Gelert Solos tent a...
[Closed] Gelert Solos tent anyone?
[#2498143]
Anyone got / used a Gelert Solo tent? What do you think of it?
Any cheap viable alternatives out there at the moment?
Posted : 23/02/2011 12:45 pm
I've got one somewhere - I've used it several times, including camping on the top of hills and in pretty windy conditions. Here it is at the top of East Cairn Hill in the Pentlands:
It's very small - getting changed inside it is a struggle - but fairly stable in use if it's pitched into the wind. I used mine in some pretty wet and windy conditions and it survived ok. It was noisy (but what tent wouldn't be) and a little bit of spray came in one of the vents (I was using a bivi-bag over by down bag so it wasn't a problem).
It packs very small and is light given the low price (under 1.5kg I think) but there is one big downside and that is the fibreglass poles, which are crap. One of mine started to split (although it's fine since being re-inforced with tape) and I'd be quite surprised if it survived more that a few trips.
Argos used to do a very good cheap one-man tent (can't remember the name but I've got a couple of them) which is a bit heavier (still sub 2kg though) but much, much better quality. It's also a pretty good size as well.
Posted : 23/02/2011 12:53 pm
Just checked on Argos and can't see the tent there any more. It was a Pro-Action one, although usually they can be had on Ebay. Current item 320658027852 looks like it, although the ones I have are green.
Posted : 23/02/2011 12:58 pm
Like steve says, the poles aren't up to much ... however it's easy enough to buy a Vango Aluminium pole kit and make some new ones, shaves quite a bit of weight off too. For the money there isn't much out there that compares, nearly everything else will be single skin and just as heavy.
If you don't mind a little bit more weight / cost then take a look at a Vango Banshee.
Posted : 23/02/2011 12:59 pm
I did wonder about getting some aluminium poles as with those it'd be a great little tent if you don't mine the lack of space.
Might look at doing that, even though I splashed out on a Big Agnes Seedhouse SL1 when I was in the states a while back. Is there a particular Vango kit that I should be looking for?
Posted : 23/02/2011 1:02 pm
Can't remember which kit it is now Steve but I seem to recall there was only one with the right diam' poles ... but I could be wrong 😉
Posted : 23/02/2011 1:04 pm
Mine split down the seem the first time I used it. Only on the inner, at the foot end so not terminal but I wouldn't get another one
Posted : 23/02/2011 1:18 pm
Think these are the things
http://www.traveloutdoorsleeds.co.uk/vango-8.5mm-alloy-pole-set/
Posted : 23/02/2011 1:20 pm
The Argos tent can be found if you shop around, there's somewhere doing them for £30 at the moment. It's the Pro Hike Lite I believe, the orange one.
Great value for money, although perhaps slightly heavy compared to more expensive competition. Mine has seen off Glencoe rain without any problems at all.
Posted : 23/02/2011 2:12 pm
Couldn't find anywhere with the Pro Hike Lite tent in stock, but that one on eBay looks worth a punt. Plan was to go with Gelert Solo and replacement alloy poles, but thanks for thoughts on other options.
Posted : 23/02/2011 5:55 pm
Thanks for the info on those poles - will check them out.
On the Pro Hike tent - I'm pretty sure I've got two of them (one might even be unused), green rather than the orange though. I'll have a look tonight but could probably be persuaded to part with one of them. I've got loads of other tents anyway!
Before I got the Seedhouse my favourite 1-man tent was the old Vango TBS Micro 100. They can often be had cheap 2nd hand and are excellent little tents. The main benefit of them over the Solo or the Pro Hike is that it can be pitched inner first or all-in-one, which is useful in bad weather.
Posted : 23/02/2011 6:56 pm
I picked up a Force Ten Helium a few weeks ago, brand new from the shop £100 ... pretty much half price 😀
Only being 5'7" means it's like a mansion inside!
Posted : 23/02/2011 7:06 pm
Force Ten Helium @ £100 - have they got any more?
Posted : 23/02/2011 11:39 pm
This looks like it could be good but not tried it myself.There's a few review online
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350193138660&ssPageName=STRK:MEWAX:IT
Posted : 24/02/2011 12:44 am
So is the Vango Banshee any good? Going cheap in Go Outdoors at the moment.
Posted : 24/02/2011 12:54 am
I have a Gelert Solo and an alloy replacement pole set. Never got round to actually replacing the poles - looks like a major faff-on. How do you go about bending the poles to the correct shape? Some of the sections are only about 15cm long with bends in them....
Do I need a pipe bending tool?
Posted : 24/02/2011 1:01 am
I've got one of the pro hike lites in green that I could be persuaded to part with in Bristol. Used twice and in perfect condition.
£20
Posted : 24/02/2011 8:33 am
@DoctorRad, I picked up the Helium from Field and Trek ... no sign on the website though. I assume it's an in store offer.
I do have a brand new Terra Nova Argom 900 I'd sell for £100 if anyone fancies it. 2 man and sub kilo.
Posted : 24/02/2011 9:40 am
@flatfish - yes please, I'm in Long Ashton, but could pick up. Email in profile, or I'll look for yours...
Posted : 24/02/2011 10:12 am
call me oppurtunistic - but i've got a banshee and a gelert solo that i'd part with.
both used once.
also have an older 20L OMM rucksack going as well.
n.downs located if anybody is interested.
Posted : 24/02/2011 10:20 am
http404 which banshee and how much?
Posted : 24/02/2011 10:54 am
@user-removed: Looks to me like the best approach would be to use the existing alloy elbows, remove the carbon poles and replace with alloy. No bending of anything needed.
Posted : 24/02/2011 11:07 am
How about these;
http://www.winwood-outdoor.co.uk/acatalog/Coleman_Kraz_X1_Single_Person_Backpacking_Tent.html
I have a gelert but not had the opportunity to use it in anger. The poles are quite strong as my 2 year tested them by jumping on the tent when I put it up in the back garden!
Posted : 24/02/2011 11:15 am
The problem with the Gelert poles that I've read about is them becoming brittle and cracking in cold temperatures. Alloy replacements are apparently stronger and lighter.
Posted : 24/02/2011 12:10 pm
I have a Banshee, very good. I used it in the Lakes 2 years ago and it did the job nicely.
On the second night it was extremely wet and windy and I was a bit worried....no problems, so I am very pleased with mine.
Posted : 24/02/2011 12:16 pm
I'm interested in that - drop me a line at niblueATyahoo.com with more details please!
Posted : 24/02/2011 6:07 pm
Sent you an email Steve.
Posted : 24/02/2011 7:40 pm
Thanks for the tent deal flatfish 😀
Posted : 24/02/2011 10:27 pm
No worries. Enjoy.
Posted : 24/02/2011 10:36 pm
Note photo and comment 🙂
http://www.flickr.com/photos/47300508@N05/4381724925/in/set-72157623494030614/
Posted : 25/02/2011 12:05 am
DoctorRad - Member
Ah yes 😳 Just checked and you are of course quite correct. I had a false memory of the poles themselves being bent...
Posted : 25/02/2011 12:15 am
@Tiger - presumably the moral of the tale is that a tarp is more pisshead proof than a tent?
Posted : 25/02/2011 10:44 am
