Evening all, First time on here, so not sure this post is going to end up in the right area....I have a 2012 Cube AMS 130SL, that currently has a pair of Fox TALAS 110/130/150mm FIT forks on it. They are knackered and I am considering replacing with a some Rock Shox PIike 160/130 RCT3's. I am curious as to whether this is a good idea, given the bike should only run unto a 150mm fork. Will the extra 10mm change the geometry that much and place too much stress on the head tube, or am i just worrying unnecessarily??? I normally run the current fork at 150mm for trail use....cheers in advance....
Posted : 17/07/2014 6:56 pm
