Hope T Rex and XT R...
[Closed] Hope T Rex and XT RM clearance (Not! Arrrghhhh!)
[#6347673]
The rear arm of the RM (the bit the cable is attached to), is too close to the adapted cassette at points of the range, (specifically 28T -> 24T) the chain is touching it when trying to shift up so the shift is broken. (I can do a double shift then back if I have to).
It looks to me like pushing all the cogs outwards one level is simply compromising the clearance. It's nowt to do with set screws or the B screw, the TRex itself works fine as does shifting at each end of the cassette.
RM is M786. Cassette is a 11-36 (17T removed IIRC) with a Hope TRex (40t). Shifter is XTR. Hanger and frame are true.
what am I doing wrong?
Posted : 17/07/2014 6:42 pm
No idea... I have same set up and it works fine. You using the longer b screw?
Posted : 17/07/2014 6:46 pm
yes, the longer B screw fully wound in.
here's a pic showing the chain contacting the RM (this is after the shifter has been clicked for the upshift so the RM has moved, and is trying to reposition the chain but it's touching the RM back arm so is being prevented).
https://plus.google.com/photos/+MattGillam/albums/6037092664834972417?authkey=CL6aoozr05hA
the angle looks good because it's on a stand
Posted : 17/07/2014 7:05 pm
(and yes I know the grass needs water, the cassette could be cleaner and the cable needs an end cap. when it works, I'll put one on!)
@matther01 good to know your set up works!
Posted : 17/07/2014 7:06 pm
One up rad cage moves the jocky wheel back £20ish
Posted : 17/07/2014 7:18 pm
Sure the mech is bolted on correctly and the b-screw doing its job correctly?
Posted : 17/07/2014 7:23 pm
Bit curious about the frame, I suppose it's possible the mech/hanger position is doing something weird? There's more than enough clearance normally.
How sure are you everything's straight?
Posted : 17/07/2014 7:26 pm
Best guess is that the arm is bent and/or twisted.
Posted : 17/07/2014 7:53 pm
Don't think jockey wheel is the problem, happy to be corrected. (see the pic).
yeah think so
it's a new frame, had the same issue on another frame (tho this is the first time I have diagnosed it fully).
frame rides straight, it's a 142x12 axle on sliding dropouts
RM is new, good theory but I don't think so. I'll look as it seems a good theory.
Posted : 17/07/2014 8:12 pm
anyway ta for ideas, I ponder some more
Posted : 17/07/2014 8:29 pm
If it happens in 2 frames and the mech is new I'm going to blame the mech. But, with the slidey dropouts, is the wheel axle moving in relation to the mech pivot, or are they all on the same slidey?
Posted : 17/07/2014 8:35 pm
no, mech and axle are in the same slider
Posted : 17/07/2014 9:56 pm
rad it
Posted : 17/07/2014 9:57 pm
Do you need the b-tension screw as far in as that? As the mech body swings down away from the cassette, that arm will swing up toward it. If you can slacken the b-tension and get clean shifts you might be able to find the sweet spot.
The Rad cage will help though as it allows less b-tension, or just file a touch off the corner of that arm.
Posted : 17/07/2014 10:10 pm
Is it a direct mount mech?
Posted : 17/07/2014 10:24 pm
robin ta re logic of rad.I would have thought more B screw means more clearance, I'll experiment.
Stu the mech is http://www.chainreactioncycles.com/shimano-xt-m786-shadow-10-speed-rear-mech/rp-prod83162 (so yes. is that good or bad?)
Posted : 17/07/2014 10:42 pm
Looking at this pic.
The direct mount mechs do seem to sit a bit further back.
That could be causing your problem?
[url= https://farm4.staticflickr.com/3816/13946283374_9172df0dea_z.jp g" target="_blank">https://farm4.staticflickr.com/3816/13946283374_9172df0dea_z.jp g"/> [/img][/url][url= https://flic.kr/p/nfomaC ]IMG_8754[/url] by [url= https://www.flickr.com/people// ]dRj0n[/url], on Flickr
Posted : 17/07/2014 10:55 pm
What hub are you using? Are the end caps on the right way round if its a thru axle? That would cause the cassette to be too close to the mech.
Posted : 17/07/2014 11:04 pm
hi - Hope Pro Evo 2 on a through axle. They are different lengths, wheel won't fit in the frame if adapters are switched.
Posted : 17/07/2014 11:06 pm
I don't think it's the Trex causing it, I'd remove the Trex and try it without, does it still do it?.
Posted : 17/07/2014 11:30 pm
I had this exact same problem last year, I think I later discovered my chain was too short and fitting a new chain the correct length sorted it
Posted : 17/07/2014 11:36 pm
bunch of stuff to try there, will report back, thx for ideas
Posted : 18/07/2014 9:29 am
I had a chance to double check this morning.
Hope 40T with SLX GS RD in the same position as your photo has about 10mm clearance between arm and cassette/chain.
Posted : 18/07/2014 9:41 am
DP
Posted : 18/07/2014 9:42 am
I experimented with winding out the B-screw, there is a sweet spot where the 28->24 shift works, but it moves the problem elsewhere, specifically downshift from 3rd to 4th cog.
