Best minipumps at t...
[Closed] Best minipumps at the mo?
[#5158521]
My Blackburn seized up when reinflating post-puncture this morning. In a fit of stupidity, I unscrewed it to try to ascertain the problem, and a shower of tiny bits fell out. So it's now definitely died. 😆
So, what minipumps are people currently recommending - not too pricey as am super skint right now, discrete enough that people aren't going to immediately pinch it off my pomp when it's locked up, frame clip so I can leave it on there most of the time, not too big and obviously good for decent pressure. Not too demanding, eh? 🙂
Any suggestions gratefully received.
Posted : 15/05/2013 10:37 am
Evolution, under whatever brand it's sold under these days- used to be Truflo, think it might be Mparts now? Like a Mountain Morph but cheaper and doesn't fall apart.
Posted : 15/05/2013 11:06 am
Cool ta, will take a look. Any other recommendations, people?
Posted : 15/05/2013 11:28 am
Mountain morph or some johnny come lately replica. I'd suggest there obviously not for the cack-handed but as I am cack-handed, mine lasted 5 or more years before I managed to snap the footpad off the other month.
Make of that what you will & just get one (or a copy)
Posted : 15/05/2013 11:39 am
I bit the bullet and went for a Lezyne Pressure Drive. It better not let me down!
Posted : 15/05/2013 1:20 pm
What are these like? [url= http://www.on-one.co.uk/i/q/TOPHGM82/phaart_rumbler_large_volume_micro_floor_pump ]Phaaaaaaart[/url]
Posted : 15/05/2013 1:28 pm
They are really good. One of the best pumps i've used and by far the best value for money pump out there.
Posted : 15/05/2013 1:32 pm
I have a Lezyne one, quite like it as it screws on to the valve, rather than just held on by friction (the standard press on, and flip the lever), which I never really got on with.
Plus it's anodized red and looks cool 😛
Posted : 15/05/2013 2:05 pm
I think we have the same one. "Alloy Drive" or something, IIRC. Good bit of kit.
Posted : 15/05/2013 3:46 pm
Duane... - Member
That was part of what convinced me - I managed to rip the valve on my only spare tube recently using the now-deceased Blackburn. Never again, hopefully!
Posted : 15/05/2013 4:45 pm
Another shout for the Phaart Rumbler - great VFM, comes with frame clip, and works! It has a pull-out hose which avoids valve ripping.
Posted : 15/05/2013 5:29 pm
Why not just get another Blackburn? It has a lifetime warranty, contact the shop where you got it from / Madison for details of how to get it replaced. Saves buying a new one.
Posted : 15/05/2013 5:48 pm
does it now... will look into that, ta.
Posted : 15/05/2013 6:05 pm
Anyone know the dimensions (ie. length) of the Phaart Rumbler pump?
Posted : 15/05/2013 6:52 pm
Phaart Rumbler is teh win-awesumz. Does the job with much less faffage and isn't that much bigger in the bag than my Blackburn Pump. Although it clips to a bottle mount, it's big (by mini standards) so will probably go missing if left on the frame. It's great though, just take it off when you lock up.
Posted : 15/05/2013 6:54 pm
Roughly it's 30x4x2.5cm
Sounds massive but is fine in real life as the plastic hose tube and alloy barrel aren't particularly fat.
Posted : 15/05/2013 7:00 pm
30cm is quite long for a jersey back pocket though, no?
Posted : 15/05/2013 7:46 pm
It is, but it's also a mini floor pump. There's only so small it can reasonably be. I think the Lezyne teeny weeny pumps or those airbone ones Charlie the Mike Bonger sells are more jersey friendly.
I wouldn't have one waggling about on my back (I'd use the frame mount), but then I only use my road bike for getting about and not 'proper' roadie use.
Posted : 15/05/2013 9:45 pm
