
    “Tubular” though, does that not mean you need special tyres and glue to hold them on?
    njee20
    That’s exactly what it means. Interesting though, tempted to try a set of tubs!
    cookeaa
    Related but not exactly to Rims, I’ve been looking at the LB Carbon Bar/Stem that they do I was just wondering if anyone else has ordered one, what the sizing of it is like, and how you found it comfort wise?
    I generally prefer a Compact, ~120mm drop, round profile bar, but still relatively wide at 440mm, do they do one like that at all?
    bigjim
    OK so I managed to get a tyre on and inflate it, but it has made the spoke tension decrease noticeably. I’ve seen this on stan’s rims, but the question is should I be aiming for them to be a good tension when the tyre is on?
    I don’t have a tensionometer so just plucking compared to my other wheels. Anyone with 251mm DT comps happened to have made a video or recording of the tension theirs are at?!
    sbd16v
    thought I would put up my build got to ride them for the first time last week and I eco everything that’s already been said there just so stiff and direct but feel so light when riding.
    35mm hookless 650b
    hope hubs
    cx ray spokes
    sapim alloy nipples
    was unsure on hub colour but im well chuffed with it now its on the bike (althou im sure it wont be to everyones taste lol.
    davosaurusrex
    I think those hubs look great with the frame. Don’t put any more purple on though, would be too much imo
    chickenman
    Yeah, don’t “Go commando” on this one…
    davosaurusrex
    Ah. Just noticed the purple nipples. Is disappoint.
    sbd16v
    see I love the purple nipples aswell lol
    I was going to put some more purple on it but now I have seen it I agree it needs no more.
    jimification
    Those purple hubs / nips are beautiful! but agree, the balance of acid yellow to purple is a delicate one – it looks great but you’re on a Llewelyn-Bowen knife edge there!
    btw: I decided my new 29er 35mm hookless are more than I need for my lightweight XC riding, so if anyone wants a hardly used pair, I’ll be selling them in a month or so (as soon as the new Light Bicycle 27mm’s XC versions I just ordered arrive).
    bigjim
    hmm yeah could be interested in them jimification, was going to buy some arch ex 29er rims but despite their size these LB ones are still lighter
The topic ‘light bicycle carbon rims’ is closed to new replies.