I uploaded pics of the set up in smallest cog, largest, and the rear arm of the RM, it doesn't look stressed or out of shape to my eye.
Chain is not excessively short.
back later, will try standard cassette next.
Posted : 18/07/2014 10:12 am
I'd just file the inside of the mech arm until it clears the cassette
Posted : 18/07/2014 10:16 am
By removing the 17t you have moved all the bigger sprockets closer to the mech.
If you put a washer between your derailer and the frame this will regain some of the lost space.
Rear mech spacing relative to casette is also a function of the width of the dropout. There was a recent post here from Brant who said that SRAM were basing there rear mechs on 6mm dropouts so would not reach smallest sprocket if used on a 5mm dropout.
I bet that slider is steel - and probably slimmer than an alloy dropout.
(might have been 6mm and 7mm but you get the idea)
Posted : 18/07/2014 10:45 am
Does look like you have a very short hanger dimension, from axle centre to mech fixing hole centre.
Especially without an offset as the two holes are almost on the same vertical line.
Did you have this setup running okay before?
Have you double check the stops are meeting on the mech and hanger?
Has it just risen slightly as you have torqued the mech fixing bolt?
EDIT - For clarity
Posted : 18/07/2014 10:49 am
To me, it looks like the problem is the linkage between the mech hanger and the mech body is at the wrong angle.
If you look on this pic (from web) the mech hanger bolt (allen) is above the mech body bolt (torx).
whereas on your setup the opposite it the case. The torx bolt is above the allen bolt:
This isn't to do with the b-screw I don't think. It's to do with the linkage being at the wrong angle, which rotates the mech backwards. Maybe the mech hanger is putting the mech at the wrong angle?
Posted : 18/07/2014 10:51 am
Slightly different setup, obviously... But on my Titus FTMC with SRAM mech, the RM bolt is further rearwards of the axle.
I have a feeling you've discovered an issue with compatability between your frame/mech/T-rex.
Posted : 18/07/2014 11:05 am
Though the OP mentioned it happened with another frame too- is that also direct mount?
Posted : 18/07/2014 11:15 am
Is that a matching frame or a different frame OP?
What frame do you have now?
Posted : 18/07/2014 11:19 am
Is everyone using the longer b screw?
Posted : 18/07/2014 11:28 am
You don't necessarily need it for 40t.
Posted : 18/07/2014 11:31 am
Something looks wrong on your last pic:
Surely at some point, the main body of the mech should be more horizontal.
The jockey wheel is a million miles from the small cog!
Edit: reggiegasket's spotted something above. Definitely in the wrong place there.
Posted : 18/07/2014 11:45 am
Frames: both are Canfields, a Yelli Screamy and a Nimble 9.
Yes, wondering this. Perhaps it's a 'Canfield' issue, it's reasonable to assume common DNA in the designs. I'll ask them.
@alexsimon not entirely clear what you're pointing out, could you point me to a generic pic showing the difference you have in mind pls.
In the meantime, I'm going to put a regular 11-36 on and try that.
Posted : 18/07/2014 11:53 am
ah missed reggie's post, thx reggie I take a look at that too.
Posted : 18/07/2014 11:58 am
I think a combination of rotating the mech around based on reggiegasket's post and then loosening the B-tension screw will see it fixed.
Here's a drawing:
Posted : 18/07/2014 12:01 pm
The only way to achieve that would be to remove some material from the hanger.
Posted : 18/07/2014 12:13 pm
Or, presumably the company makes a non-direct-mount hanger for SRAM. And I've heard you can buy the wee knuckle to convert a direct mount mech to a normal one? But that's all pretty messy.
Difficult one, to me it looks like the direct-mount hanger is basically out of spec. But if it works fine on a normal drivetrain they can reasonably say it's fit for purpose.
Posted : 18/07/2014 12:26 pm
Might be a stupid question, but if you unclamp the gear cable can you cycle the mech through the cassette without issue?
ie, move the mech up and down while pedalling, even if you're moving the mech into a position it wouldn't normally get into when using the shifter...
Posted : 18/07/2014 12:27 pm
Northwind - That knuckle looks like the standard shimano part to me, is it DM?
OP - I remember reading that Canflied use a 135mm maxle for a 142mm hub, which I thought was a bit odd at the time, is the hanger also set further inboard than usual?
Best suggestion is to back the B screw right off, reset to give the absolute minimum clearance at the 40T sprocket with the cage in working position and without chain. Then try that.
Posted : 18/07/2014 12:34 pm
Ah, maybe I'm getting confused with all the pics, I thought this was a direct mount mech?
Posted : 18/07/2014 12:37 pm
Someone posted a DM pic but I don't think it was the OP.
Posted : 18/07/2014 12:47 pm
Looking at what I believe is your post on another forum, I can't see that rotating the mech will solve the problem...
It appears that, to me, your mech is too far forward in relation to the wheel axle.
Posted : 18/07/2014 12:50 pm
Page 1 / 3
