Disc brakes for XC ...
[Closed] Disc brakes for XC = daft
Last year I used my v- brake retro killi flyer for a lap at race. Oh my I love my discs.
V brake ok for bumbling around with your missis but not flat out down hill with flat bars on a hardtail
I could not help feed the troll sorry
Posted : 24/05/2012 7:26 am
 Mr_C
I last bled my XT brakes in 2003 when I installed them, they have now been on 3 different frames and the only maintenance I have had to do is replace the pads - a 2 minute job with no finicky adjustments which can be done on th trail if necessary. I wouldn't want to try and install V pads out ib the wilds.
The OP may think they are OTT but just looking at it from a maintenance POV they have probably saved masses of time which can be spent riding the thing.
Posted : 24/05/2012 7:39 am
All brakes are OTT for mountain biking. Fixie all the way for me!
Posted : 24/05/2012 7:44 am
Pfft, v-brakes are flashy posers.
Rod brakes are where it's at. All this cable nonsense! *walks away shaking head*
Posted : 24/05/2012 7:45 am
don't feed the troll.
Posted : 24/05/2012 7:58 am
Yeah! Rod brakes..wooden rims..an lard instead of bearings..if you need owt else you're a wuss.... 😀
Mmmmmmmmmmlard.......
Posted : 24/05/2012 8:02 am
brakes are daft full stop. And they are for jessies..
jam your foot twixt tyre and frame a la 1981 for maximum radness.. be prepared for a bollocking from your old dear when she sees the state of your shoes though
Posted : 24/05/2012 8:09 am
That bike is better looking than Tulisa
[i]She's[/i] your yardstick? Each to their own, of course, but you've not set your standards all that high, now have you?
Posted : 24/05/2012 8:25 am
orangeboy - Member
If it were a singlespeed you'd have been massively slower on a lap regardlesss of brake type. Yet that's an option on frames today while V brakes aren't.
Races are won and lost on the climbs anyway, and not many ppl are fast enough to need to brake into uphill corners.
As long as you can lock a wheel, that's as much braking power as you could ever need. 4 piston calipers, cross-drilled discs etc are just marketing ploys. An engineering professor actually told me this. See, I wasn't born this way you know.
nickf - Member
She's your yardstick? Each to their own, of course, but you've not set your standards all that high, now have you?
Ah but you didn't disagree!
Not my yardstick, just what a certain poll in a well known periodical depicts as the benchmark. I'm saving myself for Sue Barker. 😛
Posted : 25/05/2012 12:52 am
 mboy
Many of us, yes, but I know some guys that singlespeed or gears, it matters not, they'll still kick almost anyone's arses. So that's kinda a moot point, and far be it for me to defend singlespeed (not my thing either), but the whole idea originally is that it just doesn't require the level of maintaining so makes a good idea for winter bikes, where the overall speed will be lower anyway.
It depends at what level you're talking... Fat biffer sport category, yes almost certainly, but World Cup XC level... They're probably all as quick as each other on the ups, but the reason the likes of Julien Absalon has been so consistently successful over the last decade nearly, is he's such a good technical rider and descender, that's where he puts time into his opponents. Helps that he rides and trains with his brother Remy, who has pretty consistenly been the world's best Enduro DH rider too over the last few years.
Power is nothing without control, as the old Pirelli advert used to go. You can lock a wheel if you put a stick in it, doesn't mean it's useful though! Similarly, take almost any old car with really crap brakes (but still disc brakes), something like an 80's Fiesta say. If you positively kick the brake pedal at 40mph, not squeeze it progressively, I guarantee you'll lock the wheels up still. Does that mean its brakes are good enough?
Being able to lock a wheel, and stop a bike effectively are two totally seperate things. Your engineering professor (would love to know where he teaches, so I could turn up to one of his lectures, and out him for the engineering know nothing luddite he really is in front of all his students!) hasn't got a clue. If you use fistfuls of brake, then you could probably get an old school U brake to lock a wheel even, or even a rod brake if you tugged hard enough! Only in the dry though, in perfect conditions.
To stop quickly, and safely, on a Mountain bike though, you need to maintain control of the bike. The more fingers you have to use to slow the bike down, the less control you're retaining on the bike. The more pressure you have to use to slow the bike down, the less control you have over the bike and the more fatiguing it becomes to brake repeatedly. Modern disc brakes, allow you to repeatedly stop a mountain bike, in any conditions, with a maxiumum of control, using only 1 finger per brake, and a minimum of brake lever pressure required. This is FAR better for the rider in the short, medium and long term.
