Home Forums Bike Forum Formula R0 Racing Brakes – advice please
Viewing 14 posts - 1 through 14 (of 14 total)
  • Formula R0 Racing Brakes – advice please
  • cuda17
    Maybe a little foolishly I have purchased (off a well known bidding site!) a Formula R0 Racing front brake in the Team Edition blue colour (not that that bit matters but trying to justify my purchase!!). now i got this at a bargain price, only problem is I cant find any advice/information as to spare parts of any kind! First and foremost brake pads (it didnt come with any). so my questions to the knowledgable out there…
    1. is the “Racing” version of the R0 the same as the standard R0?
    2. can i fit brake pads specified for “The One”, “R1”, “RX”, etc or being as my brake runs an ovalised piston do i need a specific “R0R” brake pad
    3. Any idea what mounting bolts i need to fit on a Rockshox Yari running a 180mm floating rotor?
    4. am i a complete idiot for not doing my research first?
    thank you
    stevied
    Are they the older style like this:
    If so:
    1: Don’t know, maybe a slightly lighter version?
    2: Yep, pretty sure they’ll be the ones
    3: Pretty sure the Yari is a 180mm standard size (ie 200mm needs an adapter) so M6 x (about) 16mm caphead. Don’t just wind them in, check they are tightening the caliper.
    4: Maybe 😉
    Great brakes though, had mine for about 3 years and only needed one bleed. Loads of power, great modulation.
    cuda17
    cheers for the advice!!
    they look simular to those but the master cylinder is pulled rather than pushed by the lever if that makes a difference?
    http://www.silverfish-uk.com/ProductDetail/8457/18728/RO-Racing-Brake-Team-Edition
    the above link should show you the ones i have.
    stevied
    Ooh, go on, how much did you pay? Been looking at the new ones for no other reason than they are new 🙂
    Pad will be the same as the older RO’s then:
    Yetiman
    Yeah how much?
    I have two pairs of the standard R0’s….awesome brakes and like stevied they have only needed one bleed in over 3 years of fairly hard use. I love them.
    cuda17
    i dont want to upset anyone by saying how cheap they were (front only btw) and as they have no pads in them i’ve yet to check if i’ve bought a rotter!! 😳
    but think dirt cheap and go lower!!!!
    where do you get your pads from then? i was told by uberbikes components they didnt stock them!
    Yetiman
    I’ve settled on Superstar kevlars. Uber certainly used to stock them, as I bought a couple of pairs of their Race Matrix ones, but the quality and performance was a bit iffy.
    ads678
    I’ve had R1 pads from superstar, crc, Uber. Are these the ones you need?
    https://www.uberbikecomponents.com/category/332/Formula-Disc-Brake-Pads
    stevied
    Chain Reactio have one set left: http://www.chainreactioncycles.com/formula-formula-one-r1-rx-disc-brake-pads/rp-prod25564
    Superstar are my normal ‘go to’ but they are out of stock.
    cuda17
    i asked uber and they said those wouldnt fit the RO!??!
    tish
    I’ve had pads from uber for my older ro’s.
    Fantastic brakes I love mine.
    cuda17
    at least i may have made the right choice in brake as they seem to be getting much love on here! might have to change out the XT M785 i have on the rear at this rate!
    ads678
    These are cheap as chips on CRC. might be worth a go for a few quid to check the fit.
    http://www.chainreactioncycles.com/brand-x-formula-r1-the-one-db-disc-pads/rp-prod136703
    cuda17
    Wow!! that is cheap!!! defo gonna take a punt on them!!
    great spot !
The topic ‘Formula R0 Racing Brakes – advice please’ is closed to new replies.