I'm noticing that on your bike, amongst the other odd choices of component that you make, you are using some cheap caged pedals with clips and straps still. What's your theory behind this? Why not clipless pedals, or proper flat pedals? And the stem that crosses two time zones on its way to the handlebars from the steerer tube? Again, why? You will find your retro lookout, and belief that technological advances are marketing bullshit, is pretty unique on here. OK, now I'll agree that when some manufacturers claim their 2012 bike is 5% stiffer than their 2011 bike, and 50 grammes lighter, in an attempt to justify a £300 price hike, I'm one of the first people to whinge about marketing bullshit, but disc brakes came on the scene a long time ago, and have stuck around for good reason.
Posted : 25/05/2012 4:29 am
 GW
Eh? one finger braking is fine with v brakes.
Posted : 25/05/2012 5:53 pm
I'd rather use the brake lever thanks all the same. There is always a risk of catching said pinkie in the spokes if you do it your way.
Posted : 25/05/2012 6:26 pm
Complete & utter rowlocks my friend 'cos at that point youve lost control of how much braking youre applying.
Did he tell you that the Earth was flat too??
Posted : 25/05/2012 6:54 pm
Luckily for you, this is a democratic country. if you don't like disc brakes, then no one is forcing you to fit them! Just stick with your V brakes.
The rest of us, not stuck in 1984 will continue on without you
(and no, i'm not going to wait at the bottom of the hill for you to catch up as you bump along at 5mph out of control on your chosen steed)
Posted : 25/05/2012 9:44 pm
 GW
The original point was that many frames and forks don't come with bosses for rim brakes anymore. 🙄
You're an absolute fanny if you honestly believe discs will make you any faster or more in control on most XC descents.
Posted : 25/05/2012 9:54 pm
Why?
Posted : 25/05/2012 10:12 pm
Posted : 25/05/2012 10:44 pm
 grum
I'm an absolute fanny.
Posted : 25/05/2012 11:01 pm
All XC descents which are ridden faster and better due to disc brakes are now re-categorised as hydrodiscgnarXCore...
Posted : 25/05/2012 11:22 pm
in the dry maybe, but in the wet?
pff i dont even know why im replying to this troll thread...
Posted : 25/05/2012 11:52 pm
Can you please define "XC descent"?
Posted : 25/05/2012 11:54 pm
XC riding in the mud with rim brakes = poor braking and clogged up forks/chain+seat stays.
XC riding in the mud with disc brakes = good braking
Conclusion = As this is the UK and generally muddy most the year XC riding is better with discs.
Posted : 26/05/2012 12:17 am
 GW
you think disc calipers don't clog up too? (have you missed the amount of moaning about wearing out pads in one ride or less on here?) plus, how can you blame clogged up chainstays on a brake mounted on the seatstays?
thing is... in muddy conditions your bike rolls way slower and braking lessens grip so why are you wanting "better" brakes? sounds like some of you you might be a bit scared of riding in mud to me.
pretty bloody obvious chvck but here you go:
"XC descent"? = any descent on an XC ride. (and I did say "most")
XC ride = up/down/along and mainly off road.
Posted : 26/05/2012 12:38 am
was riding for 10 years on cantis and v-brakes (which were amazing at time, and came with a tag saying not to pull the front too hard because you'll endo). then one day, I used my emergency support grant to buy a set of hopes in 1998-ish. All of a sudden I was able to smoke everyone on the pink heifer descents in the wet, because I could brake later and harder. Good day, that. Ahhh, nostalgia. when coed y brenin had proper trails, not this motorway nonsense, and you got a baked potato with cheesey beans on in the shed at the end, jumpers for goalposts, and so on.
Posted : 26/05/2012 2:54 am
mboy - Member
Almost all Olympic XC gold medals have been won by riders with rim brakes - fact. (Actually I'm guessing but I'm sure I'm correct on that).
mboy - Member
Similarly, take almost any old car [b]with really crap brakes[/b] (but still disc brakes), something like an 80's Fiesta say. If you positively kick the brake pedal at 40mph, not squeeze it progressively, I guarantee you'll lock the wheels up still. Does that mean its brakes are good enough?
You've just prejudiced a statement then contradicted yourself. If the brakes can lock the wheels, there is no more the brakes can do to slow you down. The maximum possible deceleration of a vehicle is µg where µ is the coefficient of friction between tyre and ground. Hence why riding down a muddy slope it matters very little what your braking medium is because not much braking force will lead to locking a wheel. Grippier, more suitable tyres would make the biggest difference. You know this to be true from experience.
And if you ride when it's raining the disc/pad gets affected just as negatively as a rim/pad would.
There could be a market for drum brakes, who knows?
mboy - Member
1. Cheap 2. Being mechanically attached to a bike? No thanks 3. Flat pedals have freedom but one shin whack is always one too many
mboy - Member
1. I like to see the sunrise in New York while my wheels are in Surrey 2. Being stretched out a bit more helps on climbs and aids my classic Max Biaggi cornering style 3. Short stems have always led to twitchy bikes for me
Posted : 26/05/2012 3:07 am
Both are harmful to squirrels.
Posted : 26/05/2012 3:23 am
 mboy
That's 4 time zones, but I'll give you that one... Good come back! 😉
Don't go into an argument armed without facts. MTB has been in the Olympics since 1996, but a quick youtube search for footage reveals that even by the Sydney Olmypics in 2000 many competitors were running disc brakes, by 2004 in Athens just about all of them were already on discs (although Absalon was still using V Brakes at this point oddly). Just found a pic of Absalon's 2008 winning Olympic bike, and it's very definitely fitted with disc brakes though, as was everyone else's it would also seem by video footage. Even the French and American markets, that doggedly hung onto V's on top level XC bikes for ages after the rest of the world moved on, still moved over to discs pretty much wholesale 7 or 8 years ago now.
It does get affected, but not as badly. I remember Shimano made several prototype drum brakes back around the late 90's, and several top level DH riders were testing them. They seemed to do the job pretty well, only they were hideously expensive to make, and generated extreme amounts of heat iirc.
A bigger grippier tyre will of course make a difference. I'm not denying that. You've lost what I was trying to get at though, and that is the speed factor. A V brake, in the dry, is usually more than capable of locking a wheel up at low speeds... How does it perform at high speeds?
It's not the low speed performance that's an issue, if we all rode everywhere at a max of 10mph, then V brakes would be fine. Its the high speed stuff that we're concerned with. V brakes simply don't provide enough power as the speed increases. Discs offer a lot more power and control which is more useful at higher speeds.
I'm interested to know, have you properly ridden a bike with decent disc brakes for any amount of time? And if so, on what terrain, and what did you think?
I can understand the first point you make about your pedals, but the second...? With clips and straps, you're actually more mechanically attached to the bike (it's certainly more difficult to get out of in a hurry) than with decent clipless pedals. It's an old wives tale that experienced riders like to scare newbies with when they start riding, that clipless pedals are dangerous to use and need extreme care.
Anyway... Where do you ride normally? It might go some way to explaining some of your theories also, and why you're happy with what you've got. It'd be interesting to see you swap bikes with someone on a modern disc braked, clipped in, short stemmed bike to see how you cope. I think if you relaxed a bit, you might even enjoy it somewhat more than you think possible!
Posted : 26/05/2012 4:11 am
Wow. People are STILL trolling on this topic after all these years.
OP, isn't it about time you got some new material?
Posted : 26/05/2012 7:04 am
U brakes anyone?
Posted : 26/05/2012 8:25 am
Have you considered a skills course?
Posted : 26/05/2012 10:52 am
Had a great ride today - at no point did I think I needed or wanted disc brakes.
And no squirrels were harmed either.
Anyway, there is a half decent frame in existence that has V-brake mounts
Like they say, if you're riding across a continent the last thing you want is hydraulics to worry about.
kenneththecurtain - Member
Just you wait til my next thread!
Posted : 28/05/2012 12:43 am
Wow, this is still going, I am incredulous.
Posted : 28/05/2012 7:37 am
Agreed. If correctly set up. And in the dry. But quite tiring on longer trails. I would not swap my disc brakes back for Vs.
Posted : 28/05/2012 8:14 am
Ha ha - brilliant
Been away for 4 days without internet access and see that this is still going
The best bit is the dead squirrels - genius!! 😀
Posted : 29/05/2012 8:26 am
Your choice of bicycles hints very closely at the type of riding you do and thus why you would see no merit in disc brakes for 'your' XC.
Do you really need to carry on with this?
Posted : 29/05/2012 9:04 am
Page 2 / 2
